Expansion of space affecting photon's energy
In summary, a photon's energy, frequency, and wavelength depend on the frame of reference of the detection device. The expansion of space also affects the measured energy of a photon, resulting in redshift. In a medium, the propagation of an electromagnetic wave is affected by the electromagnetic field, resulting in a reduced speed of light. Energy is not conserved in an expanding universe. The position of a photon cannot be defined until it interacts with something. It is better thought of as a spread out wave.
stuart100
TL;DR Summary
Light is travelling as a photon, what extent is change in journey distance affecting wavelength
given it's only at one place at a time? Also, a reduction in frequency is a reduction in energy, so how and where is that energy gone?
On a long trip the photon goes, but it occupies a wavelength of space at any particular time. If the space between start and finish (inspection) is expanding all the way all the journey time, then most of the expansion has no effect on the photon. Like eg second tenth is section currently passed thru, but the effect takes place on the other say ninety percent all the total time period. So, did I get that right? Also, the photon lost energy by reducing it's frequency but where went the energy? And, in the vicinity of that proton within a wavelength, does space expand? Last, why does light travel below c in a medium? Is it curving next to atoms because space is not empty?
Space news on Phys.org
stuart100 said:
Summary:: Light is traveling as a photon, what extent is change in journey distance affecting wavelength
Energy is, and always has been, dependent on the frame of reference. A photon does not have a definitive energy (or a definitive frequency or wavelength). Its energy, frequency and wavelength depend on the frame of reference of the detection device. It's true, of course, that a photon has a specific energy relative to its source - but its energy if measured depends on the relationship between the source and the detector. E.g. if the source and detector are in relative motion, then the energy of the photon may be greater or less than the energy if measured at the source.
The expansion of space also creates a relationship between the source of light and where it is detected. In an expanding universe, this results in a reduction of the measured energy the further from the source a photon is detected. This is called redshift. This can be equated to a "recession" velocity, so in some sense it is not fundamentally different from the redshift associated with simple motion between source and receiver.
In that sense, the energy does not "go anywhere". That said, in an expanding universe, energy is not necessarily conserved. The conservation of energy fundamentally is a consequence of time symmetry - which is lost in an expanding universe.
On your final question, the best answer is to consider light as an electromagnetic (EM) wave. It travels through vacuum at ##c##. In a medium, however, if it can travel at all, the propagation of the wave is affecetd by the electromagnetic field within the medium. Ultimately, EM fields must satisfy Maxwell's equations and this results in a reduced speed for propagation of an EM wave through a medium.
Likes stuart100 and PAllen
Not true. The position of a photon cannot be defined until it interacts with something. Until then, it is better thought of as being a large, spread out wave, possibly of more than one wavelength.
If I remember correctly, a very simplified answer is that the incoming EM wave interacts with electric charges in the medium and these charges create another EM wave that interferes with the original in such a way as to slow it down.
Thanks for the info, especially; "This can be equated to a 'recession' velocity, so in some sense it is not fundamentally different from the redshift associated with simple motion..." I keep forgetting how fuzzy things get in the micro. So, even though the distance ahead of the photon expands in the journeytime, the whole effect self-determines based on source-detector relationship? On the last point, I suspected your explanation.
Thanks. I did suspect something like that given the photon is an EM wave. With the universe running on probabilities it's doing very well. I guess space over billions of light years is not a sufficiently dense medium to produce an apparent slowdown.
stuart100 said:
The whole effect self-determines based on source-detector relationship?
The redshift calculation in an expanding universe is remarkably simple. It boils down to:
$$\frac{\lambda_r}{\lambda_s} = \frac{a(t_s)}{a(t_r)}$$where ##\lambda_r, \lambda_s## are the measured wavelength at the receiver and the wavelength emitted at source, and ##a(t_r), a(t_s)## are the universal scale factor at the times received ##t_r## and emitted ##t_s##.
In an expanding universe, ##a(t)## increases over time, so the measured wavelength of light gets longer the further it travels.
PS ##t## is so-called comoving time. And we assume the light is emitted and received by comoving objects. The Earth is almost comoving; as are most distant objects.
Is there really a consensus to say that energy is not conserved in GR ?
For example, according to A. Guth, during inflation, the density is constant while the universe is exponentially expanding, and this does not violate energy conservation because negative gravitational energy is produced at the same time. For a flat universe, the total energy is constant and 0.
Considering the photons, may their energy loss due to the expansion be considered as going into the gravitational potential, slowing down the expansion? Indeed the expansion is slower for a radiation-dominated universe than for a matter-dominated one (time power 1/2 versus 2/3 respectively).
The short answer is "no". The slightly longer answer is "it's complicated".
@pervect made a good post on this in another recent thread:
https://www.physicsforums.com/threads/is-gravity-a-force.1008409/post-6557489
Both of the references he gives there are worth reading in full.
The problem with this (for those physicists who think it's a problem) is that there is no invariant way to define the "negative gravitational energy" Guth is talking about. (In more technical language that goes beyond a "B" level discussion, but you'll see it if you start digging into more advanced sources, there is no way to define a tensor for "gravitational energy". You can define various pseudo-tensors that capture aspects of "gravitational energy", but all of them depend on particular coordinate choices and different physicists who like the "gravitational energy" concept prefer different ones.)
Some physicists (of whom Guth might be one) might describe it this way. But again, there is a problem (for those physicists who think it's a problem): the concept of "gravitational potential", if you try to make it rigorous, is only well-defined in a stationary spacetime, and the spacetime of an expanding universe is not stationary. So using the concept of "gravitational potential" this way in an expanding universe is really just hand-waving that falls apart on closer inspection.
More precisely, the deceleration is larger for a radiation dominated universe. The reason for this, if you want a reason that will stand up to a more rigorous treatment (unlike the "energy loss" reason I discussed above), is that pressure gravitates, and a radiation dominated universe has pressure equal to 1/3 the energy density, while a matter dominated universe has zero pressure. (More precisely, negligible pressure compared to the energy density.) So, given the same energy density, a radiation dominated universe will "gravitate more" and hence decelerate the expansion more.
Likes mbond, Bandersnatch, anorlunda and 1 other person
The photon emitted for say a remote hydrogen atom can be calculated, and is the same as one emitted locally. This does not change with the frame of reference, both are local to the event and give the same result. I I measured it at both ends, I will measure a different energy, and there is a loss. How does this happen, and how much it challenges how we define energy in relation to wavelength other than locally?
  • Skeptical
Likes PeroK
The curvature of space means that there's a changing inner product between the worldlines of local co-moving observers and that of a travelling light pulse, which is not the case in flat spacetime. This is no challenge to how we define energy, since that's frame dependent anyway as already noted, and you can only measure it locally.
Likes Hyperfine
The socalled "photon" is described by it's four-momentum vector ##q^{\mu}##, fullfilling ##g_{\mu \nu}(x) q^{\mu} q^{\nu}=0##. To get the measured energy you need the four-velocity ##u^{\mu}## of the detector, normalized such that ##g_{\mu \nu}(x) u^{\mu} u^{\nu}=c^2##. Then the energy of the photon measured by this detector is
$$E_{\gamma}=\hbar \omega_{\gamma}=g_{\mu \nu}(x) q^{\mu} u^{\nu}.$$
Also this is, of course, independent of the choice of coordinates/reference frames as it must be for a measured quantity.
This formula implements both the gravitational frequency shift as well as the Doppler effect for moving detectors.
For a detailed treatment of electromagnetic waves in GR, particularly in FLRW spacetime, see
https://itp.uni-frankfurt.de/~hees/pf-faq/gr-edyn.pdf
This also clarifies, who to understand the "naive photon picture", which is unfortunately used without clear definitions in most textbooks. It's to be understood as the geomtric-optic approximation (leading-order eikonal approximation) of Maxwell's equations for (free) em. fields.
Likes Klystron
FAQ: Expansion of space affecting photon's energy
How does the expansion of space affect a photon's energy?
The expansion of space does not directly affect a photon's energy. However, as space expands, the distance between objects also increases. This means that the wavelength of a photon traveling through expanding space will also increase, resulting in a decrease in its energy.
Can the expansion of space cause a photon's energy to change over time?
Yes, the expansion of space can cause a photon's energy to change over time. As the universe continues to expand, the wavelength of a photon will continue to increase, leading to a decrease in its energy. This phenomenon is known as cosmological redshift.
Does the expansion of space affect all types of photons?
Yes, the expansion of space affects all types of photons, including visible light, radio waves, and X-rays. This is because all photons have a wavelength and are subject to the same laws of physics.
Can the expansion of space cause a photon to disappear?
No, the expansion of space does not cause photons to disappear. However, as the universe continues to expand, the wavelength of a photon may become so long that it is no longer detectable by our current technology, making it appear to disappear.
How does the expansion of space relate to the redshift of galaxies?
The expansion of space is directly related to the redshift of galaxies. As space expands, the distance between galaxies increases, causing their light to be stretched to longer wavelengths, resulting in a redshift. This is one of the key pieces of evidence for the expansion of the universe.
