Every positive real number has a unique positive n'th root
I'm not really using a textbook but the syllabus from my brother. It's called Analysis 1 and it's in Dutch. I'll send you a link in PM.I don't read Dutch, but I'll try to find what you need to know. Can you read English? I don't read Dutch, but I'll try to find what you need to know. Can you read English?Yes I can read English.Yes I can read English.Ok, let me put this in a much more direct way. You can prove uniqueness for the positive root ##x^2 = a## without any analysis, right? You do that by showing that if ##x^2 = a## and ##y^2 = a
member 587159
Show, using the axiom of completeness of ##\mathbb{R}##, that every positive real number has a unique n'th root that is a positive real number.
Or in symbols:
##n \in \mathbb{N_0}, a \in \mathbb{R^{+}} \Rightarrow \exists! x \in \mathbb{R^{+}}: x^n = a##
Axiom of completeness:
Suppose ##I_n = [x_n,y_n]## is a sequence of closed intervals and they are nested such that:
##I_1 \supset I_2 \supset \dots \ I_n \dots##.
Then, there exists at least one number x, for which:
##x \in \bigcap\limits_{n=0}^{\infty} I_n##
[/B]
My textbook says that I can prove it as an application of the axiom of completeness. But it doesn't ask to proof this as an exercise, so I'm not sure whether I have covered enough to proof this problem.
So, I thought of a proof by contradiction. So, suppose that there are ##2## different numbers ##y,z \in \mathbb{R}##, for which: ##y^n = a## and ##z^n = a##. Then I wanted to take them as bounds in ##[x_n, y_n]##, and somehow show that this interval only contains 1 element, but it seems that that's not the correct approach. Any hints in the right direction will be appreciated.
Math_QED said:
[/B]
The axiom of completeness is required for existence of an nth root. I would use the existence of ##sup## and ##inf## for any set.
For uniqueness, you could show that ##x < y \ \Rightarrow x^2 < y^2## and hence ##x^n < y^n##.
Likes member 587159
Sup and inf are defined later in the book so I was right that I did not cover enough yet. I will come back later to this thread. Thanks!
You don't need to know about sup and inf to do it; using your completeness property is enough.
You are trying to show the existence of a root of the equation ##y^n = x##, so you can just apply the so-called bisecting search method to do it. See, eg., https://en.wikipedia.org/wiki/Bisection_method
or http://www.sosmath.com/calculus/limcon/limcon07/limcon07.html . All you need to get started is the existence of a number ##b > 0## such that ##b^n > x##.
I'm sorry but the proof for that method seems to require some analysis (continuous function etc) and at this point I'm not allowed to use that.
The idea is that there are, for example, rationals to any number of decimal places, ##k##, such that:
##r_1^n \le x \le r_2^n##
And ##r_2 - r_1 = 10^{-k}##
You start with integers and add decimal places etc.
Likes fresh_42
The absolute easiest proof is by using the intermediate value theorem (which is equivalent to completeness) on the function ##f(x) = x^n - a##. But ok, you want to prove it from scratch without using any further analysis. Perhaps you could tell us what textbook you are using, because I don't know what properties you get to accept as true and which not.
Are you worried that you cannot use the so-called "intermediate-value theorem"? Well, you do not need it.
You have ##a_1 \leq a_2 \leq a_3 \leq \cdots \leq b_3 \leq b_2 \leq b_1##, with ##b_k - a_k = b_0 2^{-k}##. Completeness gives
$$ \bigcap_{j=1}^{\infty} [a_k, b_k] = y \in \mathbb{R}.$$
What can you say about the value of ##y^n##, using only properties like ##y_1 < y_2 \Rightarrow y_1^n < y_2^n##, etc.?
Likes member 587159
Related to Every positive real number has a unique positive n'th root
1. How do you define the n'th root of a positive real number?
The n'th root of a positive real number is the number that when multiplied by itself n times, results in the original number. It is denoted by the symbol √n and is also known as the n'th root.
2. Is the n'th root of a positive real number always a positive number?
Yes, the n'th root of a positive real number is always a positive number. This is because the n'th root is defined as a number that, when multiplied by itself n times, results in the positive real number. Therefore, the n'th root must also be a positive number.
3. Can a positive real number have multiple n'th roots?
No, a positive real number has only one n'th root. This is because the n'th root is a unique number that satisfies the definition of the n'th root. If there were multiple n'th roots for a positive real number, it would contradict the definition of the n'th root.
4. How can the n'th root of a positive real number be calculated?
The n'th root of a positive real number can be calculated using the following formula: √n = x1/n, where x is the positive real number and n is the root number. For example, the square root (n=2) of 9 (x=9) can be calculated as √2 = 91/2 = 3.
5. What is the significance of the statement "every positive real number has a unique positive n'th root"?
This statement highlights the fact that every positive real number has a specific number that, when multiplied by itself a certain number of times, will result in the original number. It also emphasizes that this n'th root is a unique number and cannot be replaced by any other number. This concept is fundamental in mathematics and has various applications in fields such as algebra, calculus, and geometry.
  • Linear and Abstract Algebra
