Expansion of the Universe
In summary, the expansion of the universe refers to the phenomenon where galaxies are moving away from each other over time, indicating that the universe is growing larger. This concept, first observed by Edwin Hubble in the 1920s, is supported by the redshift of light from distant galaxies, which shows that they are receding. The expansion is driven by a mysterious force known as dark energy, which constitutes a significant portion of the universe's total energy density. The rate of expansion is described by Hubble's Law, which relates the distance of galaxies to their recessional velocity. Understanding this expansion is crucial for cosmology, as it provides insights into the universe's origin, structure, and ultimate fate.
petercl14
TL;DR Summary
accelerating expansion of the universe
Einstein's equations in general relativity indicate that the universe is expanding. Einstein himself believed that the universe should be stable so he introduced a correction to his equations which made for a static universe. He later admitted that was his biggest blunder. Hubble proved by observation that the universe was indeed expanding.
Latest observations are that the universe is expanding at an accelerating pace. Faster than in the past. Scientists are now trying to introduce a new phenomenon called dark energy to account for this.
As the universe expands galaxies become further apart. There is less gravitational attraction between them. Thus the universe will expand at an accelerating rate. There is no need to introduce another non entity like dark matter and call it dark energy.
Space news on Phys.org
See, the first two sentences are fine. But the third doesn't follow - not without dark energy. Without dark energy a universe with any amount of mass in it must always decelerate, much like a ball thrown out of a gravity well must always decelerate even as the gravitational potential monotonically decreases. I.e. there is always some attraction, invariably acting to slow the galaxies down - because gravity can't be repulsive.
To get acceleration you need something repulsive to take over once the mass density goes down sufficiently. That's what dark energy does.
Likes Klystron, DAH, Vanadium 50 and 2 others
No, this is not correct. As can easily be seen from the Friedmann Equations, which are just the Einstein Field Equations for the case of a homogeneous, isotropic, expanding universe, a universe that only contains matter and radiation, with no dark energy, will have decelerating expansion.
I did a google search for:
The Implications of Hubble's Law: An Expanding Universe
e-education.psu.edu
Here is the opening paragraph:
"Like Kepler's Laws, Hubble's Law is an empirical law. Hubble discovered a relationship between two measurable properties of galaxies: their velocities and their distances. Given this relationship, though, it naturally leads to several questions. These questions are:
  • What is the cause of this relationship?
  • Why should more distant galaxies have larger velocities?"
As a layman, I found the article's information to be informative, thought provoking, and relevant.
(Mods - if my post has violated any rules, I assure you that I am posting in good faith, and I ask for your understanding.)
Likes PeroK
e-education.psu.edu
One difference between Kepler and Hubble is that Kepler took 20 years to work through an enormous amount of data on planetary motion before finally proving that the orbits were elliptical relative to the Sun. Hubble, on the other hand, took a huge guess based on a small sample of inconclusive data. The data that really confirms Hubble's law only came out years afterwards. But, by then, his was the name on it. The two sides of experimental science and gaining immortality!
Likes Hyku
petercl14 said:
TL;DR Summary: accelerating expansion of the universe
Your argument fails for the same reason that the following argument fails:
"As a rocket ascends, it moves away from Earth. There will be less gravitational attraction between Earth and the rocket. Thus, the rocket will move away from Earth at an accelerating rate and will not require additional fuel expenditure."
Likes Hyku and phinds
I believe the current effect is that the deceleration of the expansion is slowing, not that the rate of expansion is increasing. A bit like gradually applying less force on the brakes when stopping your car. You decelerate hard at first, then less and less over time. The current rate of expansion is less than in the past.
@PeterDonis is that correct?
If by "the rate of expansion" we mean ##\dot{a}##, i.e., the rate of change of the scale factor with respect to the proper time of comoving observers, and by "acceleration" we mean ##\ddot{a}##, the rate of change of ##\dot{a}## with respect to that same proper time, then the acceleration now is positive, ##\ddot{a} > 0##, and has been so for a few billion years. This is what we would expect if dark energy dominates the dynamics, i.e., if dark energy density is larger than all of the others combined (IIRC it's about twice as large now as all the others combined).
The misconception in the OP has been corrected. Thread closed.
PeterDonis said:
AFAIK, if by "the rate of expansion" we mean ##\dot{a}##, i.e., the rate of change of the scale factor with respect to the proper time of comoving observers, and by "acceleration" we mean ##\ddot{a}##, the rate of change of ##\dot{a}## with respect to that same proper time, then the acceleration now is positive, ##\ddot{a} > 0##, and has been so for a few billion years. This is what we would expect if dark energy dominates the dynamics, i.e., if dark energy density is larger than all of the others combined (IIRC it's about twice as large now as all the others combined).
Ah, well nevermind then. I thought I had read otherwise.
FAQ: Expansion of the Universe
What is the Expansion of the Universe?
The expansion of the universe refers to the phenomenon where galaxies are moving away from each other over time, indicating that the space between them is growing. This concept is primarily derived from observations of redshift in distant galaxies, which suggests that the universe has been expanding since the Big Bang, approximately 13.8 billion years ago.
What evidence supports the expansion of the Universe?
Key evidence for the expansion of the universe includes the redshift of light from distant galaxies, which shows that they are moving away from us. This was first observed by Edwin Hubble in the 1920s. Additionally, the Cosmic Microwave Background Radiation (CMB) provides a snapshot of the early universe, supporting the idea of an expanding cosmos. Observations of Type Ia supernovae also indicate that the rate of expansion is accelerating.
What is the Big Bang Theory?
The Big Bang Theory is the leading explanation for the origin of the universe. It posits that the universe began as an extremely hot and dense point approximately 13.8 billion years ago and has been expanding ever since. As the universe expanded, it cooled, allowing for the formation of subatomic particles and later atoms, leading to the creation of stars and galaxies.
What is dark energy and its role in the expansion of the Universe?
Dark energy is a mysterious form of energy that makes up about 68% of the universe and is believed to be responsible for the accelerated expansion of the universe. While its exact nature is still unknown, dark energy acts as a repulsive force, counteracting the gravitational pull of matter and causing galaxies to move away from each other at an increasing rate.
Will the expansion of the Universe continue forever?
The future of the universe's expansion is still a topic of research and debate among scientists. Current observations suggest that the expansion will continue indefinitely, leading to a scenario known as the "Big Freeze," where galaxies drift apart and stars eventually burn out. However, other theories propose different outcomes, such as a potential "Big Crunch" or "Big Rip," depending on the properties of dark energy and the overall density of the universe.
