Expansion difficulty with clearance
In summary, an 80mm aluminum alloy piston fits into a cast iron cylinder with a radial clearance of 0.75mm at 15C temp. The piston and cylinder reach 120C.
german1234
An 80mm aluminium alloy piston fits into a cast iron cylinder with a uniform radial clearance of 0.75mm at 15C temp.the piston and cylinder reach 120C.
1. Determine radial clearance at 120C
2.what is diametral clearance 120C
3.What is change in cross sectional area of piston.
I am given coefficients of linear expansion for both metals.
aluminium alloy: 19x10^-6/C
iron: 10x10^-6/C
I know how to use the formula for linear expansion and area expansion.
Part 1 is what gives me trouble.
I am not sure what radial clearance means.I think it means the gap between the piston and the iron cylinder.
In that case, I can use the formula to find how much the piston expands.
I need to find the expansion of the piston and the expansion of the metal cylinder and take these two answers away from 0.75mm to find the new radial clearance.
My problem is: How do I find the expansion of the iron cylinder?
Part 2:
If I have found the radial clearance, then I can multiply it by 2 and that will give me the diametral clearance?
Part 3:
Change in cross-sectional area:
jjust fill in the formula for this using original cross-sectional area to find new area
If you know how to find the expansion of the aluminum piston, you use the same method (Except that you use the thermal expansion coefficient of iron, not aluminum.)
Don't know if that is what you are asking, post back if you meant to ask something else.
thanks,
I don't know what the original thickness of the iron is, so i can't figure out by how much it expands
Is the 0.75mm the figure i need to use for the iron?
The iron has a radius that is 0.75 mm larger than that of the aluminum.
FAQ: Expansion difficulty with clearance
What is expansion difficulty with clearance?
Expansion difficulty with clearance refers to the challenges faced when trying to expand or grow a business or project while also obtaining the necessary legal permissions or approvals. This can include obtaining permits, licenses, or other forms of clearance from government agencies or other authorities.
Why is expansion difficulty with clearance important?
Expansion difficulty with clearance is important because failing to obtain the necessary clearances and approvals can result in legal issues, fines, or delays in the expansion process. It is also important for ensuring compliance with laws and regulations and maintaining the integrity and reputation of the business or project.
What are some common challenges associated with expansion difficulty with clearance?
Some common challenges associated with expansion difficulty with clearance include navigating complex legal and regulatory processes, understanding and meeting requirements and criteria for clearances, and addressing any potential objections or opposition from stakeholders or community members.
How can one address expansion difficulty with clearance?
One can address expansion difficulty with clearance by thoroughly researching and understanding the requirements and processes for obtaining clearances, developing a comprehensive plan and timeline for meeting these requirements, and seeking guidance and support from legal professionals or consultants if necessary.
Are there any tips for avoiding or minimizing expansion difficulty with clearance?
Some tips for avoiding or minimizing expansion difficulty with clearance include proactively engaging with relevant authorities and stakeholders, conducting thorough due diligence and risk assessments, and maintaining open and transparent communication throughout the expansion process.
