Expansions in thermodynamics using differentials
In summary, the tension in the rail decreases by 50K between night and day. However, if the rail is free to expand, its length changes by 8x10-6K between night and day.
  • #36
voko said:
Then the RHS is not an integral over a single path such as L = L(T).
So, for example, in the other equation I had when I rearranged dF = X dT + YdL for dL, I got $$\frac{\partial F}{\partial L} dL = - \frac{\partial F}{\partial L} dL,$$ where in this case L = L(T) so that this becomes $$\frac{\partial F(L,T)}{\partial L(T)} L'(T) dT = -\frac{\partial F(L,T)}{\partial T(L)} T'(L) dL$$ Provided L=L(T), this eqn then makes sense. Is this what you meant?
Because ##dF## is a full differential, you can say that you can integrate over any path and the result will be the same, provided the endpoint are the same.
Can you point me to a proof of this?
But this corresponds to $$ F_2 - F_1 = \int_{T_1}^{T_2} F_T(L_1, T) dT + \int_{T_1}^{T_2} F_L(L_1, T) L'(T) dT + \int_{L_1}^{L_2} F_T(L, T_2) T'(L) dL + \int_{L_1}^{L_2} F_L(L, T_2) dL \\ = \int_{T_1}^{T_2} F_T(L_1, T) dT + \int_{L_1}^{L_2} F_L(L, T_2) dL $$
Is your use of notation ##F_T## standard, ##F_T = \frac{\partial F}{\partial T}##? Is that top line, the general form of ##F_2 - F_1## and then by the choice of path, you were then able to say the middle terms were zero and so arrived at the bottom line?
Observe this is different from what you had earlier.
Different in the sense that I said the value of T in the second term was T1 above?
  • #37
The differential equation makes sense without regard to any path. What I meant is that in your previous integration attempt, you had the (L, T) point follow different paths in the two integrals, and it was not obvious that those are just parts of a bigger path, with some other segments of the path evaluating to zero.
This is a corollary of Green's theorem in 2D, and Stoke's theorem in higher dimensions. This is also what makes "potential energy" possible as a concept.
All correct.
  • #38
How so?
  • #39
Refer to #33. What paths are followed by (L, T) in the RHS terms?
  • #40
In #33, I wasn't referring to a path. I just knew that ##F_i## would be ##(L_i, T_i)## for i = 1,2. and integrated by just considering the end points since dF was path independent.
(I've noticed at the back of my book an appendix which gives a couple of arguments to illustrate when and when not a differential is exact)
Going back to the eqn at the top of #36, does it not need to be the case that L=L(T) for that eqn to make sense?
  • #41
When you integrate something whose dim > 1, you always have a path (or surface, or hypersurface) involved - that's how an integral is defined. In your original attempt you could say the paths were different simply because the end points were different.
Yes and no. The differential of ##f(x)##, where ##x## is a vector, is defined as ##h(x, dx)## such that ##f(x + dx) - f(x) = h(x, dx) + r(x, dx)##, where ##h(x, dx)## is linear in the second argument, and ##\lim r(x, dx)/|dx| = 0##. Because of the linearity in ##dx## it can be written in terms of its components, traditionally, as ##f(X + dX, Y + dY) - f(X, Y) ≈ f_X dX + f_Y dY##, which looks as if ##dX## and ##dY## were completely independent; but they must in fact be components of the infinitesimal vector ##dx##. So not only is ##dY = dY(dX)## here, it is even stronger: ##dY = k dX##, so you do not really have to think about the path when you deal with the differential form. And when ##x## is itself a function of something else, the same applies to its differential, and we end end up with a product of two linear maps, which is again linear, so the result holds, which basically means we can use the chain rule. This is sometimes called the invariance of (first order) differentials.
  • #42
Thanks voko, I appreciate the help.
When we started with ##dF = F_T dT + F_L dL## and for part B), dF = 0 we then had ##0 = F_T dT + F_L dL \Rightarrow F_T dT = -F_L dL## Is it correct to say that this equation is true for any path taken between ##(L_1, T_1)## and ##(L_2, T_2)## since it is really the same as evaluating ##0 = F_T dT + F_L dL ## which is path independent.
  • #43
Correct.
Likes 1 person
  • Differential Geometry
