Excitons. Is this the same as radiative recombination?
In summary: In terms of kinetics, you have to keep track of exciton densities as well as free electron and hole densities. In summary, excitons are bound electron-hole pairs with lower energy than free carriers, and they play a role in radiative recombination and absorption processes. They have a discrete density of states and may dominate recombination at low temperatures or with high binding energies. Excitons also have different properties in terms of conduction and kinetics compared to free carriers.
Logio
Hi,
I'm having difficulty getting my head round the concept of excitons, which have recently been introduced into my Uni course.
Previously, I've always understand the operation of LEDs as follows:
Under forward bias, electron and holes are injected and recombine at the p-n junction (electrons fall from CB and holes rise from the VB, so they meet in the bandgap) emitting a photon of energy equal to the bandgap.
However, I've recently learned about EXCITONS, "bound e-h pairs with not quite enough energy for electrons to escape". In describing the operation of an OLED, we're told that in the organic layer an electron and hole form an exciton, which later radiatively relaxes to emit a photon. Also, when a photon is absorbed, an exciton is formed (e.g. in photodetector).
Therefore, could someone perhaps clarify if excitons are just the "more accurate" way of describing radiative recombination and absorption or if they're fundamentally different please?
Further to this, I wonder then, how do you go from an exciton being formed to it radiatively relaxing and when an exciton is formed by photoabsorption, is the exciton used in conduction?
Any help appreciated!
Thanks,
In a rough approximation you can think of excitons being similar to hydrogen. You have one positively charged particle and one which is negatively charged. Those two form a bound complex due to Coulomb interaction. This bound complex of course has lower energy compared to having two free particles. So the energy of an exciton state is a bit below the band gap just like you need energy to break a hydrogen molecule.
Whether excitons are important in recombination prcesses depends a bit on the exciton binding energy in your material and the temperature you are working at. If the average thermal energy in the system is large, then most excitons will be ionized and you will have predominantly free carriers. If you are working at low temperatures or have high binding energies, excitons will dominate recombination processes.
There are quite some differences between free carrier recombination and exciton recombination, but for the beginning the density of states may be the most important one. While free carriers have a continuum of states, the exciton has a well defined binding energy. Of course you may add kinetic energy if the center of mass of the exciton moves around, but if you trap excitons, you may get a discrete density of states (for example for quantum dots).
The radiative recombination of an exciton is not too different from free electrons and holes. There are no huge differences. There is of course a difference in terms of conduction as an exciton is electrically neutral in first approximation. It is also bosonic which may make a difference sometimes.
Related to Excitons. Is this the same as radiative recombination?
What are excitons?
Excitons are quasiparticles formed when a photon is absorbed by a material, causing an electron to move to a higher energy level and leaving behind a positively charged hole.
How are excitons different from regular electrons and holes?
Excitons behave differently from regular electrons and holes since they are formed by the interaction of an electron and a hole, rather than being individual particles. They also have unique optical and electrical properties.
What is radiative recombination?
Radiative recombination is a process where an electron and a hole recombine and release energy in the form of a photon. This process can occur in materials where excitons are present, but it is not the same as exciton formation.
Can excitons be observed in all materials?
No, excitons can only be observed in materials with a large enough bandgap, such as semiconductors. They cannot exist in metals since the electrons are free to move and do not form bound states with holes.
How do excitons affect the properties of a material?
Excitons can have significant impacts on the optical and electrical properties of a material. For example, they can affect the absorption and emission spectra, as well as the conductivity and charge carrier mobility. Understanding and controlling excitons is important for designing new materials with desired properties.
