Example for a quantum anomaly from solid state phys?
In summary, the quantum Hall effect is a phenomenon in which the electrons in a material form a correlated system that is confined to a 2-dimensional plane. This system exhibits a (statistical) gauge field, which is a type of topological field theory. The CS-term in the action of the theory contains a gauge structure, which can be traced back to the conservation of charge. At the boundary of the system, performing a gauge transformation leaves the action invariant everywhere in the (2+1) dimensional spacetime, except at the boundary. The boundary, which is a (1+1) dimensional subspace, breaks the gauge invariance of the action and the theory is therefore anomalous at the boundary. Specifically, the gauge degrees
DrDu
979
In quantum field theory of high energy physics one encounters so called anomalies like e.g. of the kind discussed in this thread:
https://www.physicsforums.com/showthread.php?t=406540
As far as I understood, it basicallymeans that the classical theory has a higher symmetry than the qft. Does anybody know of an example from solid state physics?
One example I can think of is actually the emergence of new physics in order to cancel an anomaly.
In the quantum Hall effect the electrons form a strongly correlated system confined to a 2 dimensional plane and in the presence of a magnetic field aligned perpendicular to this plane. An important aspect of this system is the emergence of a (statistical) gauge field. In the fractional case this gauge field is described through a Chern-Simons term in the action, which is an example of a topological field theory.
The CS-term contains a gauge structure, which can be traced back to the conservation of charge. A gauge transformation leaves the action invariant everywhere in the (2+1) dimensional spacetime, except at the boundary of the system. The boundary, which is a (1+1) dimensional subspace, breaks the gauge invariance of the action and the theory is therefore anomalous at the boundary. Specifically, performing a gauge transformation gives back the original action, which is gauge invariant, plus a boundary term, which is not gauge invariant. The gauge degrees of freedom are "frozen in" at the boundary.
There are two ways to deal with this anomaly, which are actually just different viewpoints of the same resolution. The first is to limit the allowed gauge transformations, such that you only consider those transformations which leaves (the value of) the gauge field at the boundary intact. The second is to introduce a boundary term which transforms with respect to a gauge transformation in such way as to cancel the anomaly. In both cases you end up with a dynamical theory at the boundary. It's precisely this boundary term which describes the edge state of the quantum Hall effect. Since CS-theory breaks time invariance, this boundary term turns out to be chiral. In addition, due to the topological nature of the CS-theory this boundary term is also conformal. It's called a Wess Zumino Witten term. What you are dealing with is the existence of one-way moving edge states, which turn out to be the current-carrying states of the quantum Hall effect.
This is one of the main characterics of the quantum Hall effect from a field theoretic point of view: the emergence of a (2+1) dimensional Chern-Simons term which, by itself, is anomalous, accompanied by a (1+1) dimensional CFT (a WZW term) such that the overal anomaly is canceled again.
Very interesting! Do you have some reference where to look up the details?
Tried to look up a proper source which isn't too technical, but they are hard to find. For info on CS theory applied to the quantum Hall effect you may try this one:
http://arxiv.org/abs/cond-mat/9501022
But that source does not treat the edge states (or the anomaly I am talking about). For that you need to consult:
http://arxiv.org/abs/cond-mat/9506066
Specifically, chapter 3.3 explains in detail how you can derive the theory of the edge states using the Chern-Simons theory in the bulk combined with an anomaly cancellation (I do not know if it is called that way in this article)
A more general review article would be:
http://arxiv.org/abs/0707.1889
Although the part on the Chern-Simons theory and the description of the edge states is a lot more technical in this article.
These articles might be a bit heavy on the technical side if this is your first exposure to the quantum Hall effect.
Sorry for responding to this old question, but I think http://arxiv.org/abs/1010.0936" (click) paper is exactly what you are looking for. Many different kind of anomalies are applied in a condensed matter physics context, even gravitational anomalies.
Thank you! I'll give it a look.
Related to Example for a quantum anomaly from solid state phys?
1. What is a quantum anomaly in solid state physics?
A quantum anomaly in solid state physics refers to a phenomenon where the predictions of a quantum theory do not match with experimental observations. This can occur due to the breakdown of a fundamental symmetry in the system, leading to unusual behavior of particles and properties that cannot be explained by classical physics.
2. What is an example of a quantum anomaly in solid state physics?
An example of a quantum anomaly in solid state physics is the Quantum Hall Effect. This is a phenomenon where the transverse electrical resistance of a two-dimensional electron gas in a strong magnetic field shows quantized plateaus, despite the fact that the classical Hall effect would predict a continuous change in resistance.
3. How do quantum anomalies affect the behavior of materials?
Quantum anomalies can have significant effects on the behavior of materials, as they can cause unexpected properties and behaviors that do not follow classical laws. This can lead to the discovery of new materials and technologies, as well as a deeper understanding of the fundamental laws of physics.
4. Can quantum anomalies be observed in everyday materials?
Yes, quantum anomalies can be observed in everyday materials, although they may not always be noticeable. These anomalies typically occur in materials at extremely low temperatures or under high magnetic fields, making them difficult to observe in everyday conditions.
5. How do scientists study and understand quantum anomalies in solid state physics?
Scientists use a variety of experimental techniques, such as spectroscopy and microscopy, to study and understand quantum anomalies in solid state physics. They also use theoretical models and simulations to make predictions and explain the observed anomalies. Collaboration between experimental and theoretical physicists is crucial in advancing our understanding of quantum anomalies.
