Example of a Lie group that cannot be represented in matrix form?
In summary: The universal cover of a space is simply connected. The metaplectic group is not simply connected. So they are different.
nrqed
297
I am not sure if this is the right forum to post this question.
The title says it all: are there examples of Lie groups that cannot be represented as matrix groups?
Thanks in advance.
Here (at the beginning) is an example of a local Lie group
https://www.physicsforums.com/insights/journey-manifold-su2mathbbc-part/
However, we have the adjoint representation ##\operatorname{Ad}\, : \,G\longrightarrow \operatorname{GL}(\mathfrak{g})##, and ##\operatorname{Ad}(G)## is a Lie subgroup of ##\operatorname{GL}(\mathfrak{g})##. If it is a monomorphism, we automatically get ##\operatorname{G}\cong \operatorname{Ad}(G)## and have a matrix group.
Likes nrqed
Your notation for the unitary groups is unconventional.
##\widetilde{SL}_2(\mathbb R)##
Likes dextercioby and nrqed
Thank you. Can you tell me how it is defined, or under what name I can look up information about that group?
Metaplectic
Likes nrqed
martinbn said:
Metaplectic
Tank you to both of you! This is what I was looking for!
Don't you always have a trivial representation sending everything to the identity?
I guess we want to have a faithful representation to call a group a matrix group.
Likes dextercioby
How about the Cayley representation then, as a group of permutations?
Are we still talking about Lie groups?
Cant every group be described as a permutation group? Unless you want to preserve any other than algebraic properties, it seems it would work, though I don't see how to do it with Lie groups.
If the group is not finite, these permutations are not going to be matrices.
martinbn said:
Metaplectic
These groups are different. The metaplectic group ##Mp(2)## is not simply connected because it is a double cover of ##Sp(2)=SL_2(\mathbb{R}),## which has fundamental group of ##\mathbb{Z}##.
Yes, but that was clear from the link.
The tilde on top of the group "name" exactly universal cover of that group means. So the two groups are not different.
Likes dextercioby
Absolutely, it seems my memory betrays me. I stand corrected.
Related to Example of a Lie group that cannot be represented in matrix form?
1. What is a Lie group?
A Lie group is a type of mathematical group that is continuous, meaning it can be described by a smooth curve, and is also a differentiable manifold, meaning it can be described by a set of equations. Lie groups are often used in physics and geometry to describe symmetries and transformations.
2. What is a matrix representation of a Lie group?
A matrix representation of a Lie group is a way of describing the group using matrices, which are arrays of numbers. This is often done by finding a set of matrices that satisfy the group's defining equations and can be used to perform the same operations as the group.
3. Why can't all Lie groups be represented in matrix form?
Not all Lie groups can be represented in matrix form because some groups have infinite dimensions, meaning they have an infinite number of elements. Matrices, on the other hand, have a finite number of elements, so they cannot fully represent these infinite-dimensional groups.
4. Can you give an example of a Lie group that cannot be represented in matrix form?
One example of a Lie group that cannot be represented in matrix form is the group of diffeomorphisms, which are transformations of a differentiable manifold that preserve its structure. This group has infinite dimensions and therefore cannot be represented using matrices.
5. How are Lie groups that cannot be represented in matrix form studied?
Lie groups that cannot be represented in matrix form are studied using other mathematical tools, such as differential equations and functional analysis. These methods allow for a more abstract and general understanding of these groups, without relying on specific matrix representations.
