I Expected coefficient change from simple to multiple linear regression
The discussion centers on the impact of moving from simple to multiple linear regression models, particularly regarding coefficient changes for predictors when multicollinearity is present. It is noted that coefficients for predictors can change in both magnitude and sign when included together in a multiple regression model, especially due to multicollinearity among the predictors. Even in the absence of multicollinearity, random variations in the data can lead to unexpected sign changes in coefficients. The conversation also clarifies that correlation, rather than causation, defines multicollinearity, and deterministic relationships between variables, like a variable and its square, do not inherently imply multicollinearity. Overall, understanding these dynamics is crucial for accurate interpretation of regression models.
fog37
TL;DR Summary
understand the expected coefficient change (magnitude and sign) from simple to multiple linear regression
Hello forum,
I have created some linear regression models based on a simple dataset with 4 variables (columns). The first models simply involve one predictor variable: $$Y=\beta_1 X_1+\beta_0$$ and $$Y=\beta_2 X_2+ \beta_0$$
The 3rd model is multiple linear regression model involving the 3 predictors: $$Y= \beta_3 X_3 + \beta_2 X_2 + \beta_1 X_1 + \beta_0$$
I believe that the coefficient ##\beta_1## or ##\beta_2## for the predictors ##X_1## and ##X_2## change in magnitude when the two predictors are included together in the multivariate model (model 3), correct? What about the sign of those coefficients? Should the sign stay the same or can it possibly change?
I would think that the sign should remain the same to indicate that the variable ##Y## and ##X_1## (or ##X_2##) vary in the same direction in both the simple and multiple linear regression models...
Now, if multicollinearity is present, the coefficients for each predictor would certainly change in magnitude and sign from the coefficients in the simple linear regression model but not in the correct way due to the inter-variable correlation...
Thanks
I agree with you but with a couple of caveats:
  1. In real-world models, multicollinearity (correlation between the explanatory variables ##X_1,X_2,X_3##) is usually present, which undermines the expectation stated in your second last para.
  2. Even without genuine multicollinearity, random idiosyncratic variation in the sample can make an appearance of multicollinearity, in which case we can still get sign changes of coefficients. This will not usually happen, but it will sometimes. The larger the data set, the less often it will happen.
Thanks for the quick and interesting reply. I am indeed surprise to learn that even, without any multicollinearity, a change in coefficient sign may be possible when the same variables of interest are present in both a simple and in a multiple regression model...
In regards to multicollinearity, my understanding is that it affects the coefficients' values in strange ways. I recently learned that, in the case of a model with a term ##X## and a quadratic term ##X^2##, like $$Y=\beta_1+\beta_2 X^2$$ it seems that multicollinearity would not be a problem if ##X## and ##X^2## are dependent (even if not linearly dependent). Isn't the fact that one variable changing causes an change in the other variable the prime definition of multicollinearity?
No, they just have to be correlated. Causation is not part of the definition (eg see here). A common situation is where the correlation arises from each of the explanatory variables being driven ("caused") by another variable that may not be part of the set of explanatory variables. eg in a regression that had population crime levels and sickness levels as explanatory variables, we would likely find that those two are correlated because driven by a third variable of average population wealth, which may not be in the explanatory variables.
Sure, sorry, I used "cause" inadvertently. But just the fact that ##X## and ##X^2## are deterministically dependent terms would make me think that structural collinearity would emerge from them...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
