Experimental confirmation of electroweak?
In summary: due to their coupling to the strong force...are a statistical confirmation of the electroweak unification.
Sparky_
227
Can you clear something up for me?
I see that the discovery of the W and Z boson in 1983 is described as confirming the electroweak unification theory.
I was thinking that the W and Z were carriers of just the weak force.
I don’t see how the experimental discovery of the W and Z show that electromagnetism and the weak force are really one force at higher energies.
Was it the experimental discovery of something else that confirms the electroweak unification?
Can you clear this up for me?
I have a follow-up also – has the strong force been experimentally verified as unified with the electroweak force yet? If so what particle or particles were discovered and when? I don’t recall this making the news (yet).
Thanks
-Sparky
Experiments don't just detect new particles. They also measure cross sections for scattering processes and decay rates of the elementary particles that are produced. It is this wealth of data that can be used to statistically confirm the electroweak theory.
Electroweak unification is partly verified (it's also strongly tied to the charge assignments of the fundamental particles) by confirming the relationship between the [itex]SU(2)\times U(1)[/itex] coupling constants,
[itex] \frac{1}{g_1^2} + \frac{1}{g_2^2} = \frac{1}{4\pi\alpha} ,[/itex]
where [itex]\alpha[/itex] is the fine structure constant. Some relationship of this form must hold if the electromagnetic [itex]U(1)[/itex] gauge group is nontrivially embedded in both factors of the electroweak group. Extracting the electroweak parameters like [itex]g_1,g_2[/itex] is done by comparing theoretical vs experimental results for many processes, not just the W and Z masses.
Unification of the strong and electroweak forces is what's referred to as a grand unified theory (GUT). Despite various theoretical motivations for grand unification, no GUT has been experimentally verified. It is worth pointing out that the most probable scale for grand unification is many orders of magnitude above what we can test at a collider experiment for the foreseeable future. Observational cosmology might have some chance to provide at least indirect tests of GUT ideas before we have the technology or funding to build a solar system scaled collider.
I recall reading something - pretty sure it was in Discover years and years ago regarding the discovery of the W and / or Z boson and how that confirmed the electroweak unification.
The article (of course for the average person - like me) seemed to point to the success of I forget which accelerator in this discovery.
I now see that W and Z seem to be associated with just the weak force.
Am I correct that the W and Z are carriers of the weak force?
Am I correct in recalling that there was celebration with the experimental discovery of either or both the W and Z?
If the W and Z are carriers of the weak force how does their discovery do anything for the electromagnetic side?
Thanks again
-Sparky_
What we mean by unification is that the electromagnetic force is not simply the [itex]U(1)[/itex] factor of the electroweak [itex]SU(2)\times U(1)[/itex]. It's easy to roughly sketch a bit of how things work by considering how the W, Z and photon, [itex]A_\mu[/itex], embed into the EW group. For the [itex]SU(2)[/itex] factor, the 3 gauge boson are a Hermitian matrix that we can write as
[itex]\begin{pmatrix} C^0_\mu & C^+_\mu \\ C^-_\mu & - C^0_\mu \end{pmatrix},[/itex]
while we'll denote the carrier of the [itex]U(1)[/itex] by [itex]B_\mu[/itex]. Then we have the identifications
[itex] W^\pm_\mu = \frac{1}{\sqrt{2}} C^\pm_\mu, ~~Z_\mu = C^0_\mu \cos\theta_W - B_\mu \sin\theta_W ,~~ A_\mu = C^0_\mu \cos\theta_W + B_\mu \sin\theta_W,[/itex]
where [itex]\theta_W[/itex] is called the weak mixing (or Weinberg) angle. Unification is the fact that the photon and Z are orthogonal linear combinations of the same neutral gauge bosons. The pattern of electroweak symmetry breaking through the Higgs mechanism gives the Z combination a mass, but leaves the photon massless.
This is to be contrasted with nonunification, where perhaps we try to identify [itex]C^0[/itex] with the Z and [itex]B[/itex] with the photon. Such an attempt would not be consistent with observation.
The W and Z are carriers of the weak force. Their large masses explain why the weak force is so much weaker than the electromagnetic force at scales well below the EW symmetry breaking scale. Observation of the W and Z was a great triumph, but the associated analysis of the rest of the data regarding electroweak interactions had a more profound effect on our understanding of physics.
Sparky, I think what you're thinking of was the electroweak model's prediction of the mass of the Z. Basically, the nature of the electroweak unification means that you can predict the mass of the Z (well, ignoring small quantum corrections) knowing only three parameters - the electromagnetic coupling constant (e), the (charged current) weak coupling strength (usually given in terms of the Fermi constant, [itex]G_F[/itex]), and the W mass ([itex]m_W[/itex]). Given these, the Z mass should be
[tex]m_Z = \frac{m_W}{\sqrt{1-\frac{e^2}{4\sqrt{2}m_W^{\phantom{W}2}G_F}}}[/tex].
And, in fact, when the Z was found, its mass matched that prediction quite well.
FAQ: Experimental confirmation of electroweak?
1. What is the electroweak theory?
The electroweak theory is a unified theory of electromagnetism and the weak nuclear force, which are two of the four fundamental forces of nature. It explains how these two forces are related and how they govern the behavior of subatomic particles.
2. How was the electroweak theory experimentally confirmed?
The electroweak theory was experimentally confirmed through a series of experiments, including the discovery of the W and Z bosons at CERN in 1983 and the precision measurements of the properties of these particles. These experiments provided strong evidence for the existence of the electroweak force and its unified nature.
3. What is the significance of the electroweak theory?
The electroweak theory is significant because it is a key component of the Standard Model of particle physics, which is our current best understanding of the fundamental building blocks of the universe. It has been extensively tested and has made accurate predictions about the behavior of particles and their interactions.
4. How does the electroweak theory relate to the Higgs boson?
The electroweak theory predicts the existence of the Higgs boson, which is a fundamental particle that gives mass to other particles. The discovery of the Higgs boson at CERN in 2012 provided further confirmation of the electroweak theory and completed the picture of the Standard Model.
5. Are there any remaining questions or challenges to the electroweak theory?
While the electroweak theory has been extensively tested and confirmed, there are still some unanswered questions and challenges. For example, it does not explain the origin of the mass of the Higgs boson, and it does not include gravity, which is currently described by the theory of general relativity. Scientists are still working to find a more complete and unified theory that can explain all of the fundamental forces and particles of the universe.
