Exercise Question from Maths book
In summary, the problem asked to find all points on the curve with equation 6y = 2x^3 + 3x^2 + 6x + 5 where the tangent is parallel to the line with equation 3x − y + 2 = 0. After finding the slope of the line and the derivative of the curve, it was determined that the points where the tangent is parallel to the line are (1, 8/3) and (-2, -11/6).
King_Silver
83
Member warned about posting with no effort
"Find all the points on the curve with equation 6y = 2x^3 + 3x^2 + 6x + 5 where the tangent is parallel to the line with equation 3x − y + 2 = 0
No idea
There are no exercises in the book even similar to this example which is fairly frustrating. Its under the differentiation chapter so it obviously involves differentiation. I can do that myself no bother but what is the method to find all points on the curve when a tangent is parallel to the line? Is there some sort of rule?
NOTE: This is not a graded assignment or even homework for that matter, it is revision for an exam I have in 5 days.
Can you find the tangent line to your curve in an arbitrary point ##(a,b)##?
Errrrrr... I might be able to?
I need to find all points on the curve where the tangent is parallel to the line. I've tried finding a video on YouTube that works with a similar problem but I wasn't able to find anything for it.
How do you find the tangent line to the curve? Do you see the relation with derivatives?
Likes King_Silver
You differentiate the 6y - 2x^3 +3x^2 +6x +5
but I am not given the points on the curve I am asked to find them :/
No idea
Well, can you at least find the slope of the line 3x - y + 2 = 0?
Likes King_Silver
y'(x) = 3 is the slope of the line 3x -y +2 = 0 right? :)
Yes, this is correct.
Now, can you turn 6y = 2x^3 + 3x^2 + 6x + 5 into y = something ?
Likes King_Silver
Well if 6y = 2x^3 + 3x^2 +6x +5 then y = (2x^3 + 3x^2 +6x +5)/6 no?
That's correct.
Now do you understand that the derivative dy/dx for a function can be used to calculate the slope of a tangent to the function when given a particular value of x?
Likes King_Silver
Yea I understand that I just don't get how to find the points on the curve where the tangent is parallel to the line.
Well, have you calculated dy/dx for y = (2x^3 + 3x^2 +6x +5)/6 yet?
BTW: I appreciate the likes, but it's not necessary to like every reply.
How can you see whether two lines are parellel?
If their slopes are identical? i.e. the exact same value yes?
Yes. So you need to find the points whose tangent line has slope is 3.
dy/dx is x^2 + x + 1.
Now that you can find the slope along the function, for what values of x would dy/dx = 3?
dy/dx would = 3 for...
x = 1
(1)^2 + 1 + 1 = 3. What does that prove in terms of the question? :)
x = 1
Re-read your Post #14 above.
Also, is x = 1 the only value which satisfies the equation dy/dx = 3 when dy/dx = x2 + x + 1 ?
x = 1 and x = -2 (because (-2)^2 + (-2) + 1 => 4 -2 + 1 = 3)
so you have x = 1, x = -2.
Then you just do when x = 1, y = whatever you solve.
x = -2, y = whatever you solve
When x = 1 or x = -2, dy/dx = 3 for the function 6y = 2x3 + 3x2 + 6x + 5
The slope of the line 3x − y + 2 = 0 was found to be 3.
Now, the problem statement asked:
Do you see how to do this now?
Now, the problem statement asked:Do you see how to do this now?
(1,2 and 2/3s) and (-2, -1 and 5/6s) ?
It's probably better to use simple rational expressions than improper fractions here:
point 1 : (1, 8/3)
point 2 : (-2, -11/6)
Likes King_Silver
point 1 : (1, 8/3)
Thanks for that :) I understand how to do it now cheers!
FAQ: Exercise Question from Maths book
1. What is the purpose of "Exercise Question from Maths book"?
The purpose of "Exercise Question from Maths book" is to provide practice and reinforce the concepts and skills learned in the corresponding math textbook.
2. How many exercises are typically included in "Exercise Question from Maths book"?
The number of exercises can vary depending on the particular book and publisher, but typically there are around 20-30 exercises per chapter.
3. Are the exercises in "Exercise Question from Maths book" multiple choice or free response?
The exercises in "Exercise Question from Maths book" can be either multiple choice or free response, depending on the text and publisher. Some books may have a mix of both types of questions.
4. Can "Exercise Question from Maths book" be used as a standalone study tool?
While "Exercise Question from Maths book" is primarily designed to accompany a textbook, it can also be used as a standalone study tool. However, it may be more effective when used in conjunction with a textbook or other learning materials.
5. How can "Exercise Question from Maths book" help improve my understanding of math concepts?
By practicing and solving the exercises in "Exercise Question from Maths book", you will gain a deeper understanding of the math concepts and principles covered in your textbook. It also allows you to identify any areas where you may need additional practice or review.
