Exhaust pipe diameter question
In summary, the conversation discusses the engine speed and capacity, the required exhaust pipe diameter, and the force exerted by the exhaust gas on the car. It also mentions the chemistry and ratio of exhaust components. The solution involves using the given values and equations to find the necessary exhaust pipe diameter and force exerted by the exhaust gas.
pizics
The engine turns at 3000 rpm at this speed. The engine capacity has a displacement of 1.2 litres: this means that 1.2 litres of exhaust gas is expelled from the motor (into the exhaust manifold) every two* revolutions. Further assume that the gas leaves the exhaust pipe with the same volume** that it leaves the engine. What exhaust pipe diameter is required to obtain the given exhaust speed?
Remember the class problem about drag-race cars with exhaust thrust? Is there a serious propulsion effect for normal cars with horizontal exhaust pipes? To get quantitative, we need some chemistry. Here is an approximate reaction for burning hydrocarbons in air:
(CH2)n + 1.5*n O2 + 6n N2 -> n CO2 + n H2O + 6n N2 (n is an integer)
The (CH2)n approximates the fuel, and everything on the right is the exhaust. The atomic masses of hydrogen, carbon, nitrogen and oxygen are in the ratio 1:12:14:16. (Hint: how many kg of exhaust for one kg of fuel?)
A car uses 4.0 kg of (CH2)n hydrocarbon fuel per 100 km while it travels at 100 k.p.h. in a straight line at constant speed. The gas comes out of the (horizontal) exhaust pipe at a speed of v = 50 m.s-1, measured with respect to the car.
What is the magnitude of the force the exhaust gas exerts on the car? (Hint: the exhaust gasses are accelerated in the frame of the car, so ignore the momentum of the incoming gas.)
I got V = 0.6R (R = revolutions), dV/dR = 0.6 And R = 50t, dR/dt= 50 dV/dt=30 I don't know what to do after this.
There seem to be two parts to the question, the first being:
But to answer it you need to use this piece of information provided in the second part:
Where the second part is:
How can you relate the given value of v to your dV/dt and the diameter of the pipe?
Related to Exhaust pipe diameter question
1. What is the purpose of an exhaust pipe diameter?
The exhaust pipe diameter is an important factor in determining the performance and efficiency of a vehicle's exhaust system. It is responsible for directing the exhaust gases out of the engine and releasing them into the atmosphere.
2. How does the diameter of an exhaust pipe affect the performance of a vehicle?
The diameter of an exhaust pipe can greatly impact the performance of a vehicle. A larger diameter pipe allows for a greater volume of exhaust gases to flow out, resulting in increased horsepower and torque. However, if the pipe is too large, it can cause a decrease in backpressure, which can negatively affect the engine's performance.
3. Is a larger exhaust pipe always better?
No, a larger exhaust pipe is not always better. The size of the exhaust pipe should be carefully selected based on the specific vehicle and its engine. Too large of a pipe can cause a decrease in backpressure, resulting in a loss of torque and power.
4. Does the shape of the exhaust pipe affect its performance?
Yes, the shape of the exhaust pipe can affect its performance. A straight pipe with no bends will allow for a more efficient flow of exhaust gases, resulting in better performance. However, some vehicles may require a specific shape or design of the exhaust pipe for optimal performance.
5. How do I determine the right exhaust pipe diameter for my vehicle?
The best way to determine the right exhaust pipe diameter for your vehicle is to consult with a professional mechanic or exhaust specialist. They will be able to assess your vehicle's engine and make a recommendation based on its specific needs and performance goals.
  • Mechanical Engineering
21K
