Experimental dispersion relation of phonons
In summary, phonons do not have momentum, but *lattice*-momentum, which is lives on a torus (or some other compact manifold) rather than a plane. This is because the underlying crystal violates translational symmetry, reducing it to a discrete one. Similarly, electrons in crystals only have lattice momentum. However, when determining the dispersion of phonons, one would shoot in some neutrons, and observe the change of (true) momentum. This curve should repeat after translation by one reciprocal lattice vector, from which the zone can be determined. Then folding the curve back on itself gives the desired relationship.
exciton
Hi guys,
I don't understand how one would exactly determine a dispersion relation
of phonons experimentally.
There are two equations, one for momentum and one for energy conservation:
[tex]\vec{k} - \vec{k^{'}} = \vec{G} + \vec{K} [/tex]
[tex]\omega - \omega ^{'} = \omega(K) [/tex]
where [tex]\omega(K)[/tex] is the energy difference of the scattered neutrons,
[tex]\vec{k} [/tex], [tex] \vec{k^{'}} [/tex] are the wave vectors of the neutrons before and
after scattering, [tex]\vec{K} [/tex] is the created phonon and [tex]\vec{G} [/tex] a
reciprocal lattice vector.
The question is, how is the difference [tex]\vec{k} - \vec{k^{'}} [/tex] respectively [tex]\vec{K} [/tex] determined experimentally?
Of course I also have to know [tex]\vec{G} [/tex].
thanks
You can't. Phonons simply do not have momentum, but *lattice*-momentum, which is lives on a torus (or some other compact manifold) rather than a plane. This is because the underlying crystal violates translational symmetry, reducing it to a discrete one. Similarly, electrons in crystals only have lattice momentum.
But, you will say, what about when I shoot something into it? Outside, it's got definite momentum, but inside it doesn't?
Answer: Yep. It's momentum will get broken into two components, one that lies in the Brillouin zone, and a component that is a multiple of the reciprocal lattice vector. The latter is transferred to the entire crystal as a whole. Upon emission, the opposite happens, one component from within the Brillouin zone is added to a crystal momentum to give the exiting particle its true momentum.
So when determining the dispersion of phonons, one would shoot in some neutrons, and observe the change of (true) momentum. This curve should repeat after translation by one reciprocal lattice vector, from which the zone can be determined. Then folding the curve back on itself gives the desired relationship.
Hi genneth,
thanks for your (very good) explanation. It helps a lot.
Related to Experimental dispersion relation of phonons
1. What is an experimental dispersion relation of phonons?
An experimental dispersion relation of phonons is a graph that shows the relationship between the frequency and wave vector of phonons in a material. It is obtained through experimental techniques such as neutron scattering or Raman spectroscopy.
2. Why is studying the dispersion relation of phonons important?
Studying the dispersion relation of phonons allows us to understand the behavior and properties of materials at the atomic level. This information is crucial for designing new materials with specific properties or improving existing materials.
3. How is the experimental dispersion relation of phonons different from the theoretical dispersion relation?
The experimental dispersion relation is obtained through direct measurements on a material, while the theoretical dispersion relation is derived from mathematical models. The experimental data may not always match the theoretical predictions due to various factors such as imperfections in the material or experimental limitations.
4. Can the experimental dispersion relation of phonons be used to predict the properties of a material?
Yes, the experimental dispersion relation can provide valuable information about the properties of a material, such as its thermal conductivity, sound propagation, and heat capacity. However, other factors such as defects or impurities in the material may also affect its properties.
5. How does the dispersion relation of phonons vary between different materials?
The dispersion relation of phonons can vary significantly between different materials, depending on their atomic structure and bonding. For example, materials with strong covalent bonds may have a different dispersion relation compared to materials with weaker intermolecular bonds.
  • Atomic and Condensed Matter
  • Classical Physics
  • Classical Physics
