Example of an Inseparable Polynomial .... Lovett, Page 371 ...
In summary: The polynomial equation holds, because ##3=0## in a field ##F_3(x)## of characteristic ##3##. This is called the Frobenius homomorphism. It is the a ring homomorphism ##a \mapsto a^p##. And since all terms in between are divisible by ##p##, we have ##(t-\sqrt[p]{x})^p=t^p-x##.In summary, we discussed Example 7.7.4 from "Abstract Algebra: Structures and Applications" by Stephen Lovett, which deals with field extensions in characteristic 3. We determined that the field extension
Math Amateur
MHB
3,998
48
I am reading "Abstract Algebra: Structures and Applications" by Stephen Lovett ...
I am currently focused on Chapter 7: Field Extensions ... ...
I need help with Example 7.7.4 on page 371 ...Example 7.7.4 reads as follows:
In the above text from Lovett we read the following:" ... ... The element ##\sqrt[3]{2} \notin F## and ##\sqrt[3]{2}## has minimal polynomial ...##m(t) = t^3 - x##.However,##m(t) = t^3 - 3t^2 \sqrt[3]{2} + 3t x^{ 2/3 } - x = (t - \sqrt[3]{2} )^3##... ... ... ... "
My questions are as follows:
Question 1
How does Lovett establish that the minimum polynomial is
##m(t) = t^3 - x##?Indeed, what exactly is ##t##? ... what is ##x##? Which fields/rings do ##t, x## belong to?[My apologies for asking basic questions ... but unsure of the nature of this example!]
Question 2How does Lovett establish that##m(t) = t^3 - 3t^2 \sqrt[3]{2} + 3t x^{ 2/3 } - x = (t - \sqrt[3]{2} )^3##
Help will be appreciated ...
Peter
[NOTE: I understand that the issues in this example are similar to those of other of my posts ... but ... for clarity and to avoid mixing/confusing conversational threads and issues I have decided to post this example separately ... ... ]
  • Lovett - Example of an Insepable Extension ... Section 7.7, page 371 ... ....png
Hi Peter,
this is the same example I quoted in your other post on the subject. Seems to be the standard example for an inseparable field extension.
First of all, as characteristic zero fields and finite fields are all separable, we need a prime characteristic, here ##p=3## and an infinite field. Therefore Lovett considers ##F_3## as ground field and ##F_3(x)## as field extension. Now you may consider ##x## as an indeterminate or a transcendental number over ##F_3##. It doesn't make a difference. (See my post here: https://www.physicsforums.com/threads/field-extensions-and-free-parameters.916207/#post-5778146)
No. He adjoins ##\sqrt[3]{x}##, not ##\sqrt[3]{2}##. This is an essential difference here!
##m(t) = t^3 - x##.
However,
No. Again, he adjoins ##\sqrt[3]{x}##, not ##\sqrt[3]{2}##. This is an essential difference here!
Question 1
##m(t) = t^3 - x##?
Set ##\alpha := \sqrt[3]{x} ##. What is the minimal polynomial of it over ##F_3(x)##? ## \alpha^3 =x ## so ##\alpha^3-x=0## and ##t^3-x## is the minimal polynomial, an element of ##F_3(x)[t]## where ##t## is the indeterminate, the variable of the polynomial ring. ##x## is already used as transcendental number, or if you like as another indeterminate, that constitutes the field ##F_3(x)##. However, ##\sqrt[3]{2}## does not, because ##2 \cdot 2 \cdot 2= 2## which means ##2 \in F_3## has a third root in ##F_3##, namely ##2## itself.
Question 2
I suggest to read the post I quoted. It is from today so should be new to you. Lovett simply needs two different variables: one as the indeterminate for a polynomial ring, the other as either an indeterminate of a quotient field ##F_3(x)## of the polynomial ring ##F_3[x]## or as transcendental number (over ##F_3##) if you like this better. It is the same. You can also simply take ##x:=\pi## which will work the same way.
Edit (ad question 2):
As a field extension is inseparable if and only if there is a ##p-##th root (here ##p=3##) of an element that does not lie in the field already, we have to consider polynomials of the kind ##t^3-x## where ##x## is that element. The polynomial equation holds, because ##3=0## in a field ##F_3(x)## of characteristic ##3##. This is called the Frobenius homomorphism. It is the a ring homomorphism ##a \mapsto a^p##. And since all terms in between are divisible by ##p##, we have ##(t-\sqrt[p]{x})^p=t^p-x##.
Likes Math Amateur
fresh_42 said:
Hi Peter,
First of all, as characteristic zero fields and finite fields are all separable, we need a prime characteristic, here ##p=3## and an infinite field. Therefore Lovett considers ##F_3## as ground field and ##F_3(x)## as field extension. Now you may consider ##x## as an indeterminate or a transcendental number over ##F_3##. It doesn't make a difference. (See my post here: https://www.physicsforums.com/threads/field-extensions-and-free-parameters.916207/#post-5778146)No. He adjoins ##\sqrt[3]{x}##, not ##\sqrt[3]{2}##. This is an essential difference here!
No. Again, he adjoins ##\sqrt[3]{x}##, not ##\sqrt[3]{2}##. This is an essential difference here!I suggest to read the post I quoted. It is from today so should be new to you. Lovett simply needs two different variables: one as the indeterminate for a polynomial ring, the other as either an indeterminate of a quotient field ##F_3(x)## of the polynomial ring ##F_3[x]## or as transcendental number (over ##F_3##) if you like this better. It is the same. You can also simply take ##x:=\pi## which will work the same way.
Thanks fresh_42 ... still thinking over what you have said ...
By the way ... no idea why I wrote ##\sqrt[3]{2}## instead of ##\sqrt[3]{x}## ... was a "typo" ... I wrote out the post then typed it up ... wasn't paying attention when I typed it ... apologies ...
But ... what you have written is most helpful to me ... thanks for your support in my understanding of field extensions ...
Peter
Math Amateur said:
By the way ... no idea why I wrote ##\sqrt[3]{2}## instead of ##\sqrt[3]{x}## ... was a "typo" ... I wrote out the post then typed it up ... wasnt paying attention when I typed it ... apologies ...
No need for apologies, but here it changes the entire situation. ##F_3(x)## is the ground field in this example.
##F_3(x)(\sqrt[3]{x})## is inseparable (over ##F_3(x)##), because ##F_3(x)## doesn't contain a third root of ##x##.
##F_3(x)(\sqrt[3]{2}) = F_3(x)## because ##F_3(x) \supseteq F_3 \ni 2 = 1+1 \notin \{0,1\}## and ##2^3=2## which means ##\sqrt[3]{2}=2##. So in this case we wouldn't get a proper extension. We also have ##t^3-2 = (t-2)^3## so the "minimal polynomial" is ##t-2## which also shows that ##\sqrt[3]{2}=2## is the only third root of ##2##.
Likes Math Amateur
Related to Example of an Inseparable Polynomial .... Lovett, Page 371 ...
1. What is an inseparable polynomial?
An inseparable polynomial is a type of polynomial in which some of the terms cannot be separated into smaller factors. This means that the polynomial cannot be factored into simpler terms.
2. Can you provide an example of an inseparable polynomial?
One example of an inseparable polynomial is x^2 + y^2. This polynomial cannot be factored into smaller terms because the x and y terms are not able to be separated.
3. What is the significance of inseparable polynomials in mathematics?
Inseparable polynomials are important in fields such as algebra and number theory. They are used to study and solve problems related to factorization and finding roots of polynomials.
4. How are inseparable polynomials different from separable polynomials?
Inseparable polynomials cannot be factored into smaller terms, while separable polynomials can be factored into simpler terms. Inseparable polynomials also have different properties and are used for different purposes in mathematics.
5. Are there any real-world applications of inseparable polynomials?
Inseparable polynomials have many real-world applications, such as in cryptography and computer science. They are also used in fields like physics and engineering to model and solve problems related to complex systems.
  • Linear and Abstract Algebra
