Evidence of photon existence and Blackbody Radiation
In summary, the blackbody radiation proves the existence of photons or quanta as Planck described it by showing that a quantized theory of the electromagnetic field can remove the unphysical divergence in the power spectrum of blackbody radiation. This does not mean it proves the existence of photon or field quantization, but it does support quantum theory and other established physical theories by corroborating them with experiments. Planck never assumed the existence of photons, and his derivation was based on boundary conditions for standing waves, which lead to discrete values of energy for each mode. However, this does not necessarily mean that all quantities of energy are restricted, as demonstrated by the blackbody radiation.
Entanglement
439
How does the blackbody radiation prove the existence of photons or quanta as Planck described it, I've understood how the photoelectric effect proves the existence of photons, but the blackbody radiation seems quite vague to me. I would like a basic explanation for this, thanks in advance.
Science news on Phys.org
A classical theory of the electromagnetic field would lead to an unphysical divergence in the power spectrum of the blackbody radiation. A quantized theory of the electromagnetic field is sufficient in removing the divergence. This does not mean it proves the existence of photon of field quantization; what it does, as with any other aspect of quantum theory or established physical theories in general, is corroborate theory with experiment.
Nugatory said:
Give this thread a read https://www.physicsforums.com/showthread.php?t=758363 and come back with any further questions.
Thanks a lot, I appreciate your help
What I understand is that classical equations assume that blackbodies emit radiation at at all frequencies and the radiation intensity is infinite at very high frequencies, but Planck assumed that light must be quantized to explain the actual distribution of the blackbody radiation which reaches a Max intensity at a certain frequency then it approaches zero at higher frequencies, I still have a problem understanding how Planck's assumption explained it.
Planck never assume any photons.
This is an Einstein's idea, used for photoefect (a simplified version only).
The black body radiation is just a sum over all possible wavelengths in the box.
There is a simple boundary condition for the standing waves, which gives the quantisation, not any energy corpuscles - the photons, are necessary, nor possible.
Informally... If light can only be emitted in quantized packets, then if there's not enough energy concentrated in one area of the object to create a packet of light at a given frequency then nothing at that frequency will be emitted. The higher the frequency of the light the more energy is needed, and the hotter the object the more energy is likely to be concentrated in one area. Combine these two results and you conclude (after some fairly huge oversimplifying of stuff discussed in that other thread) that for any temperature there are frequencies high enough that they're unlikely to be emitted; and that the hotter the object the higher the frequencies that will be emitted can be.
WannabeNewton said:
...A quantized theory of the electromagnetic field is sufficient in removing the divergence.
It should be said that quantum theory of thermal EM radiation (I believe due to Debye) leads to a divergent spectral function too:
\rho(\nu) = \frac{8\pi \nu^2}{c^3}\left(\frac{h\nu}{e^{h\nu / (k_B T)}-1} + \frac{h\nu}{2} \right)
The divergent term ##h\nu/2## in the braces is the lowest energy eigenvalue of a quantum harmonic oscillator. This due to the presence of the so-called zero-point fluctuations of the field. The corresponding contribution to the spectral function diverges even more rapidly than the Rayleigh - Jeans function. It is usually removed by hand. The rest then gives the Planck function and resembles measurements very well.
ElmorshedyDr said:
... I still have a problem understanding how Planck's assumption explained it.
Textbooks do not explain how Planck did it - as a matter of fact he derived his spectral function in a different way from the way that is most often taught today. For his approach, read his papers
http://www.ffn.ub.es/luisnavarro/nuevo_maletin/Planck (1900), Improvement of Wien's.pdf
http://www.ffn.ub.es/luisnavarro/nuevo_maletin/Planck (1900), Distribution Law.pdf
and for more details, his book
M. Planck, The theory of heat radiation, P. BLAKISTON'S SON & Co. 1914
https://archive.org/details/theheatradiation00planrich
...There is a simple boundary condition for the standing waves, which gives the quantisation, not any energy corpuscles - the photons, are necessary, nor possible.
The boundary condition of standing waves is not that important to the derivation of the Rayleigh-Jeans or Planck formula. One can do the same derivation for any cuboid in vacuum - the walls do not need to be reflective at all.
Quantization does not refer to discrete indexing of modes, but to discrete values of energy of each mode. The latter does not follow from the boundary condition of standing waves.
The observed quantisation is always just a consequence of the boundary conditions,
and this applies to the atom, the Hall effect, flux quantisation in the superconductivity, tunneling effect, etc.; all the so-called quantum effects without exception.
Quantity of energy can be anything - there is no fundamental restriction,
which shows just a black body.
Let's keep our focus on the equilibrium heat radiation. You said that the boundary condition of standing waves leads to quantization. Please explain why do you think that.
In the common derivation of the equilibrium spectrum, energy of mode is supposed to have preferred values - multiples of ##h\nu##. So there is restriction in the calculation - values like ##1.3h\nu## are not allowed.
Do you mean Debye's model for specific heats? This is a semi-classical model (~1912). See
http://en.wikipedia.org/wiki/Debye_model
If you can quote the equation properly, can you please also provide your source? Then we can look for ourselves.
No, I mean straightforward application of quantum theory of harmonic oscillator to EM modes. See 19.2 in
L. Ballentine, Quantum mechanics - a modern development
This is standard... check the calculations in QM, for example the hydrogen atom, and you should find the cause - explanation of the quantisation.
with respect to an oscillator with fundamental frequency denoted as ##\nu## ...
Since you mentioned box, standing waves and boundary condition in relation to equilibrium radiation, I assumed you were talking about conditions imposed to EM waves inside a cavity: zero electric field along the walls. These boundary conditions do not imply any quantization of energy of EM modes.
But your second sentence above makes the impression that you're talking about boundary conditions imposed to Schroedinger's ##\psi## function instead. If you meant the latter, I agree that boundary conditions are an important part of the derivation of the discrete values ##(1/2)h\nu, (1+1/2)h\nu, (2+1/2)h\nu,...##
Correct. After all there is no quantisation visible in the black body radiation - it's continuous function.
The derivation uses explicitly the condition for the standing waves.
This is just the standing waves condition.
Is it related to Boltzmann distribution?
I think you need to relearn quantum mechanics. Your understanding of quantization is lacking. The boundary conditions gives a discrete set of oscillation modes true, but that's not what quantization is. Quantization is the fact that each mode will be occupied by an integer number of particles. In classical physics each mode may have any amount of energy.
This is probably just a misunderstanding. Apparently, parkner meant boundary conditions for the ##\psi## function of harmonic oscillator. These indeed play role in obtaining preferred values of energy ##(n+\frac{1}{2})h\nu##.
Is that related to Boltzmann distribution ?
Related to Evidence of photon existence and Blackbody Radiation
1. What is the evidence for the existence of photons?
The evidence for the existence of photons comes from various experiments, such as the photoelectric effect, Compton scattering, and the behavior of light in a double-slit experiment. These experiments have shown that light behaves as both a wave and a particle, and photons are the particles that make up electromagnetic radiation.
2. How does blackbody radiation support the existence of photons?
Blackbody radiation is the electromagnetic radiation emitted by a perfectly opaque and non-reflective object at a certain temperature. The distribution of this radiation follows a specific pattern, known as the Planck curve, which can only be explained by the existence of photons. This phenomenon provides further evidence for the particle nature of light and the existence of photons.
3. Can photons be detected directly?
No, photons cannot be detected directly as they have no mass or charge. However, their presence and behavior can be observed indirectly through various experiments, such as those mentioned above, which show the effects of photons on matter.
4. Do all objects emit blackbody radiation?
Yes, all objects emit blackbody radiation, regardless of their temperature. However, the amount and distribution of this radiation depend on the temperature and properties of the object. For example, a warmer object will emit more radiation at higher frequencies, while a cooler object will emit more radiation at lower frequencies.
5. What is the significance of evidence for photon existence and blackbody radiation?
The evidence for the existence of photons and blackbody radiation plays a crucial role in our understanding of the nature of light and the behavior of matter at the atomic and subatomic levels. It also has practical applications in various fields, such as optics, quantum mechanics, and astrophysics.
  • Thermodynamics
  • Astronomy and Astrophysics
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
