Trinitiet
- 23
Today I did an experiment to met the light intensity, a function of the wavelength of light. I gained a theoretical model *how it should look*, which had 1 light intensity peak at lambda=1083nm.
On the other hand, I measured several peaks, 1 at ~600nm and another at ~750 and 825nm.
What could've been the source of these peaks?
The first thought I had was the measurements weren't accurate, but I did the experiment over and over again and kept getting the peak.
Second thought: it's backgroundradiation. So I removed the Helium lamp and turned off the lights of the room and did the experiment again. No peaks were measured thus they can't be caused by background sources.Anyone got a thought what could cause these peaks? The line up of the experiment:
Helium lamp (with a steellike frame around it, though this can't cause the peak as it was still there when we did the background no measured peaks experimtn), then a collimator, then a lens, a glass prism, another lens and then a light sensor.
Is any additional information needed?
