I Expected value of X~Geom(p) given X+Y=z
  • I
  • Thread starter Thread starter BerriesAndCream
    Geometric Value
The discussion centers on calculating the expected value E[X|Z=z] for independent geometric random variables X and Y, where Z=X+Y. The user derives that P(X=x|Z=z) equals 1/(z-1) and attempts to find E[X|Z=z] using this distribution. They conclude that E[X|Z=z] equals z/2, confirming the validity of their calculations. The conversation also touches on whether E[X|Z=z] or E[Y|Z=z] is larger, with the implication that both expected values are equal due to the uniform distribution of P(X=x|Z=z). The thread emphasizes the use of formulas for expected values in discrete uniform distributions for such calculations.
BerriesAndCream
TL;DR Summary
finding a conditioned expected value
Hello everyone.
If X, Y are two independent geometric random variables of parameter p, and Z=X+Y, what's E[X|Z=z]?
I have calculated the distribution of P(Z=z) and I have then found that the conditional probability P(X=x|Z=z) equals 1/(z-1).
How can I now find the conditioned expected value?
What is the value of ##E[X|Z=z]+E[Y|Z=z]##?
Which is the bigger of ##E[X|Z=z]## and ##E[Y|Z=z]## (trick question).
1. E[X|Z=z] + E[Y|Z=z] = E[X+Y|Z=z] = E[Z|Z=z] = z?
2. Is there a way of knowing?
Could it be that since P(X=x|Z=z) = 1/(z-1), which is an uniform distribution, the expected value I'm looking for can simply be found by using the formula for the expected value of the uniform distribution?
edit: I tried to do it that way, but I couldn't find the right answer. So i tried by using the formula for the expected value. What I did not realise at first is that I had to sum from x=1 to x=z-1, right? By doing so I get that E[X|Z=z]=
Σx=1z-1 x·P(X=x|Z=z) =
Σx=1z-1 x/(z-1) = 1/(z-1)·Σx=1z-1 x =
1/(z-1) · (z-1)(z-1+1)/2 = z/2.
Is this valid?
Is this valid?
Yes it is.
There is another approach as described by @andrewkirk in the post #2. The first question is answered in the post #3. What about the trick question? Is ## E [X|Z=z] ## bigger than ## E [Y|Z=z] ##? or Is ## E [Y|Z=z] ## bigger than ## E [X|Z=z] ##? or What is the third option?
Yes, it can be found by using a formula for calculating an expected value of a discrete uniform distribution.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
