Example on Z-modules .... Dummit & Foote, Page 339 ....
  • I
  • Thread starter Math Amateur
  • Tags
    Example
In summary, Dummit and Foote's example on Z-modules demonstrates how the module axioms show that the only possible action of ##\mathbb{Z}## on ##A## making it a (unital) ##\mathbb{Z}##-module is the one described in the book. This is shown by using induction to prove that the operation of ##\mathbb{Z}## on ##A## is equivalent to repeated addition or subtraction, thus making Abelian groups naturally into a ##\mathbb{Z}-##module.
Math Amateur
MHB
3,998
48
I am reading Dummit and Foote's book: "Abstract Algebra" (Third Edition) ...
I am currently studying Chapter 10: Introduction to Module Theory ... ...
I need some help with an aspect of Dummit and Foote's example on Z-modules in Section 10.1 Basic Definitions and Examples ... ...Dummit and Foote's example on Z-modules reads as follows:
In the above example we read the following:
" ... ... This definition of an action on the integers on ##A## makes ##A## into a ##\mathbb{Z}##-module, and the module axioms show that this is the only possible action of ##\mathbb{Z}## on ##A## making it a (unital) ##\mathbb{Z}##-module ... ... "Can someone please explain how/why the module axioms demonstrate that this is the only possible action of ##\mathbb{Z}## on ##A## making it a (unital) ##\mathbb{Z}##-module ... ... ? How do we know it is the only possible such action ... ... ?Hope someone can help ...
Peter
Hey peter.
Take any action ##\mathbb{Z} \times A \to A: (n,a) \mapsto n.a## satisfying the module axioms.
It is easy to see that
##n.a = (1+1+ \dots +1).a = 1.a + \dots + 1.a = a + \dots + a## if n > 0.
The other cases can be treated in the same way. Since I assumed nothing but the action axioms, it follows that if there is an action, it must look like the action that is written is your book.
Hope this helps.
Likes Math Amateur
We have ##1.a=a## and ##0.a=0##. Then ##n.a=((n-1)+1).a=(n-1).a+1.a=(a+\ldots+a)_{n-1\text{ times }} \cdot a + a=n\cdot a## by induction. The same works for ##-a## if we use ##0=0.a## to show ##(-1).a=-a\,.##
Remark: Here ##n.a## stands for an operation of ##\mathbb{Z}## on ##A## and ##n\cdot a## for ##n## additions, resp. subtractions of ##a##, because at prior, ##n\cdot a## isn't defined, so it is merely a short hand notation of ## a+\ldots +a## (##n## times), which is defined. The assertion is basically that the two don't have to be distinguished, and we can speak of the operation, which makes Abelian groups (additively written) naturally into a ##\mathbb{Z}-##module.
Likes Math Amateur
Related to Example on Z-modules .... Dummit & Foote, Page 339 ....
1. What is a Z-module?
A Z-module is a mathematical structure that is similar to a vector space, but the scalars are integers instead of elements from a field. It is a set of elements that can be added and multiplied by integers, satisfying certain axioms.
2. How is a Z-module different from a vector space?
A Z-module differs from a vector space in that it does not require a field of scalars, but instead only integers. This means that there are some operations, such as division, that are not defined in a Z-module as they would be in a vector space.
3. What is the role of generators in a Z-module?
Generators are elements in a Z-module that can be used to create all other elements in the module through addition and scalar multiplication. They form a basis for the Z-module, and any element in the module can be written as a linear combination of these generators.
4. Can a Z-module have an infinite number of generators?
Yes, a Z-module can have an infinite number of generators. In fact, every nonzero element in a Z-module can be a generator, as long as they are not linearly dependent. This is because every element can be written as a linear combination of generators, and there are infinitely many ways to choose these generators.
5. How are submodules defined in a Z-module?
A submodule in a Z-module is a subset of the module that is closed under addition and scalar multiplication by integers. In other words, it is a subset that is also a Z-module itself. This allows for the concept of quotient modules, where a submodule can be "divided out" of the original module to form a new module.
  • Linear and Abstract Algebra
