Expanding the Fraction 1/x(x+1)^2: A Quick Guide for Scientists
  • MHB
  • Thread starter karush
In summary, using partial fraction decomposition, we can expand the fraction $\frac{1}{x(x+1)^2}$ into $\frac{1}{x}-\frac{1}{x+1}-\frac{1}{(x+1)^2}$. This can be done by equating coefficients and solving a system of equations. This approach is faster and easier compared to using the expand function on a calculator. This concept of partial fraction decomposition is commonly taught in precalculus and can be applied in integration in calculus.
karush
MHB
3,269
Expand
$\frac{1}{x\left(x+1\right)^2}
=\frac{-1}{x+1}-\frac{1}{\left(x+1\right)^2}+\frac{1}{x}$
I tried for an hour but no
Mathematics news on Phys.org
Using partial fraction decomposition, we may write:
\(\displaystyle \frac{1}{x(x+1)^2}=\frac{A}{x}+\frac{B}{x+1}+\frac{C}{(x+1)^2}\)
Multiply through by $x(x+1)^2$ to get:
\(\displaystyle 1=A(x+1)^2+Bx(x+1)+Cx=A(x^2+2x+1)+B(x^2+x)+Cx=(A+B)x^2+(2A+B+C)x+A\)
Equating coefficients, we obtain the system:
\(\displaystyle A+B=0\)
\(\displaystyle 2A+B+C=0\)
\(\displaystyle A=1\implies B=-1\implies C=-1\)
Hence:
\(\displaystyle \frac{1}{x(x+1)^2}=\frac{1}{x}+\frac{-1}{x+1}+\frac{-1}{(x+1)^2}=\frac{1}{x}-\frac{1}{x+1}-\frac{1}{(x+1)^2}\)
Has anyone else seen this approach to Partial Fractions?
[tex]\frac{1}{x(x+1)^2}\;=\;\frac{A}{x}+\frac{B}{x+1}+\frac{C}{(x+1)^2}[/tex]
Multiply through by the LCD: .[tex]1 \;=\;A(x+1)^2+Bx(x+1)+Cx[/tex]Now select values of [tex]x[/tex]:
. . [tex]\text{Let }x = -1:\;1 \:=\:A(0) + B(0) + C(-1) \quad\Rightarrow\quad \boxed{C = -1}[/tex]
. . [tex]\text{Let }x = 0:\;\;1 \:=\:A(1) + B(0) + C(0) \quad\Rightarrow\quad \boxed{A = 1}[/tex]
. . [tex]\text{Let }x = 1:\;\;1 \:=\:A(4) +B(2) + C(1) \quad\Rightarrow\quad 1\:=\: (1)4 + 2B +(-1)1 \quad\Rightarrow\quad \boxed{B = -1}[/tex]See? . Isn't this easier and faster?
Why is the demonator expansion of
$$x\left(x+1 \right)^2 $$
$$x, \ \ x+1, \ \ \left(x+1\right)^2 $$
When you were given this problem, did you understand what "expand this fraction" meant? That is, had you been given instruction is "partial fractions"?
this was never covered in class i just have textbook examples and forums
When I was a student in Precalculus/Calc II, we were given various forms for partial fraction decomposition without proof:
Suppose $P(x)$ is a polynomial whose degree is less than that of $Q(x)$.
Case I: Nonrepeated Linear Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{\prod\limits_{i=1}^{n}(a_ix+b_i)}=\sum_{i=1}^{n}\left(\frac{C_i}{a_ix+b_i}\right)$$
Case II: Repeated Linear Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{(ax+b)^n}=\sum_{i=1}^{n}\left(\frac{C_i}{(ax+b)^i}\right)$$
Combining the Cases: When the denominator $Q(x)$ contains distinct as well as repeated linear factors, then we combine the two above cases.
Case III: Nonrepeated Irreducible Quadratic Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{\prod\limits_{i=1}^{n}(a_ix^2+b_ix+c_i)}=\sum_{i=1}^{n}\left(\frac{C_ix+D_i}{a_ix^2+b_ix+c_i}\right)$$
Case IV: Repeated Irreducible Quadratic Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{(ax^2+bx+c)^n}=\sum_{i=1}^{n}\left(\frac{C_ix+D_i}{(ax^2+bx+c)^i}\right)$$
All of the above 4 cases may be combined.
you did this in precalculus?
Yes, we just didn't apply it to integration then...we were told it would be used later on in calculus, but that it was in general a good skill to learn. :)
The reason that expansion works is that, for any A, B, C,
[tex]\frac{A}{x}+ \frac{B}{x+ 1}+ \frac{C}{(x+ 1)^2}= \frac{A(x+ 1)^2}{x(x+ 1)^2}+ \frac{Bx(x+1)}{x(x+ 1)^2}+ \frac{Cx}{x(x+ 1)^2}[/tex]
[tex]= \frac{Ax^2+ 2Ax+ A}{x(x+1)^2}+ \frac{Bx^2+ Bx}{x(x+1)^2}+ \frac{Cx}{x(x+ 1)^2}[/tex]
[tex]= \frac{(A+ B)x^2+ (2A+ B+ C)x+ A}{x(x+ 1)^2}[/tex]
And the three equations, A+ B= p, 2A+ B+ C= q, A= r, are independent so can be solved for A, B, and C for any p, q, and r.
Notice what happens if we try just [tex]\frac{A}{x}+ \frac{B}{(x+ 1)^2}[/tex]. We get [tex]\frac{Ax^2+ 2Ax+ A+ Bx}{x(x+ 1)^2}= \frac{Ax^2+ (2A+ B)x+ A}{x(x+ 1)^2}[/tex] and the equations A= p, 2A+ B= q, A= r are not independent.
thank you, that helped a lot
i normally just use the expand() on the TI not knowing how it was derived.😎
FAQ: Expanding the Fraction 1/x(x+1)^2: A Quick Guide for Scientists
What is the expansion of 1/x(x+1)^2?
The expansion of 1/x(x+1)^2 is 1/x^3 + 2/x^2 + 1/x.
Why is it important to expand this expression?
Expanding this expression allows us to simplify and solve more complex equations involving fractions and exponents.
How do you expand 1/x(x+1)^2?
To expand 1/x(x+1)^2, we can use the formula (a+b)^2 = a^2 + 2ab + b^2. In this case, a = 1/x and b = (x+1). Therefore, the expansion is 1/x^3 + 2/x^2 + 1/x.
Can this expression be further simplified?
Yes, we can further simplify this expression by factoring out a common term of 1/x, resulting in 1/x(x^2 + 2x + 1).
What applications does this expression have in mathematics or science?
This expression is commonly used in calculus to solve problems involving derivatives and integrals. It also has applications in physics and engineering, particularly in the study of rates of change and optimization.
