MHB Every Cauchy sequence converges
  • Thread starter Thread starter evinda
    Cauchy Sequence
The discussion emphasizes that the p-adic numbers are complete with respect to the p-norm, meaning every Cauchy sequence converges. A proof is provided, demonstrating that if a Cauchy sequence is bounded, it can be transformed into a sequence within the p-adic integers, which are shown to converge. The proof also establishes that the limit of the sequence lies in the p-adic integers. An alternative proof is suggested, utilizing the compactness of the space formed by the finite sets of p-adic integers, leading to the conclusion that the p-adic metric induces a complete topology. Overall, the thread effectively illustrates the completeness of p-adic numbers through various proofs.
evinda
MHB
Hey! (Wave)
Sentence:
The p-adic numbers are complete with respect to the p-norm, ie every Cauchy sequence converges.
Proof:
Let $(x_i)_{i \in \mathbb{N}}$ a Cauchy-sequence in $\mathbb{Q}_p$.
We want to show that, without loss of generality, we can suppose that $x_i \in \mathbb{Z}_p$.Let the set $\{ |x_i|_p | i \in \mathbb{N}\} \subset \mathbb{R}$. We suppose that it is upper bounded. If not, there are $\forall m \in \mathbb{N}$ and $N \in \mathbb{N}$ two indices $i,j \geq N$ with $|x_i|_p> |x_j|_p \geq p^m$.
From the sentence: For $|x|_p \neq |y|_p$, it stands that $|x+y|_p=\max \{|x|_p, |y|_p \} $, we have that $|x_i-x_j|_p=|x_i|_p>p^m$. This is not possible for a Cauchy-sequence.
Now, we pick $m \in \mathbb{N}$ with $p^m \geq \max \{ |x_i|_p | i \in \mathbb{N}_0 \}$. Then, $(p^m x_i)_i$ is a Cauchy-sequence with $|p^mx_i|_p \leq 1 \Rightarrow p^mx_i \in \mathbb{Z}_p$. It converges exactly then, when $(x_i)_i$ converges.So, we just need to consider a Cauchy-sequence $(x_i)_i \in \mathbb{Z}_p$. We want to show that it converges and to determine its limit $z \in \mathbb{Z}_p$. For each $k \in \mathbb{N}$, we pick a $N_k \in \mathbb{N}$, so that:
$$|x_i-x_j|_p<p^{-k} ,\text{ for } i,j \geq N_k$$
We can suppose, that $N_k$ is an increasing sequence.The above inequality is equivalent to $v_p(x_i-x_j)>k$ or $x_i-x_j \in p^{k+1} \mathbb{Z}_p$. So, we find a $z_k \in \mathbb{Z}$, such that:
$$z_k \equiv x_i \equiv x_i \mod p^{k+1}\mathbb{Z}_p, \text{ for } i,j \geq N_k$$
Because of $N_{k+1} \geq N_k$, it stands that:
$$z_{k+1} \equiv x_{N_{k+1}} \equiv x_{N_k} \equiv z_k \mod p^{k+1} \mathbb{Z}_p$$
ie. $z=(\overline{z_k})_k \in \Pi \mathbb{Z}/p^{k+1}\mathbb{Z}$ is an element from $\mathbb{Z}_p$. Also, for $i \geq N_k$, it stands that:
$$x_i \equiv z_k \equiv \ \mod p^{k+1}\mathbb{Z}_p \Rightarrow |x_i-z|_p<p^{-p}$$
so $x_i$ converges to $z$.
Could you explain me step by step the above proof?
Mathematics news on Phys.org
Here is an easier proof that minimizes the use of $\varepsilon$'s . First define $X_n = \mathbb{Z}/p^n \mathbb{Z}$, and give these finite sets the discrete topology. The $p$-adic integers are the projective limit of the $X_n$.
Now consider the product,
$$ X = \prod_{n=1}^{\infty} X_n $$
This is a compact space because each $X_n$ is compact. Furthermore, $\mathbb{Z}_p$ is a closed subset of $X$. Thus, $\mathbb{Z}_p$ is a compact space.
This means that if you can find a metric which describes the topology on $\mathbb{Z}_p$ the metric must automatically be complete (since compact metric spaces are complete). You have to show, which is not so difficult, that the $p$-metric induces the same topology as $\mathbb{Z}_p$ inherits from being a subspace of $X$.
This will prove that $\mathbb{Z}_p$ is complete with respect to the $p$-adic metric. To show that $\mathbb{Q}_p$ is complete you "defractionize" it.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
