- #36
atyy
- 3,378
jbmolineux said:I actually agree with what I understand to be the conclusions of what you are saying. If you take "Copenhagen Interpretation" to mean "that which matches known experimental results," then the CI is the only reasonable interpretation. And if you then allow for the CI to be "agnostic about the reality of the wave function," and even agnostic about the possibility of hidden variables --then that seems very close to the view that makes the most sense to me in my current limited state of knowledge
Yes that is close to what I mean by CI. It is true that CI is not a well-defined term, and different people use it differently. I mean CI as a sort of minimal interpretation that should be consistent with most or all other possible interpretations. To be specific, I am thinking of something like the interpretation given at the start of Landau and Lifshitz's textbook on quantum mechanics.
jbmolineux said:But in a previous thread you said, "It is impossible to know both the position and momentum of a quantum particle, because it does not and cannot have both position and momentum simultaneously." My understanding was that some non-CI interpretations would not necessarily agree with that--or at least that it would be possible to believe that the particles DID have a momentum and position without contradicting any known experimental results. Einstein was at least reasonable familiar with most of the relevant theoretical results, and my understanding was that he did not agree with that. Moreover, it seems to be actually impossible to design an experiment that PROVES that particles don't have a momentum or velocity, even if it IS possible to prove that it's impossible to MEASURE both a particle's momentum and velocity.
Yes, this is technically tricky, but it is consistent with the meaning of CI I have just outlined. The main problem causing the confusion is that there are several different definitions of position and momentum. A particle may not have a certain type of position and momentum, but it can of course have another type of position and momentum. In quantum mechanics, the most usual definition of position and momentum are the non-commuting canonically conjugate position and momentum. It can be shown that in general and for all hidden variable interpretations, including any of the many possible variants of the Bohmian interpretation, that a particle cannot have simultaneously well-defined non-commuting canonically conjugate position and momentum. In Bohmian mechanics, it is possible for a particle to have a different sort of position and momentum, defined using the Hamilton-Jacobi formalism.
