Examples of A intersection B being an element of A
In summary, the concept of A intersection B being an element of A refers to the idea that when two sets, A and B, have overlapping elements, the elements that they have in common are considered to be part of both A and B. This is represented by the symbol "∩" and is often used in mathematical and logical operations. Some examples of this concept include the intersection of two circles, where the overlapping area is considered to be part of both circles, and the intersection of two categories, where an item that falls into both categories is considered to be part of both.
Stephen Tashi
1,599
What are some examples where the intersection of two sets is a member of one of the sets?
Let [itex] A,B,C,D [/itex] be sets whose elements are sets of integers.[tex] A = \{\emptyset, \{1,2\},\{3\} \} [/tex]
[tex] B = \{\{4,5,6\},\{7,8\} \} [/tex]
[tex] C = \{ \emptyset, \{7,8\} \} [/tex]
[tex] D = \{ \{3\}, \{4,5,6\} \} [/tex]Then [itex] A \cap B = \emptyset [/itex] and taking the empty set to be unique (as mentioned in the recent thread https://www.physicsforums.com/threa...ms-specify-that-the-empty-set-is-open.773047/ ) this is the same empty set that is an element of [itex] A [/itex] so have that [itex] A \cap B \in A [/itex]On the other hand [itex] A \cap C = \{\emptyset \} [/itex], which is to say that [itex] A \cap C [/itex] is a set with one element and that element is the empty set. This set is not the empty set, so we can't say that [itex] A \cap C \in A [/itex].[itex] A \cap D = \{\{3\}\} [/itex]. My interpretation is that [itex] A \cap D [/itex] is a set with one member and that member is itself a set with one element, the integer 3. So [itex] \{\{3\}\} [/itex] is not a "set of integers", it is a "set of sets of integers". So we can't say that that [itex] A \cap D \in A [/itex].
In the set-theoretic construction of the natural numbers, where ##0=\{\}## and ##n+1=n\cup\{n\}##, this sort of "weird" stuff happens all of the time; e.g. if ##a<b##, then ##a\in b## and ##a\subset b##.
Speaking of wierd, It's counterintuitive that [itex] A \cap B \in A [/itex] does not imply [itex] A \cap B \in B [/itex].
For arbitrary sets [itex]A [/itex] and [itex] B [/itex], does [itex] A \cap B \in A [/itex] imply [itex] A \cap B = \emptyset [/itex] ?
Well, in naive/intuitive set theory you have two classes* of objects, elements and sets, that are different types* of things (*though these words do have a technical meaning in foundations of math, my use of them here is completely informal). A such the relation ##\in## between an element and a set is viewed as a different kind of relation than the relation ##\subset## between two sets.
Dig a little deeper into naive set theory, and you start to see some examples of sets that also act like elements of other sets. But in an intuitive sense, we want to view the "bigger" set and its subsets as living on some higher level of "sethood" than the set that is an element. So we still see ##\in## and ##\subset## as different kinds of relations; ##\subset## is a relation between sets of the same level of sethood, and ##\in## is a relation between a lower-level set and on that has more sethood.
When you move to a more formal set theory, all of the objects are sets and elements. The relation ##\in## is a relation between sets that is not significantly different than the order relation ##<## on ##\mathbb{N}##. In the same way that ##1## and ##2## are on the same level of "numberhood" to most people despite the fact that ##1<2##, there are no differing degrees of sethood between ##a## and ##b## when ##a\in b##. And so you start to throw away your intuition regarding the similarities and differences between the relations ##\in## and ##\subset## and begin to see them as being more similar. But you swing too far the other way and build a new false intuition in which they are too similar.
I guess this is the long way of saying that the naive approach to set theory leads us to think intuitively that ##a\subset b## excludes the possibility of ##a\in b##, and vice versa. Once we come to the realization that ##a\subset b## and ##a\in b## aren't mutually exclusive, it's easy to begin to conflate ##\in## with ##\subset##.
No. Similar to the example I gave in post #2, ##b<a## implies that ##a\cap b=b##, which in general is not the empty set. Note that both ##b\in a## here and ##b\subset a##, so ##a\cap b\subset a## (which is totally expected) and ##a\cap b\in a## (unexpected and relevant to this question).
For a more immediate counterexample, take ##A=B\cup \{B\}## where ##B\neq\emptyset##.
[itex]\emptyset[/itex] is not the same as [itex] \{\emptyset \} [/itex]. The former means there is nothing in the intersection. The latter means there is a set, which is empty, in the intersection.
Related to Examples of A intersection B being an element of A
1. What does "A intersection B being an element of A" mean?
This means that there is at least one common element between sets A and B, and that this common element is also an element of set A. In other words, the intersection of A and B is a subset of A.
2. Can you provide an example of A intersection B being an element of A?
An example of this would be if set A represents all even numbers and set B represents all multiples of 4. The intersection of these two sets would be the set {4, 8, 12, ...}, which is a subset of the set of even numbers (A). Therefore, A intersection B (the set of multiples of 4) is an element of A (the set of even numbers).
3. How is "A intersection B being an element of A" different from "A intersection B equals A"?
While both statements involve the intersection of sets A and B, "A intersection B equals A" means that the intersection of A and B contains all elements of set A and may contain additional elements as well. On the other hand, "A intersection B being an element of A" simply means that at least one element of the intersection is also an element of set A.
4. Why is it important to understand "A intersection B being an element of A" in scientific research?
Understanding this concept is important in order to accurately interpret and analyze data. For example, in a study comparing two groups, it is necessary to determine if the intersection of the groups contains all elements of one group and if it is a subset of that group. This can help researchers make more precise conclusions about the relationship between the two groups.
5. Can the intersection of two sets ever be equal to both sets?
No, the intersection of two sets can never be equal to both sets. This is because the intersection of two sets can only contain elements that are common to both sets. If the intersection were to equal both sets, it would mean that every element in both sets is also present in the other set, making the two sets identical.
  • Topology and Analysis
