MHB Expand e^{\frac{z}{z-2}} Laurent Series: z=2
The discussion focuses on expanding the function e^{\frac{z}{z-2}} into a Laurent series around z=2. An initial attempt at expansion includes terms like 1, \frac{z}{z-2}, and higher-order terms, but participants note the need for manipulation before applying the Maclaurin series for e^z. A key insight is rewriting \frac{z}{z-2} as 1 + \frac{2}{z-2}, which leads to a more structured series expansion. The final form of the Laurent series should be expressed as a sum of the form \sum_{n=-\infty}^\infty a_n (z-2)^n, ensuring the coefficients a_n are independent of z. This approach clarifies the necessary steps for a correct expansion.
Stumped1
expand $$e^{\frac{z}{z-2}}$$ in a Laurent series about $$z=2$$
I cannot start this.
my attempt so far has been
$$e^\frac{z}{z-2}=1 + \frac{z}{z-2} + \frac{z^2}{(z-2)^2 2!} + \frac{z^3}{(z-2)^3 3!}$$
This is unlike the other problems I have worked. Seems I need to manipulate this equation some way before plugging into $$e^z$$'s maclaurin series
Thanks for any help with this!
What you have done seems fine...
Because is $\displaystyle \frac{z}{z-2} = 1 + \frac{2}{z-2}$ You obtain...
$\displaystyle e^{\frac{z}{z-2}} =e\ \{ 1 + \frac{2}{z- 2} + \frac{4}{2\ (z-2)^{2}} + ... + \frac{2^{n}}{n!\ (z-2)^{n}} + ...\}\ (1)$
Kind regards
$\chi$ $\sigma$
Note that $f$ must be written in the form
$$\sum_{n=-\infty}^\infty a_n (z-2)^n$$
where $a_n$'s are independent of $z$ as chisigma stated.
