Misc. Expand balloon with static electricity
The discussion revolves around the concept of expanding an inflated balloon using static electricity by wrapping it in layers of material similar to those used in electrostatic adhesion wall climbing robots. The theory suggests that building up an electrostatic charge on the outer layers would polarize the air inside the balloon, causing it to expand. However, several challenges are highlighted. One major concern is that electrostatic forces diminish quickly with distance, suggesting that a setup with two parallel planes of material might be more effective. Additionally, it is pointed out that within a conducting enclosure, the charge remains uniform, preventing any potential difference that could facilitate expansion. The forces generated by static electricity at practical voltage levels are considered too minuscule to significantly affect the balloon's volume. Overall, while the idea is intriguing, the feasibility of achieving the desired effect through static electricity is questioned.
smiddleton26
TL;DR Summary
Hey guys, I’m trying a weird project. I could use some help confirming the theory before I start.
I want to see if I can expand an inflated balloon using static electricity.
The idea is to wrap a balloon in several layers of material, similar to that used in electrostatic adhesion wall climbing robots, and run power through the layers. The electrostatic charge on the layers outside the balloon will build up and the air inside the balloon will begin to become polarized and begin to cause the balloon to expand.
Any thoughts about this theory would be great! Thanks for the feedback!
Steve
  • Skeptical
  • Wow
Likes Bystander and PeroK
:welcome:
Welcome to PF. :smile:
Can you post a link to that? I'm not familar with it. Thanks.
One problem with using electrostatic forces to expand a baloon is that the electrostatic force falls off quickly with distance. So to get the best effect, it would be better to use two parallel planes of material separated by a small distance. Can you alter your setup somehow to make that optimization?
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elefor.html
smiddleton26 said:
Summary: Hey guys, I’m trying a weird project. I could use some help confirming the theory before I start.
Steve
Sorry, won't work. The charge inside a conducting enclosure is uniform, being uniform there can be no potential difference inside the enclosure.
reference: Gauss's Law; Faraday Shield (Gauss's Law being the main one)
https://www.google.com/search?&q=field+strength+inside+charged+sphere
(at least some of the Utube videos are garbage, stick to the mathematical ones if you are up to it)
Cheers,
Tom
Those crossed over parts turns that sentence to technobabble.
The charge itself has some effect on the balloon, but the forces involved (=> volume change of the balloon) are just minuscule at any practical voltage level.
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Hot Threads
