Expanding an action about a background field
In summary: O}(\epsilon^3)}{\epsilon}$$Taking the limit as ##\epsilon## goes to zero, we get:$$\frac{\delta S[\varphi]}{\delta \varphi(x)} = \frac{\delta S[\varphi]}{\delta \varphi(x)} + \frac{1}{2}\int d^dx f(x) \Delta f(x) + \mathcal{O}(f^3)$$Thus, we can see that the quadratic term in the expansion of the action in terms of ##f(x)## becomes ##-\frac{1}{2}\int d^dx f(x) \Delta f(x)##. In summary, the difference in the two
saadhusayn
I refer to the attached set of lecture notes,equation 4.184, P70. We expand an action ##S[\phi]## around a background field ##\varphi(x) = \phi(x) -f(x)##
We need to know how to Taylor expand a functional.
If we expand the action ##S[\phi]## about ##\varphi(x)##,
## S[\phi] = S[\varphi] + \int d^d x \frac{\delta S[\varphi]}{\delta \varphi (x)} f(x) + \frac{1}{2!}\int d^dx_1 d^d x_2 \frac{\delta^2 S[\varphi]}{\delta \varphi(x_1) \delta \varphi(x_2)} f(x_1) f(x_2) + \mathcal{O}(f^3)##
But according to (4.184) I am supposed to get
$$ S[\phi] = S[\varphi] + \int d^d x \frac{\delta S[\varphi]}{\delta \varphi (x)} f(x) - \frac{1}{2}\int d^dx f(x) \Delta f(x) + \mathcal{O}(f^3)$$ The operator ##\Delta## has only been introduced as the Klein Gordon operator before. So how does the quadratic term become
$$-\frac{1}{2}\int d^dx f(x) \Delta f(x)$$
Thank you.
  • 3P5a.pdf
Hello,
Thank you for your post. The difference between the two expressions is due to the different ways of expanding the action. The first expression expands the action in terms of the field ##\varphi##, while the second expression expands the action in terms of the perturbation ##f(x)##. When expanding in terms of ##\varphi##, we use the functional derivatives with respect to ##\varphi##, while when expanding in terms of ##f(x)##, we use the functional derivatives with respect to ##f(x)##.
To understand why the quadratic term becomes ##-\frac{1}{2}\int d^dx f(x) \Delta f(x)##, we can look at the definition of the functional derivative:
$$\frac{\delta S[\varphi]}{\delta \varphi(x)} = \lim_{\epsilon \rightarrow 0} \frac{S[\varphi + \epsilon \delta(x-x')]-S[\varphi]}{\epsilon}$$
If we expand the action around ##\varphi##, we get:
$$S[\varphi + \epsilon \delta(x-x')] = S[\varphi] + \int d^d x \frac{\delta S[\varphi]}{\delta \varphi(x)} \epsilon \delta(x-x') + \frac{1}{2!}\int d^dx_1 d^d x_2 \frac{\delta^2 S[\varphi]}{\delta \varphi(x_1) \delta \varphi(x_2)} \epsilon^2 \delta(x_1-x') \delta(x_2-x') + \mathcal{O}(\epsilon^3)$$
Plugging this into the definition of the functional derivative, we get:
$$\frac{\delta S[\varphi]}{\delta \varphi(x)} = \lim_{\epsilon \rightarrow 0} \frac{\int d^d x' \frac{\delta S[\varphi]}{\delta \varphi(x')} \epsilon \delta(x-x') + \frac{1}{2!}\int d^dx_1 d^d x_2 \frac{\delta^2 S[\varphi]}{\delta \varphi(x_1) \delta \varphi(x_2)} \epsilon^2 \delta(x_1-x') \delta(x_2-x') + \math
Related to Expanding an action about a background field
What is expanding an action about a background field?
Expanding an action about a background field is a technique used in theoretical physics and quantum field theory to simplify calculations. It involves breaking down a complex action into terms that describe the dynamics of a background field and the fluctuations around it.
Why is expanding an action about a background field useful?
Expanding an action about a background field allows for easier and more accurate calculations in theories that involve many interacting fields. It also helps to better understand the dynamics and behavior of the system being studied.
What are the limitations of expanding an action about a background field?
One limitation of this technique is that it is only applicable to theories that have a well-defined background field. It may also not be useful for theories that involve strong interactions or large fluctuations.
How is expanding an action about a background field different from other approximation methods?
Expanding an action about a background field differs from other approximation methods in that it considers the dynamics of the background field as well as the fluctuations around it, while other methods may only focus on one aspect of the system.
Can expanding an action about a background field be applied to any physical system?
No, expanding an action about a background field is only applicable to specific types of systems, such as those described by quantum field theories. It may not be useful for other physical systems, such as classical mechanics or thermodynamics.
