Expectation values of unbounded operator
In summary, The author discusses the concept of rigged Hilbert space in relation to unbounded operators and their domains. He states that the non-invariance of the domain under the action of the operator can make expectation values ill-defined on the whole Hilbert space. The author also clarifies that this does not apply to all expectation values, specifically for ##A^2## as mentioned in the equation following the discussion.
Ravi Mohan
196
I am reading an intriguing article on rigged Hilbert space
http://arxiv.org/abs/quant-ph/0502053
On page 8, the author describes the need for rigged Hilbert space. For that, he considers an unbounded operator [itex]A[/itex], corresponding to some observable in space of square integrable functions [itex]\mathcal{H} [/itex], with the domain [itex]\mathcal{D}(A) [/itex]. The author states that in general, [itex] \mathcal{D}(A)[/itex] does not remain invariant under the action of [itex]A[/itex].
Now the author claims that such non-invariance makes expectation values ill-defined on the whole Hilbert space [itex]\mathcal{H}[/itex].
I am not able to understand the claim.
Let us consider [itex]\phi\in\mathcal{D}(A) [/itex]. Due to invariance, [itex]\psi=A\phi[/itex] may not belong to [itex]\mathcal{D}(A) [/itex], but it remains in [itex]\mathcal{H}[/itex]. Thus the expectation value [itex](\phi,A\phi)=(\phi,\psi)[/itex] should be well defined (or am I doing something wrong?).
You are right. I suppose he means expectation values of ##A^2## as appearing in the next equation.
Thank you for clearing that.
FAQ: Expectation values of unbounded operator
What is an expectation value of an unbounded operator?
An expectation value of an unbounded operator is a mathematical concept used in quantum mechanics to calculate the average value of a measurable quantity of a system. It is the average of all the possible outcomes of a measurement, weighted by their respective probabilities.
How is an expectation value of an unbounded operator calculated?
The expectation value of an unbounded operator is calculated by taking the inner product of the state vector of the system and the operator, and then taking the inner product of the resulting vector with its complex conjugate. This can be represented mathematically as ψ|A|ψϢ, where ψ is the state vector, and A is the operator.
What is the significance of the expectation value of an unbounded operator?
The expectation value of an unbounded operator is significant because it provides a way to determine the most probable outcome of a measurement for a given quantum system. It also allows for the calculation of other important physical properties, such as energy and momentum.
Can the expectation value of an unbounded operator be negative?
Yes, the expectation value of an unbounded operator can be negative. This means that the most probable outcome of a measurement can be a negative value. However, it is important to note that this does not necessarily mean that the measured value will be negative, as it is a probabilistic calculation.
How does the expectation value of an unbounded operator relate to uncertainty?
The expectation value of an unbounded operator is related to uncertainty through the Heisenberg uncertainty principle. This principle states that the product of the uncertainties in two complementary properties, such as position and momentum, cannot be smaller than a certain value. The expectation value of an unbounded operator can help determine the uncertainties in these properties for a given quantum system.
