Exciting an electron in a hydrogen atom.
A hydrogen atom in its ground state cannot be excited by a photon with a wavelength of 96.7 nm, as the energy of the photon (12.83 eV) is less than the required 13.6 eV to excite the electron to a higher energy state. If the atom were to be excited, the wavelength of the emitted photon would be longer than that of the absorbed photon, and the energy of the emitted photon would be less than that of the absorbed photon. The calculations confirm that the photon energy must exceed 13.6 eV for excitation to occur. Therefore, the initial photon does not provide sufficient energy for electron excitation. Understanding these energy transitions is crucial in quantum mechanics and atomic physics.
weston_sagle
A hydrogen atom in its ground state is illuminated with light having a wavelength of 96.7 nm. can the hydrogen atom's electron be excited to a higher energy state by absorbing one of these photons? If so, determine the state and wavelength of any photon that would be emitted by the atom.
E=hc/lambda
En=-13.6eV/n^2
E=hc/lambda
=[(6.626x10^-34)(3.0x10^8)/9.67x10-8]
=2.0556x10^18 J
Convert to / by 1.602x10^-19 eV = 12.83eV
En=-13.6eV/1^2 = -13.6eV
So I think that the photon energy would have to exceed 13.6eV to excite the electron, so in this case it would not excite it. Is this right?
If it did excite the electron, would the wavelength of the photon emitted be longer or shorter than the one absorbed? Would the energy of the emitted photon be greater or less than that of the absorbed photon?
  • · Replies 22 ·
