Expanding f(z) with Powers of z-1
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Expanding
In summary, to expand $\displaystyle f(z) =\frac{2z + 3}{z + 1}$ in powers of $z-1$, the substitution $u=z-1$ is used, resulting in $\displaystyle f(u + 1) = \frac{2u + 5}{u + 2}$. The radius of convergence can be found by using the Taylor series expansion or by using the fact that $\frac{1}{1-z}=\sum z^n$. The radius of convergence is found to be 2.
Dustinsfl
2,281
How do I expand $\displaystyle f(z) =\frac{2z + 3}{z + 1}$ in powers of $z-1$?
Use the substitution $u=z-1$ .
Where does the $u$ go?
z=u+1, now find f(z)= f(u+1)
So $\displaystyle f(z) = f(u + 1) = \frac{2u + 5}{u + 2}$.
I am a little confused. How do I expand this to find the radius of convergence? By a Taylor series?
That would be one method. Perhaps simpler is to use the fact that u+2= 2((u/2)+ 1)= 2(1- (-u/2)) and $\frac{1}{1- z}= \sum z^n$ (sum of a geometric series). So $\frac{1}{u+ 2}= \frac{1}{2}\frac{1}{1- (-u/2)}= \frac{1}{2}\sum (-u/2)^n$
So the $R = 2$ then correct?
First series expansion
$f(z)=2+\dfrac{1}{u+2}=2+\dfrac{1}{2}\dfrac{1}{1+u/2}=2+\dfrac{1}{2}\displaystyle\sum_{n=0}^{\infty}(-u/2)^n=2+\dfrac{1}{2}\displaystyle\sum_{n=0}^{\infty}(-(z-1)/2)^n$ ( if 0<|z-1|<2 )
Second series expansion
$f(z)=2+\dfrac{1}{u+2}=2+\dfrac{1}{u}\dfrac{1}{1+2/u}=2+\dfrac{1}{u}\displaystyle\sum_{n=0}^{\infty}(-2/u)^n=2+\displaystyle\sum_{n=0}^{\infty}(-2)^n/(z-1)^{n+1}$ ( if 2<|z-1|<$+\infty$ )
$\displaystyle\frac{1}{2}\sum_n^{\infty}(2z + 3)\left(-\frac{u}{2}\right)^n$
By ratio test,
$\displaystyle \frac{1}{2} \lim_{n\to\infty}\left|\frac{(2z+3)\left(-\frac{u}{2}\right)^{n+1}}{(2z+3)\left(-\frac{u}{2}\right)^n}\right|$
$\displaystyle =\frac{1}{2}\lim_{n\to\infty}\left|\left(-\frac{u}{2}\right)\right|=\frac{1}{4}\left|u\right|<1\Rightarrow\left| u\right| < 4$
Is this not correct?
No, that is not correct. You should not have that "1/2" in front of the limit.
$\displaystyle \lim_{n\to\infty}\left|\frac{(2z+3)\left(-\frac{u}{2}\right)^{n+1}}{(2z+3)\left(-\frac{u}{2}\right)^n}\right|$
$\displaystyle =\lim_{n\to\infty}\left|\left(-\frac{u}{2}\right)\right|=\frac{1}{2}\left|u\right|<1\Rightarrow\left| u\right| < 2$
Is this correct then?
Also, if the 1/2 was part of the factorization, why was it neglected?
I think I have it.
$u = z - 1$
$|z - 1|<2\Rightarrow |x - 1 + yi|<2\Rightarrow \sqrt{(x-1)^2+y^2}<2$
$\Rightarrow (x-1)^2+y^2<4\Rightarrow -1<x<3$ and $-2<y<2$.
Now is this correct?
Assuming this is correct, what would I say the Radius of convergence is?
The radius of convergence is 2 right?
Right.
FAQ: Expanding f(z) with Powers of z-1
What is the purpose of expanding f(z) with powers of z-1?
Expanding f(z) with powers of z-1 allows us to express a complex function as a series of simpler terms, making it easier to analyze and manipulate mathematically.
How do you expand f(z) with powers of z-1?
To expand f(z) with powers of z-1, we use the binomial theorem or the Taylor series expansion. Both methods involve taking the derivative of f(z) and evaluating it at z-1, then multiplying by (z-1)^n where n is the power we are expanding to.
What is the significance of using powers of z-1 in the expansion?
Using powers of z-1 allows us to center the expansion at z=1, making it easier to work with and providing insight into the behavior of the function near that point.
Can we expand f(z) with powers of a value other than z-1?
Yes, the expansion can be centered at any value of z. However, using z-1 is a common choice because it simplifies the algebra and helps us understand the function near the point z=1.
How accurate is the expansion of f(z) with powers of z-1?
The accuracy of the expansion depends on the function and the number of terms we use. Generally, the more terms we include, the more accurate the expansion will be. However, in some cases, the expansion may not converge well and may not accurately represent the original function.
