Expected value of X*exp(X) for X normally distributed
In summary, the conversation discusses the computation of expected value for a random variable X with a standard exponential distribution. The formula for calculating this value involves integrating a complex expression, which may not be easily solved using traditional methods. However, using WolframAlpha and completing the square, an exact result can be obtained for the standard distribution with mean 0 and standard deviation 1.
TaPaKaH
54
Assume we have [itex]X\sim\exp(\mu,\sigma^2)[/itex].
How does one compute [itex]\mathbb{E}\left(Xe^X\right)[/itex] and/or what is the outcome value?
The definition would say that
$$\mathbb{E}[ X e^X ] = \int_{-\infty}^{\infty} x e^{x} e^{-(x - \mu)^2 / \sigma^2} \, dx$$
That's a tricky one, I don't think any of the common integration strategies really work.
WolframAlpha does give me an exact result for the standard distribution ##(\mu, \sigma) = (0, 1)##.
Maybe this will also help.
Sorry for the incomplete answer, hoping that this will get you started.
Rewrite ##\exp(x)\exp(-(x-\mu)^2/(2\sigma^2))## as ##\exp(x-(x-\mu)^2/(2\sigma^2)) = \exp((2\sigma^2x-(x-\mu)^2)/(2\sigma^2))##. Now complete the square so that you get ##a\exp(-(x-\mu')^2)/(2\sigma^2))##, where ##a## is the exponential of the nasty junk you had to add to complete the square and ##\mu'## has the effect of being a new mean.
Likes 2 people
Very nice one, and congratulations on post number 13,000!
To compute the expected value of X*e^X, we can use the formula for the expected value of a continuous random variable, which is given by:
\mathbb{E}\left(Xe^X\right) = \int_{-\infty}^{\infty}x*e^x*f(x)dx
Where f(x) is the probability density function of X. In this case, since X is normally distributed, its probability density function is given by:
f(x) = \frac{1}{\sigma\sqrt{2\pi}}e^{-\frac{(x-\mu)^2}{2\sigma^2}}
Substituting this into the formula, we get:
\mathbb{E}\left(Xe^X\right) = \int_{-\infty}^{\infty}x*e^x*\frac{1}{\sigma\sqrt{2\pi}}e^{-\frac{(x-\mu)^2}{2\sigma^2}}dx
To solve this integral, we can use integration by parts, where u = x*e^x and dv = \frac{1}{\sigma\sqrt{2\pi}}e^{-\frac{(x-\mu)^2}{2\sigma^2}}dx. This gives us:
\mathbb{E}\left(Xe^X\right) = \left[x*e^x*\frac{1}{\sigma\sqrt{2\pi}}e^{-\frac{(x-\mu)^2}{2\sigma^2}}\right]_{-\infty}^{\infty} - \int_{-\infty}^{\infty}e^x*\frac{1}{\sigma\sqrt{2\pi}}e^{-\frac{(x-\mu)^2}{2\sigma^2}}dx
The first term in this expression evaluates to 0, since the exponential function goes to 0 as x approaches either infinity. The second term can be simplified using the fact that the integral of the normal density function over its entire support is equal to 1. This gives us:
\mathbb{E}\left(Xe^X\right) = \frac{1}{\sigma\sqrt{2\pi}}\int_{-\infty}^{\infty}e^x*e^{-\frac{(x-\mu)^2}{2\sigma^2}}dx
FAQ: Expected value of X*exp(X) for X normally distributed
What is the expected value of X*exp(X) for X normally distributed?
The expected value of X*exp(X) for X normally distributed is equal to the mean of X multiplied by the expected value of exp(X), which is equal to e^(mu + sigma^2/2), where mu is the mean of X and sigma^2 is the variance of X.
2. How is the expected value of X*exp(X) calculated for a normal distribution?
The expected value of X*exp(X) for a normal distribution can be calculated using the formula e^(mu + sigma^2/2), where mu is the mean of X and sigma^2 is the variance of X. This formula is based on the properties of the exponential function and the fact that the expected value of a constant times a random variable is equal to the constant times the expected value of the random variable.
3. What is the relationship between the expected value of X*exp(X) and the mean of X?
The expected value of X*exp(X) is equal to the mean of X multiplied by the expected value of exp(X). Therefore, the expected value of X*exp(X) is directly proportional to the mean of X. This means that as the mean of X increases, the expected value of X*exp(X) also increases, and vice versa.
4. Is the expected value of X*exp(X) affected by the variance of X?
Yes, the expected value of X*exp(X) is affected by the variance of X. This is because the expected value of exp(X) is equal to e^(mu + sigma^2/2), where sigma^2 is the variance of X. Therefore, as the variance of X increases, the expected value of exp(X) also increases, which in turn increases the expected value of X*exp(X).
5. How can the expected value of X*exp(X) be used in practical applications?
The expected value of X*exp(X) can be used in various practical applications, such as in finance and risk management. In finance, it can be used to calculate the expected return of a portfolio of investments with normally distributed returns. In risk management, it can be used to calculate the expected loss or gain of a particular investment or strategy. It can also be used to estimate the expected value of a product or service with normally distributed demand or revenue.
