Dustinsfl
- 2,281
- 5
I am trying to understand this example:
Let H be the upper half plane. The map
f:z\mapsto\frac{z - i}{z + i}
is an isomorphism of H with the unit disc.
proof:
Let $w=f(z)$ and $z=x+yi$. Then
f(z) = \frac{x + (y-1)i}{x+(y+1)i}.
Since $z\in H$, $y>0$, it follows that $(y-1)^2<(y+1)^2$ whence
x^2+(y-1)^2=|z-i|^2<x^2+(y+1)^2=|z+i|^2
and therefore
|z-i|<|z+i|,
(I understand the above)
so $f$ maps the upper half plane into the unit disc (I don't understand why we can make this statement now? How does the above allow for this?). Since
w=\frac{z-i}{z+i},
we can solve for z in terms of w, because $wz+wi = z-i$, so that
z=-i\frac{w+1}{w-1}.
Write $w=u+iv$. By computing directly the real part of $(w+1)/(w-1)$, and so the imaginary part of
-i\frac{w+1}{w-1}
you will find that this imaginary part is > 0 if $|w| < 1$ (why is this?).
So I computed the imaginary part and obtained
-i\frac{(u+1)(u-1)+v^2}{(u-1)^2+v^2}
Hence the map
h:w\mapsto -i\frac{w+1}{w-1}
sends the unit disc into the upper half plane. Since by construction $f$ and $h$ are inverse to each other, it follows that they are inverse isomorphisms of the upper half plane and the disc.
proof:
and therefore
|z-i|<|z+i|,
w=\frac{z-i}{z+i},
-i\frac{w+1}{w-1}
Hence the map
