MHB Expected value and equality to sums
The discussion centers on demonstrating the equality of the expected value of a non-negative integer-valued random variable, expressed as E[N] = ∑ P{N ≥ k} = ∑ P{N > k}. Participants explore the use of indicator random variables to express this relationship, with one member suggesting that the expectation can be understood through the probabilities of outcomes exceeding a certain value. Additionally, various mathematical identities are mentioned that may aid in proving the equality. The conversation encourages sharing solutions to benefit others facing similar questions.
WMDhamnekar
MHB
How to show that$E[N]=\displaystyle\sum_{k=1}^\infty P{\{N\geq k\}}=\displaystyle\sum_{k=0}^\infty P{\{N>k\}}$
If any member here knows the answer, may reply to this question.:confused:
Mathematics news on Phys.org
Hello,
'N' denote a non-negative integervalued random variable.
Hello,
Hello,
I got the answer after doing some carefully thinking.
Hello,
Perhaps yu'd like to share your solution so that others facing the same or similar question can benefit from your work?
Hello,
If we define the sequence of random variable $I_n$ (Indicator random variable), n > 1 by
$$I_n= \left \{ {1,\text{if n < X} \atop \text{0, if n>X}} \right.$$. Now express X in terms of $I_n.$ (Actually, I don't know how to express in terms of $I_n$:confused:)
I understood the equation in #1 by using the expectation of random variable X(outcome of a toss of a fair dice)is equal to summation of the probabilities of X > n, where range of n is 0 to $\infty$
I think the following below mentioned identities will be useful here.
$$ a)(1-1)^N= \left \{{\text{1, if N > 0}\atop \text{0, if n < 0}} \right.$$
$$b)(1-1)^N=\displaystyle\sum_{n=0}^n\binom{N}{i}*(-1)^i$$
$$ c)1-I=\displaystyle\sum_{n=0}^n\binom{N}{i}*(-1)^i$$
$$ d)I=\displaystyle\sum_{n=1}^n\binom{N}{i}*(-1)^i$$
If you want to show this equation in mathematical language, you may reply to that effect.:)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
