Examples where mixed states are eigenstates
In summary, the conversation discussed the relationship between mixed states and eigenstates in quantum mechanics. While mixed states and eigenstates both have a value, they are not the same. In a collapse interpretation, measuring an observable collapses the system into an eigenstate, while in a no collapse interpretation, this is not the case. Mixed states can have a definite value for certain observables, such as spin or number, even though they are still considered mixed states. This can be seen in experiments with electrons and photons. Ultimately, further study of quantum mechanics is recommended to fully understand this topic.
oquen
109
I have actually read so much about density matrix and eigenstates today. I just want to know what particular situations when mixed states are eigenstates. Can this occur?
Mixed states and eigenstates have one thing in common.. they have a value.. but I know mixed states aren't eigenstates.. what are the exceptions?
Just one paragraph of accurate reply is enough to guide me to many reading. Thank you.
Mixed state is not described by a vector, in fact it's an operator.
oquen said:
they have a value.
What kind of value?
What kind of value?
When entangled pair is sent to Alice and Bob.. Alice can measure values of position or momentum... and having values of position and momentum are said to be in eigenstates. hence my confusion all day today.
oquen said:
Can this occur?
No.
That depends on the interpretation of QM you are using. In a collapse interpretation, measuring an observable (position or momentum or anything else) collapses the measured system into an eigenstate of that observable (the one corresponding to the value that is measured). But in a no collapse interpretation, like the MWI, this is not the case.
PeterDonis said:
No.
So what is the relationship of mixed state to eigenstates? Again going to alice and bob.. when entangled pair is sent to Alice and Bob.. Alice can measure values of position or momentum... isn't this the same as saying the mixed state Alice measures is in an eigenstate? But you disagree mixed states can't be eigenstates.
Or is the following the answer. Mixed state only produce statistics.. so when Alice measures the subsystem.. she gets a mixed state statistically and an Eigenstate of value? Is this it?
In a mixed state with density operator ##\rho##, the hermitian operator ##A## has a definite value ##\alpha## iff ##A\rho=\alpha\rho##. This is the correct form of the eigenstate condition for density operators.
This happens regularly when a state is modeled in a more complete fashion than just with one degree of freedom.
For example, an electron in a Stern-Gerlach experiment is typically in a mixed state with respect to position, but may still have a definite spin up. In the simple textbook description, only the spin degree of freedom is considered, and the electron appears to be in a pure state.
Similarly, experiments with photons are often in a mixed (thermal) state with respect to polarization, but for photons on demand, the number operator has the definite value 1.
PeterDonis said:
No.
Are you saying that in MWI, mixed state where born rule applied has a world/branch whereas in collapse interpretation, mixed state where born rule applied doesn't necessarily produce any collapse at all? and the only way for collapse to occur in the latter is when it is in an eigenstate of that observable?
I'm not sure what this means. I think you need to spend some time with a QM textbook; your background does not seem to be sufficient for an "I" level discussion.
Thread closed.
Related to Examples where mixed states are eigenstates
1. What are mixed states and eigenstates?
Mixed states and eigenstates are concepts in quantum mechanics. Mixed states refer to a state of a system that cannot be described by a single pure state, but rather a combination of multiple pure states. Eigenstates, on the other hand, refer to the states of a system where a particular observable quantity has a definite value.
2. Can a mixed state also be an eigenstate?
Yes, it is possible for a mixed state to be an eigenstate. This can occur when the mixed state is a combination of multiple eigenstates of a particular observable quantity. In this case, the observable quantity has a definite value in the mixed state, but the overall state is still a combination of multiple pure states.
3. Are there any practical applications of mixed states and eigenstates?
Yes, there are several practical applications of mixed states and eigenstates in quantum mechanics. These concepts are used in quantum computing, quantum cryptography, and quantum information processing, among others. They are also important in understanding the behavior of systems at the quantum level.
4. Can you give an example of where mixed states are eigenstates?
An example of this is in the spin of an electron. The spin of an electron can have two possible eigenstates: spin up and spin down. However, if we have a system with two electrons, the overall state of the system can be a mixed state of these two eigenstates. This is because the spin of the two electrons can be entangled, resulting in a mixed state that is also an eigenstate of the total spin of the system.
5. How do mixed states and eigenstates relate to the uncertainty principle?
The uncertainty principle states that certain pairs of physical properties, such as position and momentum, cannot be measured simultaneously with high precision. Mixed states and eigenstates are related to this principle because the concept of a mixed state arises when we have uncertainty about the state of a system. Similarly, the concept of an eigenstate is tied to the precise measurement of a particular observable quantity, which goes against the uncertainty principle.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
