Exercise about an aqueous solution (containing a halogen)
  • Chemistry
  • Thread starter Ako9
  • Tags
    Chemistry
In summary: I did the calculation and seem to be getting nonsense numbers. Concentration in % is honestly the devil.
Ako9
Misplaced Homework Thread
"An aqueous solution, with 5% of CaX_2 (X is an halogen), freezes at t=-1.396°C. K_cr=1.860. Find X."
$$\Delta t = K_{cr}\cdot m \cdot i$$
I can't find my mistake, can you help me?
I suppose that in 1000g of solution there are 50g of solute and 950g of solvent.
Then I find the molality
$$m= \frac{50}{MM} \cdot \frac{1}{0.950}$$
So I can find the Molar Mass of the compound using the relation $$\Delta t=K_{cr}\cdot m \cdot i$$ where i is the van 't Hoff coefficient which is 3 in this case.
At the end I don't find an halogen (Rubidium is the closest) so I assume something is wrong but I can't see what.
I think you've done the calculation correctly - at least, I agree with your answer. You get a halogen if you assume there are 50g solute to 1000g water. I'm never quite sure what people mean when they say "x% solution" with no further specification. Perhaps they think that this solution is sufficiently dilute that you can make this approximation, but that seems inconsistent with measuring T to 4 sig figs. (By the way, we usually use T for temperature, t for time.)
Likes Ako9
Last time I checked rubidium wasn't a halogen :wink:
The molality can be found exactly using the information given and the freezing point of water. You didn't use this number?
They did, but it doesn't produce a reasonable answer. Turns out the 5% part is unreliable, try to do the calculations assuming 50/950 and 50/1000 and you will see where the problem is.
Likes Ako9
Likes Ako9
% is OK as long as used correctly, it is just misused here.
FAQ: Exercise about an aqueous solution (containing a halogen)
What is an aqueous solution containing a halogen?
An aqueous solution containing a halogen is a mixture where a halogen element (such as chlorine, bromine, or iodine) is dissolved in water. These solutions often exhibit unique chemical properties due to the reactive nature of halogens.
How do halogens behave in aqueous solutions?
Halogens in aqueous solutions can act as oxidizing agents, meaning they can accept electrons from other substances. Their reactivity can vary, with fluorine being the most reactive and iodine the least. They can also participate in displacement reactions where a more reactive halogen displaces a less reactive halogen from its compounds.
What safety precautions should be taken when handling aqueous solutions containing halogens?
When handling aqueous solutions containing halogens, it is important to wear appropriate personal protective equipment such as gloves, goggles, and lab coats. Work in a well-ventilated area or under a fume hood to avoid inhaling fumes. Always follow proper disposal procedures for chemical waste.
How can you test for the presence of halogens in an aqueous solution?
The presence of halogens in an aqueous solution can be tested using various methods such as adding silver nitrate solution, which causes the formation of a precipitate. The color of the precipitate can help identify the specific halogen: white for chloride, cream for bromide, and yellow for iodide.
What are some common applications of aqueous solutions containing halogens?
Aqueous solutions containing halogens have various applications, including disinfection and sterilization (e.g., chlorine in water treatment), organic synthesis (e.g., halogenation reactions), and analytical chemistry (e.g., titrations and qualitative analysis). They are also used in the production of certain pharmaceuticals and industrial chemicals.
