Every integer greater than 5 is the sum of three primes?
Every integer greater than 5 can be expressed as the sum of three primes, which is proven through two cases: when the integer is even and when it is odd. For even integers, the proof utilizes Goldbach's conjecture to show that subtracting 2 from the integer results in another even number that can be expressed as the sum of two primes. For odd integers, subtracting 3 yields an even number that can also be expressed as the sum of two primes. The discussion highlights the equivalence between the Goldbach conjecture for even integers greater than 2 and the statement regarding integers greater than 5. This establishes a foundational link between these two conjectures in number theory.
Math100
Prove that the Goldbach conjecture that every even integer greater than ## 2 ## is the sum of two primes is equivalent to the statement that every integer greater than ## 5 ## is the sum of three primes.
[Hint: If ## 2n-2=p_{1}+p_{2} ##, then ## 2n=p_{1}+p_{2}+2 ## and ## 2n+1=p_{1}+p_{2}+3 ##.]
None.
Proof:
Let ## a>5 ## be an integer.
Now we consider two cases.
Case #1: Suppose ## a ## is even.
Then ## a=2n ## for ## n\geq 3 ##.
Note that ## a-2=2n-2=2(n-1) ##,
so ## a-2 ## is even.
Applying Goldbach's conjecture produces:
## 2n-2=p_{1}+p_{2} ## as a sum of two primes ## p_{1} ## and ## p_{2} ##.
Thus ## 2n=p_{1}+p_{2}+2 ## is a sum of three primes.
Case #2: Suppose ## a ## is odd.
Then ## a=2n+1 ## for ## n\geq 3 ##.
Note that ## a-3=2n-2=2(n-1) ##,
so ## a-3 ## is also even.
## a-3=p_{1}+p_{2} ## as a sum of two primes ## p_{1} ## and ## p_{2} ##.
Thus ## 2n+1=p_{1}+p_{2}+3 ## is a sum of three primes.
Therefore, the Goldbach conjecture that every even integer greater than ## 2 ## is the
Math100 said:
Homework Statement:: Prove that the Goldbach conjecture that every even integer greater than ## 2 ## is the sum of two primes is equivalent to the statement that every integer greater than ## 5 ## is the sum of three primes.
Relevant Equations:: None.
Proof:
You have shown that given Goldbach then every positive integer greater than five is a sum of three primes.
What is left to show is: If every integer ##n>5## can be written as ##n=p_1+p_2+p_3## the sum of three primes, then every even positive integer greater than two is the sum of two primes.
Equivalence means that one statement implies the other and the other way round.
(Forget about the greater than conditions. Just show it for integers great enough.)
Likes Prof B and Math100
Conversely, suppose every integer ## a>5 ## is the sum of three primes
such that ## a=p_{1}+p_{2}+p_{3} ##.
Let ## a>2 ## be an even integer.
Then ## a+2=2n+2 ## is even and ## a+2>5 ##.
Thus ## a+2=p_{1}+p_{2}+p_{3} ## is the sum of three primes ## p_{1}, p_{2} ## and ## p_{3} ##.
Since ## a+2 ## is even,
it follows that at least one of ## p_{1}, p_{2} ## and ## p_{3} ## must be ## 2 ##.
Without loss of generality, assume ## p_{3}=2 ##.
Then ## a+2=p_{1}+p_{2}+2 ##.
Thus ## a=p_{1}+p_{2} ## is a sum of two primes.
Likes Prof B and fresh_42
Looks good.
Thank you.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
