I Expansion of 1/|x-x'| into Legendre Polynomials
The discussion centers on the expansion of the function 1/|x - x'| using Legendre polynomials and geometric series. There is confusion regarding the equivalence of this function to two different expressions based on the values of x and x'. It is clarified that the function is not equal to both expressions simultaneously; rather, it depends on which variable is larger. The expression involving Θ(x - x') serves to summarize the two cases succinctly. Understanding this distinction is crucial for proper application in the context of the discussion.
deuteron
TL;DR Summary
we know that we can expand the following function in Legendre polynomials in the following way
in the script given yo us by my professor, ##\frac 1 {|\vec x -\vec x'|}## is expanded using geometric series in the following way:
However, I don't understand how ##\frac 1 {|\vec x -\vec x'|}## is equal to both the above, and the below:
Do you understand the meaning of ##\Theta(x-x')##?
It's not equal to both. It's equal to one or the other depending on which of ##x## and ##x'## is larger. The bottom expression summarizes in one line the two "für" cases above it.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
