Experimental evidence of higher dimensions. What will they be?
In summary: Sure, I have a link for you.The article you are mentioning is called "Is the Universe Going to End?" and it was written by Konopinski, Marvin, and Teller.
yoda9999
Has there been any direct or indirect evidence from particle accelerators, telescopes, or observatories that the universe has more than 3 spatial dimensions? If not, what kind of evidence or data are particle physicists looking for? Are there some unexplained phenomenon that could only be attributed to the existence of higher dimensions?
I've been told that the Large Hadron Collider could yield some results about extra dimensions. If anyone wants to elaborate on that, that'll be fine. Thanks!
Yes several methods..
1) Indirect proof.. Usually associated with phenomology. The so called phenomological desert most places and boom lots of activity at some critical scale.
2) Direct proof. Kaluza Klein Modes, which would be very evident in a particle accelerator.
3) Even more direct proof, large extra dimensions and departure from Newtons laws at say nm scales
I read a nice clear article a while back about the LHC possibly revealing extra dimensions, yoda. I'll try to dig it up. Meanwhile there's a lot of papers you can find via a google search.
http://www.google.co.uk/search?hl=en&q="large+hadron+collider"+dimensions&meta=
Rather too many, so maybe one of the experts here could select a few out for you.
lowered Planck energy
I've heard that if there are any extra dimensions compactified on a scale significantly larger than the Planck length, the Planck energy would be lower than its calculated value of ~10^19 GeV. Consequences of this would evident at the LHC II next year, like the production of microscopic black holes or a (hopefully remote) chance of triggering a cosmological phase transition (a.k.a. vacuum decay) and thus ending the universe as we know it. Other consequences would be departures from Newtonian gravitation and general relativity at the length scale of the not-fully-compactified dimension(s). These departures would usually involve a weakening of the expected gravitational force at the length scale involved.
xionium said:
... chance of triggering a cosmological phase transition (a.k.a. vacuum decay) and thus ending the universe as we know it.
surely there are other processes in the universe whose energy output is many orders of magnitude beyond that of the LHC... wouldn't it be more probable that such reactions would trigger such a phase transition?
Of course, there is no guarantee it hasn't happened yet, and we're waiting to find out.
That is one of the primary arguments against those who claim that the LHC II will end the universe as we know it next year. It is similar to the calculations that there is a one-in-a-billion chance that a thermonuclear weapon will ignite the atmosphere, ending most life on the planet. If you detonate enough thermonuclear weapons, one of them will eventually destroy the planet. Similarly, if you achieve the Planck density enough times (assuming that we can even reach it with the LHC), one of those times it will destroy the universe. Everything has an associated risk.
I don't mean to be rude but I have to call this BUNK. Can you show me this calculation? Because a report authored by Konopinski, Marvin and Teller (LA-602), which was commisioned by Oppenheimer (declassified in 1973) showed that it could never happen (with the fission weapons of the time). You can see the document http://www.fas.org/sgp/othergov/doe/lanl/docs1/00329010.pdf"
The main finding was that even if you can achieve the needed temperature (which may or may not be possible today- I do not know), compton scattering would make a chain reaction impossible. Now, I have only skimmed the document and I do not have a nuclear weapons background, so I wouldn't mind someone correcting me.
On the notion of the LHC creating a cosmological phase transistion... not being a cosmologist and all, could someone spell this out a little? Or give a credible reference for it please?
You are correct---apparently it was thought that there was a slim but finite chance that thermonuclear weapons could ignite the atmosphere until it was proven impossible. Thanks for the info. Even though it is impossible, though, the analogy for cosmological phase transitions/vacuum decays still holds. Most likely a cosmological phase transition will not occur at the LHC, even if the Planck energy is reached, but I would feel a lot better if it could be proven mathematically impossible, like the atmospheric ignition.
Do you know on what theoretical framework this notion that a cosmological phase transition is based on?
Basically, a cosmological phase transition is when the universe decays to a stabler and less energetic state, similar to the phase transitions of matter. Past cosmological phase transitions include the Planck, GUT, and electroweak transitions. These transitions involved major changes in the forces and constituents of the universe, such as the decay of the X and Y bosons of GUT theories to produce a matter-antimatter asymmetry in our universe. Scientists predict that the next cosmological phase transition would probably not occur naturally for another 10^100 to 10^1000 years. This is way beyond what big bang theorists call the "big freeze" or heat death of the universe. The universe would most likely not be able to support "life" at that time, even in its most speculative forms.
So with the LHC the worry is about the Planck transition I garner. But aren't all (maybe a better question is any) these theories of the Planck transition based on some sort of SUSY framework? Implying no SUSY = no worries. And the whole notion that IF these POSSIBLE extra dimensions exist the Planck energy MIGHT be lower than the "accepted" value seems wildly speculative.
FAQ: Experimental evidence of higher dimensions. What will they be?
1. What is the evidence for higher dimensions?
The evidence for higher dimensions comes from various fields of science, including mathematics, theoretical physics, and cosmology. One of the most significant pieces of evidence is the mathematical models and equations that suggest the existence of additional spatial dimensions beyond the three dimensions we are familiar with. Additionally, experiments such as the Michelson-Morley experiment, which showed the constancy of the speed of light, support the idea of higher dimensions.
2. How can we detect these higher dimensions?
Currently, there is no direct way to detect higher dimensions. Scientists rely on indirect methods, such as observing the behavior of particles at high energies, studying patterns in the cosmic microwave background, and analyzing the results of particle collider experiments. These methods allow us to gather evidence and make predictions about the existence of higher dimensions.
3. What implications do higher dimensions have on our understanding of the universe?
The existence of higher dimensions would require a significant shift in our understanding of the universe. It would challenge our perception of space and time and potentially provide explanations for unanswered questions, such as the nature of gravity and the origin of the universe. Additionally, it could open up possibilities for new technologies and advancements in science.
4. How many dimensions are there?
The number of dimensions is still a topic of debate among scientists. Some theories suggest that there could be up to 11 dimensions, while others propose the existence of infinite dimensions. The exact number of dimensions remains unknown, and further research and experimentation are needed to determine the true nature of the universe.
5. What are the potential consequences if we find evidence of higher dimensions?
If we find concrete evidence of higher dimensions, it would revolutionize our understanding of the universe and have significant implications for various fields of science. It could lead to advancements in technology, provide insights into the mysteries of the universe, and potentially open up new avenues for exploration and discovery.
