Examples of Non-Orthogonal Curvilinear Coordinates
In summary, the conversation discusses the difficulty in finding realistic examples of non-orthogonal curvilinear coordinates in textbooks and websites for studying mathematics. The speaker suggests constructing a non-orthogonal system using polar coordinates as an example. The conversation also explores the practical applications of non-orthogonal coordinates in various fields, such as fluid dynamics and structural mechanics. The speaker emphasizes the importance of studying actual examples rather than generalized coordinates in order to better understand the concepts and calculations involved.
Frank Peters
28
I am beginning to study the mathematics of curvilinear coordinates and all textbooks and web sites do not have realistic examples of non-othogonal systems.
What are some examples of non-orthoganal curvilinear coordinates so that I can practice on actual systems rather than generalized examples?
All the coordinate systems that I've examined, such as parabolic cylindrical, ellipsoidal, spherical, and polar cylindrical, are all orthogonal. There must be lots of non-othogonal examples.
Mathematics news on Phys.org
The reason you just see orthogonal coordinate systems is that they are generally much easier to work with. It should be rather easy to construct a non-orthogonal curvilinear system though. For example, for the two-dimensional plane you could use ##\rho = r## and ##\alpha = \theta + kr##, where ##r## and ##\theta## are the usual polar coordinates and ##k## is a constant.
Likes romsofia
I would say that orthogonal systems are the "actual" systems we work in!
Are you just looking for these coordinates in case you come across a scenario in which orthogonal coordinates are not the most ideal? What calculations are you looking to do?
You can work in any system you like, it does not matter for the results. You will get the same results in a non-orthogonal system as you will in an orthogonal one. There is nothing more "actual" about an orthogonal system.
The main example that comes to my mind here is light-cone coordinates on Minkowski space. There are also many generalised mechanical systems where the kinematic metric is not diagonal in the most obvious coordinate systems.
Yes, which is why I put it in quotes since OP said he wants to practice on "actual systems rather than generalized examples?".
An example I can provide is that of an automobile tire structure that is modeled as a membrane. One is studying the structural mechanics of the tire as it is deformed under various modes of load application such as inflation and contact with the ground. The deformations of the tire membrane can be large. The initial shape of the tire is described by a material coordinate system embedded or inscribed onto the surface of the undeformated membrane. The coordinates are initially orthogonal. However, when the tire membrane deforms, the material coordinates become non-orthogonal, and the displacements of the material points are expressed functions of the original material coordinates. This is a standard way of setting up structural deformation problems.
Likes WWGD and Orodruin
There are all sorts of things: covariant and contravariant vectors, metric components and the metric tensor, scale factors, differential quantities, transformations between different systems, etc., etc.
In my experience, it is better to study these things using actual examples rather than the generalized coordinates, i.e. x=x(q1, q2, q3), y=y(q1, q2, q3), and z=z(q1, q2, q3), which are universally used in textbooks and web sites.
It is straightforward to construct non-ortho systems but I was wondering if there were some actual systems used somewhere in practice.
You are interested in some actual application of this to practical problems. OK.
Here is an example of a fluid dynamics problem from Physics Forums in which non-orthogonal coordinates are used to develop the differential force balance on a free surface of a fluid, including surface tension: https://www.physicsforums.com/threads/when-to-use-which-dimensionless-number.933101/page-2 The analysis involving non-orthogonal coordinates starts at post #31.
Here is a simplified version of the tire example I alluded to in a previous post, taken from the open literature:
Miller, C., Popper, P., Gilmour, P.W., and Schaffers, W.J., Textile Mechanics Model of a Pneumatic Tire, Tire Science and Technology, 13, 4, 187-226 (1985). See the Appendix for the development of the equations.
FAQ: Examples of Non-Orthogonal Curvilinear Coordinates
1. What are non-orthogonal curvilinear coordinates?
Non-orthogonal curvilinear coordinates are a type of coordinate system that uses curvilinear or non-linear lines to represent points in space. These coordinates are not perpendicular to each other, unlike orthogonal coordinates which use perpendicular lines.
2. What are some examples of non-orthogonal curvilinear coordinates?
Some examples of non-orthogonal curvilinear coordinates include cylindrical coordinates, spherical coordinates, and ellipsoidal coordinates. These coordinate systems are commonly used in physics and engineering applications.
3. What is the advantage of using non-orthogonal curvilinear coordinates?
The advantage of using non-orthogonal curvilinear coordinates is that they can better represent curved or irregularly shaped objects or spaces. This makes them useful in applications that involve curved surfaces, such as fluid dynamics, electromagnetics, and geophysics.
4. What is the relationship between non-orthogonal curvilinear coordinates and orthogonal coordinates?
Non-orthogonal curvilinear coordinates can be derived from orthogonal coordinates through a process called coordinate transformation. This involves using mathematical equations to convert between the two coordinate systems.
5. How are non-orthogonal curvilinear coordinates used in practical applications?
Non-orthogonal curvilinear coordinates are commonly used in solving partial differential equations and in numerical simulations for various engineering and scientific problems. They are also useful in representing and studying complex three-dimensional shapes and surfaces.
11K
