MHB Exact Sequences - Dummit and Foote Ch 10 - Proposition 29
  • Thread starter Thread starter Math Amateur
    Sequences
The discussion centers on understanding Proposition 29 from Dummit and Foote regarding exact sequences and the mapping between homomorphism sets. The user seeks clarification on how the defined maps lead to a homomorphism from Hom_R(D, L ⊕ N) to Hom_R(D, L) ⊕ Hom_R(D, N). A proposed mapping F is presented, where F(f) = (π₁ ∘ f, π₂ ∘ f), and the user is working through the proof that F is indeed a homomorphism. The conversation also touches on categorical language and the importance of understanding functors in this context. Overall, the thread emphasizes the need for explicit justification of certain steps in the proof process.
Math Amateur
MHB
I am reading Dummit and Foote, Section 10.5 : Exact Sequences - Projective, Injective and Flat Modules.
I am studying Proposition 29 (D&F, page 388)
I need some help in order to fully understand the proof of the last statement of Proposition 29.
Proposition 29 and its proof (Ch 10, D&F page 388) reads as follows:
As can be seen above, in the proof, D&F define $$ \pi_1 \pi_2, f, \pi_1 \circ f text{ and } \pi_2 \circ f $$ and then state the following:
"This defines a map from $$ Hom_R (D, L \oplus N) $$ to $$ Hom_R ( D, L ) \oplus Hom_R ( D, N )$$ which is easily seen to be a homomorphism.
Can someone please help me to see explicitly and formally how the definitions of MATH] \pi_1 \pi_2, f, \pi_1 \circ f text{ and } \pi_2 \circ f $$ lead to such a map and also help me to determine an explicit expression/formala for this homomorphism?
Hope someone can help.
Peter
Peter
I have reflected on my post above and believe I have a (tentative) idea of the map referred to be D&F:
I believe one should proceed as follows:
Let $$ \pi_1 : \ L \oplus N \to L $$ where $$ \pi_1 ( ( l_1, n_1)) = l_1 $$
and let $$ \pi_2 : \ L \oplus N \to N $$ where $$ \pi_2 ( ( l_1, n_1)) = n_1 $$
Now let $$ f : \ D \to L \oplus N $$ where $$ F(d) = ((l_1, n_1)) $$
Thus we have the following:
$$ \pi_1 \circ f : \ D \to L \text{ where } \pi_1( f (d) ) = \pi_1 ( ( l_1 , n_1) ) = l_1 $$
and
$$ \pi_2 \circ f : \ D \to L \text{ where } \pi_2( f (d) ) = \pi_2 ( ( l_1 , n_1) ) = n_1 $$
Now we can define what I believe to be the required homomorphism, as follows:
Let $$ F : \ Hom_R (D, L \oplus N) \to Hom_R ( D, L ) \oplus Hom_R ( D, N ) \text{ where } F(f) = ( \pi_1 \circ f , \pi_2 \circ f ) $$
Can someone please confirm that F is the required map?
Still have to show that $$F$$ is a homomorphism but I am slightly perplexed as to the details of this task.
To show $$F$$ is a module homomorphism, we must show that
$$ F(f + g) = F(f) + F(g) $$ where $$ f, g \in Hom_R (D, L \oplus N ) $$
and
$$F (rf) = rF(f)$$ for $$ r \in R $$
BUT ... how to do this?
Can someone please help?
Peter
In categorical language, we are saying we have a FUNCTOR:
$H: R-\mathbf{Mod} \to R-\mathbf{Mod}$
given on objects by:
$H(M) = \text{Hom}_R(D,M)$
and on arrows (maps), by:
for $\psi:M \to N, H(\psi) = \psi'$, where for any $f \in \text{Hom}_R(D,M)$ we have $\psi'(f) = \psi \circ f$.
This is often called "the pullback of $\psi$ by $f$" (allowing us to "modify" $\psi$ so its domain is now "pulled back" to $D$), and the functor $H$ is often called $\text{Hom}_R(D,-)$ (an example of a "hom-functor").
If you are going to be reading more on this subject in other texts, it might be wise to assimilate some of this language now. I note in passing that this type of construction lies at the heart of the "chain rule" that proves to be such a stumbling block for many first-year calculus students. You may find it enlightening to consider what changes if we have a common "target":
$M \to \text{Hom}_R(M,D)$
In any case, as with most "hom-functors", showing we have the requisite morphism properties is so "work-a-day" that the proofs are often entirely omitted. To start with, we assume an arbitrary $d \in D$. Then:
$F(f+g)(d) = [(\pi_1\circ(f+g))\times(\pi_2\circ(f+g))](d) = (\pi_1((f+g)(d)),\pi_2((f+g)(d)))$
$= (\pi_1(f(d)+g(d)),\pi_2(f(d)+g(d)) = (\pi_1(f(d)),\pi_2(f(d))) + (\pi_1(g(d)),\pi_2(g(d)))$
$= [(\pi_1 \circ f) \times (\pi_2 \circ f)](d) + [(\pi_1 \circ g) \times (p_2 \circ g)](d) = F(f)(d) + F(g)(d) = (F(f) + F(g))(d)$.
And, for any $r \in R$:
$F(rf)(d) = [(\pi_1 \circ (rf)) \times (pi_2 \circ (rf))](d) = (\pi_1((rf)(d)), \pi_2((rf)(d)))$
$= (pi_1(r(f(d))),\pi_2(r(f(d)))) = (r\pi_1(f(d)),r\pi_2(f(d))) = r(\pi_1(f(d)),\pi_2(f(d)))$
$= r[(\pi_1 \circ f) \times (\pi_2 \circ f)](d) = r(F(f(d)) = (rF)(f)(d)$.
Note that your $F$ is really just $\pi_1' \times \pi_2'$, where $\pi_1,\pi_2$ are the canonical projection homomorphisms, so in shorter language we are asserting:
$\pi_1' \times \pi_2' = (\pi_1 \times \pi_2)'$
Imagine diagrams between the (single) modules lying "flat" on a surface, with $D$ lying in space above them. Each diagram is then augmented with an arrow from $D$ down to the modules lying below. The commutative triangle diagrams (from the common source $D$) we obtain from each arrow on the flat surface can be "stitched together" (composed) by identifying "matching edges".
In particular, we can make the diagram corresponding to the two projection maps:
$L \leftarrow L \oplus N \rightarrow N$
and "pulling this back to $D$", gives us two "commutative triangles" which serve the same function in the hom-sets as the projection maps do on the modules. By the universal property of the product construction:
$\text{Hom}_R(D,L \oplus N) \cong \text{Hom}_R(D,L) \oplus \text{Hom}_R(D,N)$
Thanks so much for the help Deveno ... Just working through your post now ...
Peter
Thanks again for the help Deveno ...
Can you demonstrate explicitly why the following step in your reasoning is justified:
Would appreciate help regarding the reason why this step is valid.
Peter
Peter
Just been reflecting on my own question ... and believe I have seen the reason (which I have to say appears to be quite straightforward ...)
We have
$$= (\pi_1(f(d)+g(d)),\pi_2(f(d)+g(d)) = (\pi_1(f(d)) + \pi_1(g(d), \pi_2(f(d)) + \pi_2(g(d)))$$
$$ = (\pi_1(f(d)),\pi_2(f(d))) + (\pi_1(g(d)),\pi_2(g(d))) $$
since $$ (x_1 + x_2, y_1 + y_2) = (x_1, y_1) + (x_2, y_2) $$ by the definition of component-wise addition.
Can you confirm this is OK?
It is pretty simple and looks OK ... but just to be sure ...
Peter
That is correct.
