B Exact differential and work done
The discussion focuses on the relationship between conservative forces and exact differentials in the context of work done. It explains that if the infinitesimal work 𝐹⃗ β‹…π‘‘π‘Ÿβƒ— is an exact differential, the work is independent of the path taken, indicating that the force is conservative. An example involving gravity illustrates that the total work done is the same regardless of the path, confirming gravity as a conservative force. In contrast, friction is shown to be non-conservative as the total work varies with the path. Understanding exact differentials is essential for grasping why conservative forces exhibit this property.
putongren
TL;DR Summary
The work done is independent of path if the infinitesimal work 𝐹⃗ β‹…π‘‘π‘Ÿβƒ—
is an exact differential.
I was researching about conservative and non-conservative forces, and there is some information in a website that sates that the work done is independent of path if the infinitesimal work 𝐹⃗ β‹…π‘‘π‘Ÿβƒ— is an exact differential. It further states that in 2 dimensions the condition for 𝐹⃗ β‹…π‘‘π‘Ÿβƒ— = Fxdx + Fydy to be an exact differential is:
𝑑𝐹π‘₯/𝑑𝑦=𝑑𝐹𝑦/𝑑π‘₯.
My question is this: why is a force conservative if the work is an exact differential? How can we deduce from the definition of a conservative force that this force is conservative if the work done to it is an exact differential?
Because if you integrate an exact differential, the result is the difference of some function evaluated at the two limits. This is what "work is independent of the path" means.
Here is an example. Suppose you use an eraser to erase a chalkboard. To do that you push the eraser against the board and, starting at the bottom B, you go to the middle M, then to the top T and then back to M. Let ##h=~##the height of the board.
The work done by the force of gravity ##mg## is
From B to M: ##~W_{BM}=-mg*\dfrac{h}{2}.##
From M to T: ##~W_{MT}=-mg*\dfrac{h}{2}.##
From T to back to M: ##~W_{TM}=+mg*\dfrac{h}{2}.##
Note that ##W_{BM}+W_{MT}+W_{TM}=W_{BM}.## This says that the total work is independent of the path because it is the same when one stops at M or goes past M to T and then back to M. We conclude that the force of gravity is conservative.
The work done by the force of friction ##f## is
From B to M: ##~W_{BM}=-f*\dfrac{h}{2}.##
From M to T: ##~W_{MT}=-f*\dfrac{h}{2}.##
From T to back to M: ##~W_{TM}=-f*\dfrac{h}{2}.##
Note that ##W_{BM}+W_{MT}+W_{TM}=3W_{BM}.## This says that the total work is not independent of the path because it is not the same when one stops at M or goes past M to T and then back to M. We conclude that the force of gravity friction is not conservative.
Note that ##W_{BM}+W_{MT}+W_{TM}=3W_{BM}.## This says that the total work is not independent of the path because it is not the same when one stops at M or goes past M to T and then back to M. We conclude that the force of *gravity* is not conservative.
I believe you meant friction. Besides that, great explanation.
Likes berkeman and kuruman
Good catch, thanks. I cut and pasted from above without changing the force. I edited to fix the typo.
Likes berkeman and Juanda
Sorry, I assumed you already knew what an exact differential is.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
