- #36
PeterDonis
Mentor
- 46,628
- 23,185
zoki85 said:Do you mean here "applies to anything massless ..."
Yes, that's what "anything traveling on null worldlines" means.
roineust said:As much as i search Google, in an effort to find out how exactly the constancy of speed of light was historically deduced before 1905, from Maxwell equations or by any other means, i am not able to find such an explanation. In all of the search results that i could find, it is just stated that it was deduced from Maxwell equations and does not detail exactly how.
By using the term 'constancy' i mean that the speed of light is not changed for any observer, no matter the relative speed of a light emitting object.
If there is a difference between the 'constancy' of the speed of light and the 'invariance' of the speed of light, please add this also to the explanation.
What i am trying to understand is the exact way in which the constancy (or/and the invariance) of the speed of light was deduced before 1905, not how the exact number of 299,792,458 m/s was deduced before 1905, but if possible, please also add an exact explanation to how this number itself was deduced before 1905.
That's not a deduction. It is an experiment whose outcome was inconsistent with the deductions of the physicists who conceived of the experiment. Maxwell's equations interpreted in a way differently than physicists used at the time could have led to such a deduction but @PeterDonis explained why this did not occur.Sooty said:'Never use one word if you can get away with ten!' seems to be central to most of the 'answers' to questions you didn't even ask! :D
OK - your question - 'The exact way in which the constancy (or/and the invariance) of the speed of light was deduced before 1905?'...
So, unless I've got it wrong too, maybe try - https://simple.wikipedia.org/wiki/Michelson–Morley_experiment
PAllen said:So far as I know, no one before 1905 deduced the invariance of lightspeed
roineust said:the invariance of the Lorentz frames of reference, as a logic entity, is one that can never be deduced
roineust said:but can be falsified
PeterDonis said:Indeed it could, but it hasn't;
roineust said:if it is a logical entity that can never be deduced, isn't that a problem?
PeterDonis said:It's assumed as an axiom. You have to assume some things as axioms in order to construct a mathematical model in physics at all.
roineust said:f this non-deducible Lorentz type of science different from a type of science, that finds out proportionality in experiments and then deduces (correct term here?) the equations from proportionality?
PeterDonis said:Read this again:
Do you understand what that means?
PeterDonis said:You can't deduce equations from experimental data alone. The experimental data is always consistent with multiple different possible equations--in fact, strictly speaking, with an infinite number of them. You have to bring in other assumptions to narrow down the equations you are going to consider.
roineust said:if there is not also other types of science, that do not need new axioms but only build upon known ones (the proportionality thing?)
roineust said:i would ask you if possible, to give more examples of a physics theories besides SR and GR, that decided to add a new axiom that were not used before them, in order to create a new equation.
PeterDonis said:There is only one type of science: the type that builds mathematical models and tests their predictions against the results of experiments. If the predictions match the results, the models are accepted (at least until further results come in, when they have to be evaluated again). If the predictions don't match the results, the models are falsified and scientists have to go back to the drawing board to try to build different ones.
As far as how you build the mathematical models, see below.
Every single scientific theory that has ever existed has done this.
If you have all the same axioms as before, you have the same mathematical model as before. But if you are trying to build a new mathematical model, it must be because the old one made wrong predictions and was falsified. So obviously you can't use the same axioms as the old one did, because you would then just have the old model and it would make the same falsified predictions. You have to pick at least one different axiom to get a different model that makes different predictions.
roineust said:did every scientific theory before that also say what i interpret SR 1st postulate to say: "And this axiom is true also for any other existing scientific theory (axiom?)"?
roineust said:Isn't that a different type of axiom than any other axiom used before?
