Examples of infinite nonabelian groups not GL_n(G)?
In summary, the OP is trying to identify an infinite non-abelian group other than ##GL_n(G)## and also other than contrived groups such as the group:##G=\big<r,s : r^2=s^3=1\big>##but he is having difficulty understanding what can be done with these groups. He then asks for help from the community on examples.
jackmell
1,807
54
Hi,
I was trying to identify some infinite non-abelian groups other than ##GL_n(G)## and also other than contrived groups such as the group:
as per:
https://www.physicsforums.com/threa...and-nonabelian-given-its-presentation.643968/
and I was wondering if someone here could give me some examples that I could understand. Does not seem to be common and I didn't find any with a cursory search but may have to just search more.
Thanks,
Jack
Have you considered Quaternions?
But that's only a finite group ##Q=\{\pm 1, \pm i, \pm j, \pm k\}## although perhaps I'm not fully understanding what can be done with this group.
Edit:
Maybe though I can consider the group ##G=\{a+bi+cj+dk\; :\; (i,j,k)\in Q, (a,b,c,d)=\mathbb{R}\}##. But then wouldn't multiplication still be commutative? Looks to be the case.
Not so. I can let ##h_1=i## and ##h_2=j## then ##h_1 h_2\neq h_2 h_1##. I'm getting it.
But now I have to figure out what the inverse of ##g\in G## is. I assume that's the conjugate ##(a-bi-cj-dk)##? Need to check that. Just haven't done much with quaternions.
Edit:
Right, the first is just a finite generating set and not the group itself. And you should consider the relations, e.g.. ##i^2=-1 ##. Maybe viewing them as rotations will help you get a more intuitive view, a better grasp of them --please let me know when you do, because I don't have it myself ;).
The group of quaternions is equivalent to the group U(2), the group of 2*2 unitary matrices. For unit quaternions, it's SU(2), the U(2) matrices with determinant 1.
More generally, however, GL(n,C) > U(n) > SU(n)
But by mapping complex numbers a+b*i onto a*{{1,0},{0,1}} + b*{{0,-1},{1,0}} = {{a,-b},{b,a}}, one finds that GL(n,C) is a subgroup of GL(2n,R).
More generally, the OP seems to be asking if there is some infinite group that does not map onto some subgroup of GL(n,C) for some n. Such a subgroup is called a "representation" of the group, and the OP is asking if there is some group without representations. Strictly speaking, every group has a representation: the identity one, the identity matrix for every element of the group. But that case aside, the trivial case, the interesting case is a "faithful" representation, where distinct group elements map onto distinct representation elements.
Thus, the OP's question is whether there is some infinite group that has no faithful representations, or even no nontrivial representations.
In the finite case, that is easy to prove, by constructing the "regular representation", D(a)x,y = 1 if x = a*y, 0 otherwise. It is not difficult to show from that definition that D(a).D(b) = D(a*b).
I don't know if anyone has proved that for infinite groups, however.
I assumed when you mention a group, it is up to isomorphism. Representations are usually just homomorphisms.
Consider the set of bijections from [0,1] to itself under the operation of composition of functions. This group is infinite and not abelian.
Following up on pasmith's example, consider the mapping class group of a topological space, also under composition. These are automorphisms (self -homeomorphisms), often diffeomorphims, up to isotopy.https://en.wikipedia.org/wiki/Mapping_class_group . Many of these are infinite, but not all.
Hi,
Isn't that just isomorphic to a set of permutations? I'm not sure but if I define:
##\phi: \{ \sigma: [0,1]\to [0,1] \text{ is a bijection}\}##
then I could write ##\phi\cong S_{\infty}## and I know that the symmetric group is non-abelian.
Also the reason I asked was related to a homework problem which I didn't want to ask you guys for help since wabbit had already helped me with the first part:
https://www.physicsforums.com/threads/normalizer-n_g-x-equal-to-another-set-when-o-x-infty.831620/
but since I've already turned it in maybe you guys could tell me what I did wrong because I don't think I got it right:
Give an example of a group in which the normalizer, ##N_G(X)## is not equal to the set ##\{g\in G : gxg^{-1}\in X;\forall\; x\in X\}## for some set ##X\subseteq G##.
My professor had briefly suggested in class using ##GL_n(F)## but I wanted to try something different so I tried that quaternion group above and let ##X=\{x_0, x_1, x_2,\cdots,x_n,\cdots\}## with ##x_0## some non-identity element in G and then ##x_1=g_0xg_0^{-1}, x_2=g_0x_1g_0^{-1}, \cdots##, again for some non-identity ##g_0## element in G. Then I argued that almost certainly we have the following:
##N_G(X)=\{1\}##
but
##\{g\in G : gxg^{-1}\in X\;\forall\; x\in X\}=\{1,g_0\}##
But I couldn't prove it so left it at "almost certainly". Maybe ## \{ \sigma: [0,1]\to [0,1] \text{ is a bijection}\}## would have been a better choice.
Yes, it's a faithful representation that's an isomorphism, one whose kernel contains only the identity element.
Ben Niehoff said:
The "metaplectic" group is an infinite group with no faithful matrix representations:
https://en.wikipedia.org/wiki/Metaplectic_group
So that's a counterexample to what one would expect from a finite group. The regular representation of a finite group can easily be shown to be a faithful matrix representation, but that concept does not carry over very well into infinite groups. For countably infinite groups, one might define an infinite-dimensional matrix as an extension of finite-dimensional ones, but I don't think that one can do that for uncountably infinite groups. One might generalize a matrix into function composition, however, and get a function-composition generalized representation for an uncountably infinite group. Matrix multiplication -> function composition:
A.B.x -> A(B(x))
An invertible matrix would generalize to a bijection, an invertible function. Function composition is associative, and there is an identity function. So function composition in general is a monoid. With only invertible functions, it is a group.
FAQ: Examples of infinite nonabelian groups not GL_n(G)?
1. What is an example of an infinite nonabelian group?
An example of an infinite nonabelian group is the dihedral group, which consists of all rotations and reflections of a regular polygon. It is nonabelian because the order in which these operations are performed matters, and it is infinite because there are an infinite number of possible rotations and reflections.
2. How is a nonabelian group different from an abelian group?
A nonabelian group is a group in which the order in which operations are performed matters, while an abelian group is a group in which the order does not matter. In other words, for a nonabelian group G, there exist elements a and b such that ab≠ba, while for an abelian group, ab=ba for all elements a and b.
3. What does "GL_n(G)" mean in the context of nonabelian groups?
"GL_n(G)" refers to the general linear group, which is the group of all invertible n×n matrices with entries from the group G. In the context of infinite nonabelian groups, it is often used as a benchmark or reference point for comparison.
4. Can you give an example of an infinite nonabelian group that is not GL_n(G)?
Yes, one example is the infinite symmetric group, which consists of all permutations of an infinite set. It is nonabelian because the order in which permutations are performed matters, and it is not GL_n(G) because it is not a group of matrices.
5. How are infinite nonabelian groups relevant in scientific research?
Infinite nonabelian groups are relevant in many areas of mathematics and physics, such as group theory, topology, and quantum mechanics. They are also used in cryptography, coding theory, and other fields that require the manipulation of complex structures and symmetry groups.
