- #36
- 37,181
- 14,025
Maxwell's equations are not the only Lorentz-invariant field equations. They are the classical limit for low field strength.
Sure but they have some relevance in their quantum form for QED. What other equations are you thinking of that are relevant here?mfb said:Maxwell's equations are not the only Lorentz-invariant field equations.
But that's like saying Lorentz-invariance is only important for the theory at low field strength. Is this what you mean?They are the classical limit for low field strength.
Yes, they are the classical limit of QED for low field strength, as I said already. See the discussion in the first few posts for classical limits which include light-by-light scattering.RockyMarciano said:Sure but they have some relevance in their quantum form for QED.
No, and I have no idea how you got that idea.RockyMarciano said:But that's like saying Lorentz-invariance is only important for the theory at low field strength.
Ok. Here is my reasoning, it seems to me that given that we are talking about a global anomaly that appears also non-perturbatively(the measure of the path integral cannot be defined globally, the symmetry in the classical action is not a symmetry of the integral measure), using the perturbative heuristic of classical limit only at zero loop(low field strength) is not so convincing, because non-perturbatively the idea is that there is no classical electrodynamics limit, period.mfb said:Yes, they are the classical limit of QED for low field strength, as I said already. See the discussion in the first few posts for classical limits which include light-by-light scattering.
RockyMarciano said:And I don't know how to recover the global symmetries of the theory without the classical limit, so how is this sorted out in practice?
I guess you actually meant something else when you wrote about particles "not really colliding"(what were particles doing in the LEP collider if not colliding?) ;) But yes with elementary particles the results are in a sense "cleaner" and therefore "clearer", the issue here is more to do with energy(lighter particles means less energy in the collisions) and that's why the results have been first obtained in the hadron collider.DrDu said:Shouldn't this effect be even clearer when elementary particles are used instead of nuclei, e.g. in electron electron scattering, as electrons, being point particles, cannot really collide with each other?
Personally, I have problems to talk of a collision of point particles like electrons but not to imagine a collision of extended objects as nuclei. But maybe this is a question of definition.RockyMarciano said:I guess you actually meant something else when you wrote about particles "not really colliding"(what were particles doing in the LEP collider if not colliding?) ;) But yes with elementary particles the results are in a sense "cleaner" and therefore "clearer", the issue here is more to do with energy(lighter particles means less energy in the collisions) and that's why the results have been first obtained in the hadron collider.
Here you are saying the opposite of what Vanadium wrote in #6 and #10atyy said:Maxwell's equations are the classical limit of QED
And here you are doing the same with mfb.- not just at low energies -
I've mentioned the fact that the effect is predicted at first loop already in my first post so I don't know how that answers anything. Did you read that this can be analysed non-perturbatevely?the light by light scattering appears at one loop (see my discussion with Vanadium 50 about the same point you are raising, and his answer in post #13).
Discussing this would take us far into a philosophical debate of what a particle is and what it means to collide for objects without classical properties, etc..DrDu said:Personally, I have problems to talk of a collision of point particles like electrons but not to imagine a collision of extended objects as nuclei. But maybe this is a question of definition.
RockyMarciano said:Here you are saying the opposite of what Vanadium wrote in #6 and #10
I suppose you are simply using a different definition of classical limit from mine (and apparently from Vanadium's and mfb's), you seem to be referring to the possibility of recovering the classical result(this is the definition in wikipedia), in this case at the tree level, that is of course a necessary condition for a theory in terms of consistency, the problem is that in quantum theory (as described for example in the first pages of Landau/Lifshitz vol.3) this recovery also implies dependency of the classical theory, which is a bad thing for a theory that tries to generalize classical mechanics.atyy said:Yes, I don't think what they said is correct if one uses the usual definition of classical limit. I believe Vanadium 50 agrees (ie. he agrees that LbyL is a quantum effect obtained at one loop, not an effect that can be obtained in the classical limit of QED), I'm not sure why mfb put in the restriction to low energies.
That alone is not sufficient. The analysis uses 480/µb at 5 TeV nucleus-nucleus cms energy. Scaling it to proton-proton, we get the same events in 20/fb pp collisions at the same energy. We had more than that at a higher energy in run 1 (2011+2012) already.Vanadium 50 said:This is a non-linear effect, so it goes as Q^4. 82^4 is 45 million. That's a heck of a head start.
