MHB Exact Sequences - Dummit and Foote Ch 10 - Proposition 28
  • Thread starter Thread starter Math Amateur
    Sequences
The discussion focuses on understanding the proof of Proposition 28 from Dummit and Foote regarding exact sequences of modules. The key point is that taking D = R allows for the application of the isomorphism Hom_R(R, X) ≅ X, which simplifies the proof of the exactness of the sequence 0 → L → M → N. This approach highlights that the derived properties of the hom-sets reflect the original exact sequence. The clarification emphasizes that while R is a ring, it can also be viewed as a module over itself, making this case not just a special instance but an integral part of the general theory. The participants conclude that this insight resolves their confusion about the proof's logic.
Math Amateur
MHB
I am reading Dummit and Foote, Section 10.5 : Exact Sequences - Projective, Injective and Flat Modules.
I am studying Proposition 28 (D&F pages 387 - 388)
I need some help in order to fully understand the proof of the last statement of Proposition 28.
Proposition 28 (Ch 10, D&F pages 387-388) reads as follows:
View attachment 2487The proof of the last statement of the proposition reads as follows:View attachment 2488
In the proof, after the statement:
"In general, $$ Hom_R (R, X) \cong X $$, the isomorphism being given by mapping a homomorphism to its value on the element $$1 \in R $$"
D&F write:
Taking D = R in (10), the exactness of the sequence:
$$ 0 \longrightarrow L \stackrel{\psi}{\longrightarrow} M \stackrel{\psi}{\longrightarrow} N $$
follows easily.
Can someone please explain how/why this follows easily? ... ... ... that is how/why does taking D=R in (10) lead easily to the result that the sequence $$ 0 \longrightarrow L \stackrel{\psi}{\longrightarrow} M \stackrel{\psi}{\longrightarrow} N $$ is exact?Further, it seems strange to me that in an exact sequence of modules we are putting D = R where (I assume) R is a ring. (Yes, I understand that a ring can be viewed as a module over itself, but it seems it is a special case, which we are using to establish a general result?) Can someone please clarify this issue?Hope someone can help.
Peter
If we assume that:
$0 \to \text{Hom}_R(D,L) \stackrel{\psi'}{\to} \text{Hom}_R(D,M) \stackrel{\phi'}{\to} \text{Hom}_R(D,N)$
for ANY $D$ is exact, then taking $D=R$ and using the fact that $\text{Hom}_R(R,X) \cong X$ for $X = L,M,N$
makes this obvious.
Let's put this in context. If we start with the exact sequence of modules, we can form (for any particular module $D$) the sequence of hom-sets. The sequence of hom-sets has DERIVED properties from the original sequence.
Now, we get a LOT of sequences from this (one for every different $D$). The "special case" $D = R$ picks out a particular sequence that mimics our original sequence in every detail.
In other words, to make the "return" trip of a one-to-many correspondence, we ought to pick a "special" (distinguished) element in the image.
Deveno said:
If we assume that:
makes this obvious.
Oh ... neat ... yes, solution was staring at me! ...
Thanks so much for the help ...
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
