MHB Ewaz's question at Yahoo Answers regarding a Bernoulli Equation
The discussion revolves around solving the Bernoulli differential equation y' + xy = y². The solution involves transforming the equation by dividing through by y² and using the substitution v = y⁻¹, leading to a linear ordinary differential equation. An integrating factor, e^(-x²/2), is applied to facilitate solving the equation. The final result for y is expressed as y(x) = 1/[ -e^(x²/2) ∫ e^(-x²/2) dx]. This thorough approach highlights the steps necessary to arrive at the solution for the given differential equation.
MarkFL
MHB
Here is the question:
Solve this Differential Equations problem? (Bernoulli's)?
y' + xy = y2
answer should be
y = 1/[ -e^(x2/2) ∫ e^(-x2/2) dx]
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Ewaz,
We are given to solve:
$$\frac{dy}{dx}+xy=y^2$$
Dividing through by $$y^2$$ (observing we are losing the trivial solution $y\equiv0$) we obtain:
$$y^{-2}\frac{dy}{dx}+xy^{-1}=1$$
We want to use the substitution:
$$v=y^{-1}$$
Differentiating with respect to $x$, we then obtain:
$$\frac{dv}{dx}=-y^{-2}\frac{dy}{dx}$$
And so our ODE becomes:
$$\frac{dv}{dx}-xv=-1$$
This is a linear ODE, and thus computing our integrating factor, we obtain:
$$\mu(x)=e^{-\int x\,dx}=e^{-\frac{x^2}{2}}$$
Multiplying the ODE by this factor, we obtain:
$$e^{-\frac{x^2}{2}}\frac{dv}{dx}-xe^{-\frac{x^2}{2}}v=-e^{-\frac{x^2}{2}}$$
Observing that the left side is not the differentiation of a product, we obtain:
$$\frac{d}{dx}\left(e^{-\frac{x^2}{2}}v \right)=-e^{-\frac{x^2}{2}}$$
Integrating with respect to $x$, there results:
$$\int\,d\left(e^{-\frac{x^2}{2}}v \right)=-\int e^{-\frac{x^2}{2}}\,dx$$
$$e^{-\frac{x^2}{2}}v=-\int e^{-\frac{x^2}{2}}\,dx$$
Multiplying through by $$e^{\frac{x^2}{2}}$$, we obtain:
$$v=-e^{\frac{x^2}{2}}\int e^{-\frac{x^2}{2}}\,dx$$
Back-substituting for $v$, we have:
$$\frac{1}{y}=-e^{\frac{x^2}{2}}\int e^{-\frac{x^2}{2}}\,dx$$
Inverting both sides, we the find:
$$y(x)=\frac{1}{-e^{\frac{x^2}{2}}\int e^{-\frac{x^2}{2}}\,dx}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
