Example of a factor space in physics
In summary, a factor space is a quotient space that is obtained by taking the equivalence class of vectors in a vector space and defining an addition rule for combining them. An example of a factor space from physics is the Fock Space, which models the indistinguishability of particles by taking quotients of tensor spaces. It can also be viewed as a Grassman algebra, where the quotient is used to enforce the Pauli principle.
Geofleur
177
Suppose ## V ## is a vector space and ## W ## is a subspace of ## V ##. Then for ## |a\rangle, |b\rangle \in V ##, say that ## |a\rangle ## and ## |b\rangle ## are equivalent (in the sense of an equivalence relation), if ## |a\rangle - |b\rangle \in W ##. Denote the equivalence class of ## |a\rangle ## by ## [\![ a ]\!] ##. The factor space (also called the quotient space) is defined via the underlying set ##\{ [\![ a ]\!] \; | \; | a\rangle \in V \} ## together with the addition rule ## \alpha [\![ a ]\!] + \beta [\![ b ]\!] = [\![ \alpha a + \beta b ]\!] ## for combining elements in this set, with ##\alpha ## and ##\beta## scalars of the original space ## V ##.
For an intuitive idea of the meaning of a factor space, let ## V = \mathbb{R}^2 ##, ## W ## be a line passing through the origin, and ## | v \rangle ## be a position vector originating from the origin. Then ## [\![ v ]\!] ## is the line obtained by shifting every point in ## W ## (regarded as a position vector) by ## |v\rangle ##. The factor space is the set of all lines that are parallel to ## W ##.
Does anyone know of a good example, from physics, of a factor space?
Likes tabassum proma
Do Lorentz groups count?
Likes Geofleur
The Fock Space is an important example of such a space, that occurs in quantum mechanics. It is obtained by taking quotients of tensor spaces. But tensor spaces are also vector spaces. The quotient is used to model the indistinguishability of particles.
Likes Geofleur
But where is the quotient there? Bosonic it's a tensor algebra and fermionic a Graßmann algebra. Graßmann algebras can be viewed as factor algebras. Is the Pauli principle basically the equivalence relation here? Can it be viewed this way?
As you note, there's a quotient taken in constructing the Grassman Algebra, which can model collections of fermions. I can't remember how it works for bosons. I thought there was a quotient taken in there as well but my memory is dim.
I wrote some good notes on this topic a few years ago but I went looking for them a couple of months ago and couldn't find them anywhere. It's most disconsoling. It all came out of a thread on here where I was ranting about the sloppiness with which most QM texts approach the issue of indistinguishable particles, whereby they just start breaking all the rules they've laid down in the previous chapters, without justification. Most posters said don't worry about it, it's just pedantry. But one helpful person pointed me in the direction of Fock spaces which, IIRC, led me on a most satisfying journey through Wedge Products and Symmetric and Antisymmetric Algebras. I think I go to the point where I decided the universe is - GR and string theory aside - just one enormous Fock Space.
I'll see if I can dig up the thread (and, if possible, the notes). Anything further I say without consulting my notes or recreating them from scratch is likely to be wrong.
@andrew: Thank you. Your remark on the universe remembers me on the SUSYs. First their gauge groups got larger and larger, next they graded, i.e. doubled their playground. As long as they don't come up with an s-particle I can't avoid to think: Yes, if you blow up your dimensions long enough you can embed and model everything within.
But my last question was meant seriously. The fermionic Fock space is a Graßmann algebra and therewith its quotient is ##span \{ v_1 ⊗ ... ⊗ v_n | v_i = v_j ## for a ## i ≠ j \} ##. That looks pretty much like the Pauli principle.
Is this interpretation correct?
I found the old thread. Here it is. There are some links in there to uni notes that I think may answer some of these questions. Maybe if I follow them I'll remember where I put my own notes.
I think you're probably right about the Pauli principle @fresh_42. I'm not seeing right now the equivalence between your span definition above and the quotient definition ##\Lambda(V)\equiv T(V)\ /\ I## where ##I## is the two-sided ideal generated by ##\{x\otimes x\ |\ x\in V\}##. But once I reflect on it and refresh my understanding of these objects I daresay it will become clearer to me.
Thank you. Something learned today. Thought it were easier to find an example for the OP. I was on de Sitter spaces ...(I don't see the equivalence of the 2 definitions either at once. But I remember they are. It's the usual construction of universal (sic!) objects of this kind.)
Thanks guys!
@fresh_42 In case you're still interested, I managed to eventually find the notes I wrote a while ago on this.
It's saved as PDF here.
I can't be absolutely sure it has everything I wrote in it, but it seems to contain most of the things I remember poking into.
When I get a nice chunk of time, I'll go over it myself and try to convert it to latex so it's more amenable to putting on the web, and I can refresh my knowledge, correct errors and fill in gaps along the way.
I am, thank you. I am dealing with an invariant of Lie Algebras which has some interesting properties. I'm asking myself whether it's just a nice mathematical fact or if there's anything "real" about it. It's a leftover of a thesis I once started a long time ago. And regarding the whole thing as a quotient of a tensor algebra is one possible view on it.
Related to Example of a factor space in physics
1. What is a factor space in physics?
A factor space in physics refers to the space in which a physical phenomenon or process is being studied. It is a mathematical concept that allows scientists to isolate and study specific factors that may influence the phenomenon being observed.
2. How is a factor space related to experimental design?
In experimental design, a factor space is used to identify and manipulate independent variables that may affect the outcome of an experiment. It allows scientists to control and isolate specific factors in order to draw more accurate conclusions about the relationship between variables.
3. Can you give an example of a factor space in physics?
One example of a factor space in physics is the study of the factors that affect the motion of a pendulum. The length of the pendulum, mass of the pendulum bob, and the gravitational force are all factors that can be manipulated and studied in a factor space to understand their impact on the pendulum's motion.
4. How does a factor space help in understanding complex physical systems?
Factor spaces allow scientists to simplify complex physical systems by breaking them down into smaller, more manageable parts. By studying these individual factors, scientists can gain a better understanding of the overall system and how different factors may interact with each other.
5. Is a factor space only used in physics?
No, factor spaces are used in many other scientific fields, such as biology, chemistry, and economics. In these fields, factor spaces help researchers isolate and study specific factors that may influence a particular process or phenomenon.
