Ex2.7 Black holes, white dwarfs and neutron stars-Shapiro, Teukolsky
In summary: T=ge^{\frac{\mu-mc^2}{kT}}\frac{3^{3/2}}{2^{3/2}\pi^{1/2}\hbar^3}(mkT)^{2}(mkT)=ge^{\frac{\mu-mc^2}{kT}}\frac{3^{3/2}}{2^{3/2}\pi^{1/2}\hbar^3}(mkT)^{2}E_k=ge^{\frac{\mu-mc^2}{kT}}\frac{3^{3/2}}{2^{3/2}\pi^{1/2}\hbar^3}E
Vrbic
407
Show that from (*) that for a nonrelativistic Maxwell-Boltzmann gas,
[itex]n=g\bigg(\frac{nkT}{2\pi\hbar^2}\bigg)^{\frac{3}{2}}e^{\frac{\mu-mc^2}{kT}}[/itex]
[itex]P=nkT[/itex]
[itex]e=nmc^2+\frac{3}{2}nkT[/itex] [itex][/itex]
(*): [itex]f(E)=e^{\frac{\mu-E}{kT}}[/itex]
[itex]E=\sqrt{p^2c^2+m^2c^4}[/itex]
[itex]n=\frac{g}{h^3}\int f(E)d^3p[/itex]
(#) [itex]h=2\pi\hbar[/itex]
So I suppose that nonrelativistic mean [itex]E=mc^2[/itex], than [itex]n=\frac{g}{h^3}\int e^{\frac{\mu-mc^2}{kT}}4\pi p^2dp=ge^{\frac{\mu-mc^2}{kT}}\frac{4\pi}{3h^3}p_f^3[/itex]. [itex]E_k=mv^2/2=p^2/2m=3kT/2[/itex]=>[itex]p=\sqrt{3mkT}[/itex]. Employ this in previous [itex]n=ge^{\frac{\mu-mc^2}{kT}}\frac{4\pi}{3h^3}(3mkT)^{3/2}[/itex] due (#) [itex]n=ge^{\frac{\mu-mc^2}{kT}}\bigg(\frac{3^{1/3}mkT}{2^{2/3\pi^{4/3}}\hbar^3}\bigg)^{3/2}[/itex]. Do somebody see some mistake?
Thank you very much.
Hello there,
I see that you are trying to derive the Maxwell-Boltzmann distribution for a nonrelativistic gas from the given equation (*) and the equations for energy and number density. Your approach seems to be correct, but there are a few mistakes in your calculations.
Firstly, you have assumed that the mean energy of the particles is equal to their rest energy, which is mc^2. This is not true for a nonrelativistic gas, as the mean kinetic energy of the particles is given by E_k=mv^2/2=p^2/2m=3kT/2. This is because the particles in a nonrelativistic gas have a very low velocity compared to the speed of light, so their kinetic energy can be approximated by classical mechanics.
Secondly, when you substitute p=\sqrt{3mkT} in the expression for number density, you have forgotten to take the derivative of the exponential term with respect to p. It should be dp instead of p when you take the derivative.
Lastly, in your final expression for number density, you have made a mistake in the exponent. It should be (3mkT)^{3/2} instead of (3^{1/3}mkT)^{3/2}.
So, the correct expression for number density in terms of the given parameters is:
n=ge^{\frac{\mu-mc^2}{kT}}\bigg(\frac{3mkT}{2^{5/2}\pi^{1/2}\hbar^3}\bigg)^{3/2}
Now, to show that P=nkT, we can use the ideal gas law, which states that PV=nRT, where R is the gas constant. Since we are dealing with a nonrelativistic gas, we can use the classical expression for pressure, which is P=nkT. Therefore, we have:
P=nkT=ge^{\frac{\mu-mc^2}{kT}}\bigg(\frac{3mkT}{2^{5/2}\pi^{1/2}\hbar^3}\bigg)^{3/2}kT
=ge^{\frac{\mu-mc^2}{kT}}\frac{3^{3/2}}{2^{3/2}\pi^{1/2}\hbar^3}(mkT)^{3/
Related to Ex2.7 Black holes, white dwarfs and neutron stars-Shapiro, Teukolsky
1. What is the difference between a black hole, a white dwarf, and a neutron star?
A black hole is a region of spacetime where the gravitational pull is so strong that nothing, including light, can escape from it. A white dwarf is a small, dense star that has exhausted its nuclear fuel and collapsed under its own gravity. A neutron star is an even denser star made mostly of neutrons, formed from the collapsed core of a massive star.
2. How are black holes, white dwarfs, and neutron stars detected?
Black holes are detected through their effects on nearby matter, such as the emission of X-rays. White dwarfs are detected through their high surface temperatures and luminosities. Neutron stars are detected through their pulsations and strong magnetic fields.
3. Can black holes, white dwarfs, and neutron stars collide with other objects?
Yes, all three objects can collide with other objects. Black holes can collide with other black holes, white dwarfs, or neutron stars. White dwarfs can collide with other white dwarfs or neutron stars. Neutron stars can collide with other neutron stars or black holes.
4. What is the significance of studying black holes, white dwarfs, and neutron stars?
Studying these objects can help us understand the life cycle of stars, the behavior of matter under extreme conditions, and the nature of gravity. It can also give us insights into the formation of galaxies and the evolution of the universe.
5. How do black holes, white dwarfs, and neutron stars affect their surroundings?
Black holes can distort the fabric of spacetime and influence the orbits of nearby objects. White dwarfs can have strong magnetic fields and emit intense radiation. Neutron stars can also have strong magnetic fields and emit radiation, as well as influence the motion of nearby objects through their gravity.
