Every sequence has a convergent subsequence?
In summary, the conversation discusses the possibility of finding a convergent subsequence in any sequence, including finite and infinite sequences. The definition of "converge" is referenced and it is noted that a finite sequence may not have a convergent subsequence. The example of {1,2,3,...} is given as a subspace of the Reals and its compactness is discussed.
CoachBryan
I'm not sure if this is true or not. but from what I can gather, If the set of Natural numbers (divergent sequence) {1, 2, 3, 4, 5,...} is broken up to say {1}, is this a subsequence that converges and therefore this statement is true?
You are wondering if it is always possible to find at least one convergent subsequence in any sequence however divergent?
Your specific question amounts to whether a sequence with a finite number of elements is convergent.
To answer that, check the definition of "converge".
Where does the question come up?
Likes CoachBryan
if it's possible to find at least one convergent subsequence in ANY sequence.
Definition of converge: "A sequence {a(n)} converges to a real number A iff for each epsilon>0 there is a positive integer N such that for all n >= N we have |a(n) - A| < epsilon."
Hey, thanks a lot. Now i understand it.
Only a bounded sequence has a convergent subsequence. An unbounded one, like 1,2, 3, 4...may not.
Does {1,2,3,..,n,.. } , i.e., a_n:=n have a convergent subsequence? Of course, this depends on your topology, but, as
a subspace of the Reals, does this have a convergent subsequence? This is one of the characterization of compact metric spaces, as every sequence having a convergent subsequence. And, in the subspace topology of the Reals,
{1,2,3,...} is/not compact (find a cover by open sets so that each contains a single number).
Related to Every sequence has a convergent subsequence?
1. What does it mean for a sequence to have a convergent subsequence?
A sequence has a convergent subsequence if there is a subsequence of the original sequence that approaches a finite limit as the number of terms in the subsequence increases.
2. How can you determine if a sequence has a convergent subsequence?
There are a few methods for determining if a sequence has a convergent subsequence, including the Monotone Convergence Theorem, the Bolzano-Weierstrass Theorem, and the Cauchy Convergence Criterion.
3. What is the significance of a sequence having a convergent subsequence?
A sequence having a convergent subsequence implies that the sequence itself also has a limit, and the limit of the subsequence is equal to the limit of the original sequence. This is a useful property in many mathematical and scientific applications.
4. Can a sequence have more than one convergent subsequence?
Yes, a sequence can have multiple convergent subsequences. This is because there can be multiple subsequences that approach different limits, as long as each subsequence approaches a finite limit.
5. Is it possible for a sequence to have a convergent subsequence if the sequence itself does not converge?
Yes, this is possible. A sequence may have a convergent subsequence even if the sequence itself does not converge. This is because the subsequence may approach a finite limit while the original sequence oscillates or diverges.
