Experimental check of photon mass and Coulomb's law
In summary: The photon propagator is the Green's function for the electromagnetic interaction. The static case (Coulomb field) is described by ##q^0=0##, i.e.,$$G=-\frac{1}{\vec{p}^2},$$which is familiar from classical electrodynamics. It's just the Fourier transform for the coulomb field (potential), which is ##\propto \frac{1}{|\vec{r}|}##.Now with a photon mass the propagator reads$$G=-\frac{1}{\vec{p}^2+m^2}.$$This corresponds
Prometeus
43
Despite some effort I still don't understand how Coulombs law can be used for experimental search for mass of photon.
From wikipedia:
If a photon did have non-zero mass, there would be other effects as well. Coulomb's law would be modified and the electromagnetic field would have an extra physical degree of freedom. These effects yield more sensitive experimental probes of the photon mass than the frequency dependence of the speed of light. If Coulomb's law is not exactly valid, then that would allow the presence of an electric field to exist within a hollow conductor when it is subjected to an external electric field. This thus allows one to test Coulomb's law to very high precision.[25] A null result of such an experiment has set a limit of m ≲ 10−14 eV/c2.[26]
Why would Coulombs law be needed modified if photon had non-zero invariant mass?
I want to answer this, but give me about...3-5 days to do some research.
This corresponds to an interaction law following a Yukawa potential ##\propto \exp(-mr)/r##.
Thanks for answer, but it seems that this topic is above my current knowledge.
The E field can carry energy and momentum. If I'm reading @vanhees71 correctly (and I may not be, so see what he says to this) then energy and momentum aren't conserved by an E field with a ##1/r## potential if the photon has mass. So a check that a static E field looks like a ##1/r## potential is equivalent to a check on the masslessness of the photon.
Energy and momentum are conserved for any kind of fields in relativstic QFT. The mass only enters in the dispersion relation. For a free particle it reads ##E=\sqrt{\vec{p}^2+m^2}##. In any scattering process the four-momentum, i.e., energy and momentum, is conserved.
Have tried to study the proposed topics, but despite my effort is seems to me, that all these arguments towards Proca equations, Yukawa potential and Coulombs law are kind of circular arguments. I will try to explain why. So here we have Coulombs law including vacuum permittivity:
https://wikimedia.org/api/rest_v1/media/math/render/svg/2c30719f1efcb507ce62de711b04c7f51f64983b
But let's say, that theoretically photon has some tiny mass, the measured speed of light would include this mass and also measured vacuum permittivity would include that mass, because speed of light can be expressed by
https://wikimedia.org/api/rest_v1/media/math/render/svg/f83cb831ce59c5745ee4e7af60b4f68710405b6b
So theoretically we could say that mass of photon is included in measured c and vacuum permittivity and you can use Yukawa potential to find mass of particles with mass above mass of photon, but not to find mass of photon itself.
I understand, that this line of reasoning is with very high probability wrong, but could somebody point out where is the mistake in my understanding?
Possibly interesting reading:
https://books.google.com/books?id=jL9reHGIcMgC&dq=%22lectures+on+gravitation%22+feynman&pg=PA22(see page 22)
Look for the passage starting with...
"Tell me, Professor Feynman, how sure are you that the photon has no rest mass?..."
If the photon had a nonzero rest-mass, blue light would travel at a different speed than red light. (This is related to the dispersion relation mentioned by @vanhees71.)
In theory yes, practically no. Just look on the measurements of speed of neutrino (quote from Wikipedia):
Since it is established that neutrinos possesses mass, the speed of neutrinos should be slightly lower than the speed of light in accordance with special relativity. Existing measurements provided upper limits for deviations of approximately 10−9, or a few parts per billion. Within the margin of error this is consistent with no deviation at all.
The only consequence concerning the "speed of light" if the electromagnetic field (photon) had a mass term would be that we had to rename that speed the "limiting speed of relvaitivity". There is no doubt that spacetime is better described relativistically than non-relativistically and this implies the existence of such a "limiting speed", which in fact within relativity is just a conversion parameter from the arbitrary choice of time and spatial distance units.
Sure, you are completely right, but this is other topic. I am trying to get to the bottom of reasoning behind experimental checks of photon mass.
I don't know, how often I've written this already in this thread, but again. A pure state is NOT represented by a (normalized) vector ##|\psi \rangle## but by the corresponding ray. This is very important to keep in mind to understand very basic concepts of QT, e.g., the existence of half-integer spins etc. Pure states, however, are not enough to describe physics since they are rare and have to be usually carefully prepared in the lab. The general description of a state is through a statistical operator ##\hat{\rho}## which is a self-adjoint positve semidefinite operator of trace 1. A statistical operator ##\hat{\rho}## represents a pure state if and only if ##\hat{\rho}^2=\hat{\rho}##. Then there exists one and only one eigenvector with eigenvalue ##1##, ##|\psi \rangle##, and all other eigenvectors are to the eigenvalue ##0##. Thus a pure state is uniquely represented by the projector ##\hat{\rho}=|\psi \rangle \langle \psi|##.
The speed of electromagnetic waves can be measured much more precisely than the speed of neutrinos, but the corresponding upper limits are still much worse than tests of the quasi-static electromagnetic field in astronomy.
Yes, that's true, but nobody bothered to point out where is my logical flaw when I am assuming that electromagnetic tests are useless because of circular reasoning behind it. Because when photon has mass, that means speed of light is corresponding to its mass and this also means that value of vacuum permittivity is also including mass of photon and vacuum permittivity is directly affecting Couloubs field and also Yukawa potential, meaning that electromagnetic tests are showing no difference.
No. You cannot use a framework developed for massless light to study the case of massive light.
The speed limit of special relativity is independent of light. If light has a mass, it is slower than this speed limit, and the changed propagator also means you do not get a 1/r field any more (similar to the Z boson: it has mass, therefore it has a short range). The difference between Yukawa and Coulomb potential is testable: put the same charge at twice the distance and see if the force goes down by a factor 4 (very simplified description).
It seems you don't understand what I am trying to say. Testing difference between Yukawa and Coulomb potential could be completely useless because measured value of vacuum permittivity could include (unmeasured) mass of photon. If my understanding of equations of Yukawa and Coulomb is right, it will still go down by factor 4 even when vacuum permittivity includes mass of photon. Measuring mass of Z boson is possible via Yukawa potential, because if vacuum permittivity includes mass of photon, the difference would show mass of Z boson greater as mass of photon, so it would be still in line of existing expectations.
As I said, you cannot apply frameworks for massless particles in the case of massive particles. As long as you try that you cannot come to the right anwer.
It seems to me that the fundamental flaw in the OP's reasoning is to assume that the speed of light referred to in SR is the speed at which light travels regardless of whether it has mass or not. This is not the case. If light has mass it will be able to travel at any speed below c. It is merely a historical coincidence that we call the invariant speed the speed of light, based on light being the first observed entity traveling at that speed (within experimental error).
Also, the discovery of neutrino masses had nothing to do with measuring their velocities.
Likes vanhees71
Yes, perhaps one should rename the "speed of light" to "relativistic speed limit" or something like that, although it sounds a bit odd. I guess, this won't work since "speed of light" is too established to change the name.
I would just go with "invariant speed", but as you say, I think it is way too late to change this.
Edit: Ideally though, it might be better to call it "time-to-length unit conversion factor" ... :rolleyes:
Likes mfb
Related to Experimental check of photon mass and Coulomb's law
What is the purpose of conducting an experimental check of photon mass and Coulomb's law?
The purpose of this experiment is to test the fundamental laws of nature and help further our understanding of the behavior of photons and the relationship between electric charges.
How is the mass of a photon measured in this experiment?
In this experiment, the mass of a photon is measured by observing its momentum and energy, and using the equation E=mc^2 to calculate its mass.
What is Coulomb's law and how is it related to the behavior of photons?
Coulomb's law states that the force between two electric charges is directly proportional to the product of their charges and inversely proportional to the square of the distance between them. This law is related to the behavior of photons as photons are electromagnetic particles and their behavior is affected by electric charges.
What are the potential implications of finding a non-zero mass for photons in this experiment?
If a non-zero mass for photons is found in this experiment, it could potentially challenge our current understanding of the nature of light and have significant implications for the laws of physics.
How does this experiment contribute to the field of physics?
This experiment contributes to the field of physics by providing evidence and data to support or challenge existing theories and laws, and helping to expand our knowledge and understanding of the fundamental principles of the universe.
9K
