Exact inversion of matrix complexity (by Gaussian elimination)
In summary, the conversation discussed an algorithm using Gaussian elimination to find the inverse of a non-singular matrix. The operation counts for this algorithm were calculated to be $4n^3/3 + 5n^2 - 7n/3$ for multiplication, division, addition, and subtraction. It is important to double check the calculations and consider the worst-case scenario when using this algorithm.
kalish1
99
I would like to check if what I have done is correct. Please, any input is appreciated.
**Problem statement:** Consider a non-singular matrix $A_{nxn}$. Construct an algorithm using Gaussian elimination to find $A^{-1}$. Provide the operation counts for this algorithm.
**My attempted algorithm and operations count:**
Let $[A|I]$ be an augmented $n$ x $2n$ matrix.
INPUT: number of unknowns and equations n, augmented matrix
OUTPUT: $A^{-1}$, provided that the inverse exists
STEP 1: For $i=1,\dots,n-1$ do STEPS 2-4
STEP 2: Let $p$ be the smallest integer with $i \leq p \leq n$ such that $a_{pi} \neq 0$. If no integer $p$ exists then output ('no unique solution exists'); STOP
STEP 3: If $p \neq i$ then perform $E_p \leftrightarrow E_i$
STEP 4: For $j=i+1, \dots, n$ do STEPS 5-6
STEP 5: Set $m_{ji}=a_{ji}/a_{ii}$.
STEP 6: Perform $(E_j - m_{ji}E_i) \rightarrow (E_j)$
STEP 7: If $a_{nn}=0$ then output NO UNIQUE SOLUTION EXISTS and STOP
STEP 8: For $i=n-1,n-2,\dots ,1$,
For $j=i+1,i,\dots ,1$ do STEPS 9 and 10
STEP 9: Set $m_{ij}=a_{ij}/a_{jj}$
STEP 10: Perform $(E_i - m_{ij}E_j) \rightarrow (E_i)$
STEP 11: for i=1, ldots, n, do $E_i/a_{ii} \rightarrow E_i$
STEP 12: OUTPUT $A^{-1}$ and STOP.
**I am getting the operations count as follows:** A total of $(2n^3+9n^2+n)/3$ multiplications and divisions and a total of $(2n^3+6n^2-8n)/3$ additions and subtractions for a grand total of $4n^3/3 + 5n^2 - 7n/3$ operations. **Does this sound about right?**
Thanks for any help.
Mathematics news on Phys.org
Hello,
Your algorithm looks correct and the operation count seems to be correct as well. However, there are a few things to consider:
1. The operation counts for Gaussian elimination can vary depending on the implementation and the specific matrix. So, it is always a good idea to double check your calculations and algorithm for different matrices.
2. The operation counts you have provided seem to be assuming that the inverse exists. If the inverse does not exist, then the algorithm would require additional operations to check for this and output the necessary message.
3. It is also important to note that the operation counts for Gaussian elimination are typically given in terms of Big O notation, which represents the worst-case scenario. So, your operation counts may vary for different matrices.
Overall, your algorithm and operation counts seem to be correct. I hope this helps and good luck with your research.
FAQ: Exact inversion of matrix complexity (by Gaussian elimination)
1. What is the complexity of exact inversion of a matrix using Gaussian elimination?
The complexity of exact inversion of a matrix using Gaussian elimination is O(n^3), where n is the size of the matrix. This means that the time it takes to invert a matrix using this method increases rapidly as the size of the matrix increases.
2. Is Gaussian elimination the most efficient method for exact inversion of a matrix?
No, there are other methods such as LU decomposition and Cholesky decomposition that can be more efficient for certain types of matrices. It is important to consider the structure and properties of the matrix before deciding on the best method for inversion.
3. Can Gaussian elimination be used for non-square matrices?
No, Gaussian elimination can only be used for square matrices. For non-square matrices, other methods such as the pseudo-inverse or singular value decomposition (SVD) can be used for exact inversion.
4. Are there any limitations to using Gaussian elimination for exact inversion?
Yes, Gaussian elimination can lead to numerical instabilities and inaccuracies when the matrix is ill-conditioned or nearly singular. In these cases, other methods may be more suitable for exact inversion.
5. Is there a trade-off between accuracy and complexity when using Gaussian elimination for exact inversion?
Yes, Gaussian elimination is a relatively simple and straightforward method for exact inversion, but it may sacrifice some accuracy compared to more complex methods. However, for well-conditioned matrices, the accuracy may not differ significantly between methods.
