Excel Problems with error bars
In summary, the individual is experiencing difficulty adding vertical error bars to their scatter graphs in Excel. They have tried searching for a solution online but have not found anything helpful. They have also noticed discrepancies in the size of their error bars and are looking for a way to delete certain data points without affecting their formulas. Possible solutions include creating additional columns and using the "IF" function to remove unwanted data points.
CAF123
88
I have a graph which I would like to add Y error bars to. When I click to add the error bars, it only allows me to add horizontal bars. This is very strange because the other graph I have, it allowed me to insert vertical bars.
Basically when I click on exactly the same menu to insert error bars, on one graph it takes me directly to vertical error bars and on the other graph it only allows me horizontal bars. I have for the last twenty mins been trying to get vertical bars on the menu that gives me horizontal bars. I don't know what else to try. I googled my problem but it just says click on 'More error bars options', but this is what I do by default.
It is if Excel is 'deciding' what error bars to give me.
Can anyone help?
EDIT: This is silly, now when I click on another graph I have created, I have vertical bars as my default... Vertical bars as default on two graphs, horizontal on the other - this makes no sense.
Many thanks.
Computer science news on Phys.org
Do you have a different type of diagram where you cannot add those error bars?
With X-Y (Scatter) graphs in Excel, I've never had trouble adding either horizontal or vertical error bars. What type of graphs are you using? Are they all the same type?
Yes, they are X Y scatter graphs. I click on the graph and then go the menu at the top of the page and click 'Error Bars'. Then I choose the option 'More options for Error bars'. On two of the three graphs (they are all the same, the only dissimilarity being the data) I can have vertical bars but on the third only horizontal. How did you manage to choose what ones you wanted?
I managed to get the vertical errors eventually by playing about with it some more. I have another question though. I have noticed that some of my error bars are very large in comparison to some of the others (as much as 30 times). I want to delete these data points from the graph. Is there a way to delete data points individually?
If not, I want to delete their entries in my table of data (I'll keep all raw data someplace else). How can I do this without messing things up (I have inserted formula so by deleting, it confuses Excel).
One way is to create additional columns that have the same data values, and in those columns delete the points you don't want included on the graph. Then you still preserve the original data, in case you change your mind about displaying it.
Or, you can use the "IF" function in the new column; if the error bar is greater than some cutoff value, then set the cell value to "" (i.e., a blank cell); otherwise the cell value is the data value from the original data column.
For example, if column D is to be the data that you want on the graph, then cell D3 could say
=IF(C3>E$1,"",B3)
where column B has the original data, column C has the error values, and cell E1 has the error bar cutoff value.
Related to Excel Problems with error bars
1. How do I add error bars to my data in Excel?
To add error bars to your data in Excel, first select the data points you want to add error bars to. Then, go to the "Layout" tab and click on "Error Bars" in the "Analysis" group. From there, you can choose to add standard error, standard deviation, or custom error bars to your data.
2. How do I change the direction of error bars in Excel?
To change the direction of error bars in Excel, double click on the error bars to open the "Format Error Bars" menu. Then, under "Error Amount" select the direction you want the error bars to point in from the drop-down menu. You can also adjust the length and style of the error bars from this menu.
3. Why are my error bars not showing up in Excel?
If your error bars are not showing up in Excel, it could be because they are too small to be visible. Try adjusting the scale of your chart or increasing the size of the error bars. It could also be because you have selected the wrong data points or have not formatted the error bars correctly.
4. How do I remove error bars from my Excel chart?
To remove error bars from an Excel chart, simply select the error bars and press the delete key on your keyboard. You can also right-click on the error bars and select "Delete" from the drop-down menu. If you want to remove all error bars from your chart, go to the "Layout" tab and click on "Error Bars" in the "Analysis" group, then select "None" from the drop-down menu.
5. Can I customize the error bars in Excel?
Yes, you can customize the error bars in Excel to fit your needs. You can change the type of error bar (standard error, standard deviation, or custom), adjust the error amount, change the direction and style of the error bars, and even add data labels to your error bars. Simply double click on the error bars to open the "Format Error Bars" menu and make your desired changes.
  • Computing and Technology
  • Feedback and Announcements
